Gap between print head and the PCB?
2006-04-24 by lcdpublishing
Steve, or anyone,  I suspect that the distance between the print head
and the PCB is critical.  I suspect most folks are like me, you use
the PCB material you can get and lately I have been buying off E-Bay
at really good prices.  However, the thickness varies.
So, I am planning my mechanical conversion to be adjustable to
accomodate the various thickness PCB materials.  I suspect this could
add a lot of complexity in the conversion process, but if I have time
I want to do it.  I just don't have any idea what would be the
acceptable range between that print head and the PCB material being
printed - anyone?
CHris
Re: [Homebrew_PCBs] Gap between print head and the PCB?
2006-04-24 by Stefan Trethan
many printers have a lever to adjust height. If that can be kept in a
working state it can solve the problem.
"Back then" when i did that useless HP conversion i simply planned on
putting another PCB below the one to be printed. If i wanted to print 1mm
this shim PCB would be 0.5mm, for 0.5mm 1mm.
ST
On Mon, 24 Apr 2006 17:12:14 +0200, lcdpublishing
> printed - anyone?
> CHris
Re: Gap between print head and the PCB?
Ah, excellant suggestion!  Get the range to work and accept thick
boards, and pass two through at the same time to make up the
difference beyond adjustment - Great idea!
Chris
in a
on
print 1mm
> ST
head
use
Bay
could
time
being
> > printed - anyone?
> > CHris
Re: [Homebrew_PCBs] Re: Gap between print head and the PCB?
On Mon, 24 Apr 2006 17:58:27 +0200, lcdpublishing
> Chris
I really believe some sort of flat table must be constructed to allow for
second side alignment.
Thinking about it now it seems to me a printer with bend-over paper path
might be best for that, since the table can ride over the large central
roller. With the semi-straight path printers the paper passes below the
drive rollers i would expect. maybe one can only use two narrow rollers at
the side so there is space for a PCB in the center.
ST
Well,
I got started on the modifications and it ain't pretty so far.
Right now I am cutting away a lot of the sheet metal framing to get
the path clear for "Straight through" feeding.  My first goal is to
get to that point where I can get a PCB to pass through it.
Then, the next step is to figure out where to re-locate the logic
board.  Some of the flat cables are pretty short and won't allow me
to move some parts very far.  Once I get to that point, I am going
to start looking at how I can get the PCB to feed straight and to
handle two sided printing.
I found the one switch for the paper sensor - working with that will
be key to getting double sided printing to work good.  There is
another sensor on the printer which seems to be in the paper feeder
section.  Not sure what that is for yet.  It seems to sense the
position of the cam that grabs the paper from the stack.  If it is
for that, I believe that one won't be much a problem.
Will report any further findings as I move along with this thing.
By chance, Stefan have you started on your printer yet (that is if
you have it in hand yet)?
Chris
Hmmm, getting more difficult with the 850...
I have managed to cut away all the metal in the way of the PCB path.
Then I started watching as I was pushing a PCB through the printer to
see what problems and clearences and such are needed and where. Got
all the obstructions out of the way and have clearance between the
print head and the PCB now.
Now the problem is getting the PCB to feed through.  The main feed
roller on this printer is the metal roller with the rough surface on
it - not a rubber roller.  There just isn't enough friction between
that and the rollers above and the PCB to pull the PCB through.  There
is a second set of rubber rollers on the outfeed side. Once I get the
PCB to that point, it might feed okay.
Getting a carrier board in there is the next direction for me to start
looking.
2006-04-24 by Lez
what about some silicone rubber on the rough metal roller ?
- Looking for early starwars (episode 4, original starwars)
recordings, even pirate
- I dont need your originals just some information about running time
- and scene cut points
- also looking for a car, silver or white, 4 doors -
- diesel with a bosch pump, abs and pas  -
- aircon would be nice, and not a ford       -
