inkjet printing
2006-07-14 by Stefan Trethan
How do i reduce the amount of ink used?
I still have some puddling!
I tried printing grey, but then printing a gradient image from black to
white it will be full on black to a distance and then full on white. I
have tried using the brightness/contrast setting in the driver with the
same effect.
Why?
Also, i notice the parking pad is full of ink/water each time. i have
disabled the vacuum pump to prevent all ink running off, and manually pull
the pad dry with a syringe before printing. It is easy to prime or clean a
printhead without the pump, with the syringe. But i do not think the ink
should run down into the parking pad normally?
I want to get this to work perfectly, today ;-)
Any suggestions on how to solve the puddling issue? IMO there is simply
too much ink applied, how do i get it to make smaller droplets? (the 84
does have this capability).
thanks
ST
same effect.
Why?
thanks
ST
