By chance does anyone know if a LEXMARK printer will work with the MIS inks?
2006-04-24 by lcdpublishing
I now have two ink jet printers to use for experimenting on this process, but I have to pick one. I have an Espon Stylus 850 and a Lexmark 3200. It does appear the Lexmark might be easier to modify for PCB printing mechanically. But as for the MIS inks, I have no idea if it will even be able to use them. If anyone knows, I would appreciate it if you could let me know too! Chris
2006-04-24 by Stefan Trethan
I think the lexmark is thermal inkjet, go with epson. ST On Mon, 24 Apr 2006 15:10:16 +0200, lcdpublishing <lcdpublishing@...> wrote:
> I now have two ink jet printers to use for experimenting on this > > process, but I have to pick one. I have an Espon Stylus 850 and a > > Lexmark 3200. > > > It does appear the Lexmark might be easier to modify for PCB printing > > mechanically. But as for the MIS inks, I have no idea if it will even > > be able to use them. If anyone knows, I would appreciate it if you > > could let me know too! > > > Chris >
2006-04-24 by Mycroft2152
Hi Chris, The Lexmark ink cartidges do not use the piezo pump technlogy like the Epsons. but rather the thermal jet design. Withnin the printhead in the cartridges are resisitors that vaporize a small portion of the ink to push a drop out of the cartridge. Having said all that, it would be worth testing the MIS ink on a used cartidge first, before modifying the printer. There are pigment type ink refill kits for the Lexmark, so perhaps the ink will not clog the jets? I would think chances are slim that it will work, but we all said that about inkjet printing directly to the pcbs a few weeks ago. TANSTAAFL! Myc --- lcdpublishing <lcdpublishing@...> wrote: > I now have two ink jet printers to use for > experimenting on this > process, but I have to pick one. I have an Espon > Stylus 850 and a > Lexmark 3200. > > It does appear the Lexmark might be easier to modify > for PCB printing > mechanically. But as for the MIS inks, I have no > idea if it will even > be able to use them. If anyone knows, I would > appreciate it if you > could let me know too! > > Chris > > > > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
2006-04-24 by Steve
--- In Homebrew_PCBs@yahoogroups.com, "lcdpublishing" <lcdpublishing@...> wrote: > > I now have two ink jet printers to use for experimenting on this > process, but I have to pick one. I have an Espon Stylus 850 and a > Lexmark 3200. > > It does appear the Lexmark might be easier to modify for PCB printing > mechanically. But as for the MIS inks, I have no idea if it will even > be able to use them. If anyone knows, I would appreciate it if you > could let me know too! Use the Epson 850. The Lexmark is bubblejet aka thermal inkjet and the MIS pigmented inks will NOT work in it. To clarify: only the black will be pigmented for the Lexmark and HP. See here: http://www.inksupply.com/inks.cfm Steve Greenfield
2006-04-24 by Steve
--- In Homebrew_PCBs@yahoogroups.com, Mycroft2152 <mycroft2152@...> wrote: > > Hi Chris, > > The Lexmark ink cartidges do not use the piezo pump > technlogy like the Epsons. but rather the thermal jet > design. Withnin the printhead in the cartridges are > resisitors that vaporize a small portion of the ink to > push a drop out of the cartridge. > > Having said all that, it would be worth testing the > MIS ink on a used cartidge first, before modifying the > printer. > > There are pigment type ink refill kits for the > Lexmark, so perhaps the ink will not clog the jets? You are either seeing a kit with pigmented black and dye colors, or confusing "archival" with pigmented. Archival is used as a marketing term and has no real meaning. However, there is that pigmented black in the Lexmark and HP printers... perhaps that is worth testing. Also, some HP printers use the same print heads only with different inks for the color heads. Those might be a candidate for loading all with HP pigmented inks. Argh, I wish I had time for testing! I have some HP printers here with OEM ink, and a Novajet III (needs a belt) with all four colors pigmented (it uses the HP 44 print head for all four colors). Steve Greenfield
2006-04-24 by Christopher Hart
I just got my paper thin circuit boards off ebay, and plan on doing some tests with HP ink tomorrow. these boards are actually very flexible as well, and I suspect I will have no problem with the 180 degree paper path. I don't want to modify my old HP, and waste money on new cartridges for it (Cyan and Yellow don't print on it at all for some reason other than the cartridge)
On Monday 24 April 2006 10:43, Steve wrote: > --- In Homebrew_PCBs@yahoogroups.com, Mycroft2152 <mycroft2152@...> wrote: > > Hi Chris, > > > > The Lexmark ink cartidges do not use the piezo pump > > technlogy like the Epsons. but rather the thermal jet > > design. Withnin the printhead in the cartridges are > > resisitors that vaporize a small portion of the ink to > > push a drop out of the cartridge. > > > > Having said all that, it would be worth testing the > > MIS ink on a used cartidge first, before modifying the > > printer. > > > > There are pigment type ink refill kits for the > > Lexmark, so perhaps the ink will not clog the jets? > > You are either seeing a kit with pigmented black and dye colors, or > confusing "archival" with pigmented. Archival is used as a marketing > term and has no real meaning. > > However, there is that pigmented black in the Lexmark and HP > printers... perhaps that is worth testing. > > Also, some HP printers use the same print heads only with different > inks for the color heads. Those might be a candidate for loading all > with HP pigmented inks. > > Argh, I wish I had time for testing! I have some HP printers here with > OEM ink, and a Novajet III (needs a belt) with all four colors > pigmented (it uses the HP 44 print head for all four colors). > > Steve Greenfield > > > > > > Be sure to visit the group home and check for new Links, Files, and > Photos: http://groups.yahoo.com/group/Homebrew_PCBs > > If Files or Photos are running short of space, post them here: > http://groups.yahoo.com/group/Homebrew_PCBs_Archives/ > > > > > SPONSORED LINKS > Electrical engineering degree online Electrical engineering degree > Printed circuit board Electrical engineering Electrical engineering > course Electrical engineering graduate school > > > YAHOO! GROUPS LINKS > > > Visit your group "Homebrew_PCBs" on the web. > > To unsubscribe from this group, send an email to: > Homebrew_PCBs-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > > Message transport security by GatewayDefender > 10:44:29 AM ET - 4/24/2006
Thanks guys! The 850 it is then. Later today or tonight I will begin the process of deeper investigation to see how good or bad it will be for conversion to print on PCBs. I should be getting the ink in a couple of days so I am hoping by next weekend I will be able to do some testing and experimenting. Posted another topic on this whole conversion thing that I believe will be a critical element in it all. Chris
Well, at least we know if we are too stupid to make it work we have someone who will manage eventually ;-) I'm not even sure using a HP is that desireable. The disposable heads on some bubblejets are not that desireable for me, seeing that i can buy another epson for less than a new cartridge with head. Anyway, i'll stick with the most likely chance for now, and that is a epson. ST
On Mon, 24 Apr 2006 16:43:46 +0200, Steve <alienrelics@...> wrote: > You are either seeing a kit with pigmented black and dye colors, or > > confusing "archival" with pigmented. Archival is used as a marketing > > term and has no real meaning. > > > However, there is that pigmented black in the Lexmark and HP > > printers... perhaps that is worth testing. > > > Also, some HP printers use the same print heads only with different > > inks for the color heads. Those might be a candidate for loading all > > with HP pigmented inks. > > > Argh, I wish I had time for testing! I have some HP printers here with > > OEM ink, and a Novajet III (needs a belt) with all four colors > > pigmented (it uses the HP 44 print head for all four colors). > > > Steve Greenfield
