Doepfer
Re: [Doepfer_a100] Re: more info on the a154 seq cont. and release dates for ...
2002-11-29 by davevosh@aol.com
In a message dated 11/28/2002 7:47:51 PM Eastern Standard Time,
synth_freak_2000@yahoo.com writes:
> a154
> control section be able to reach audio freqs!!!a
> graphic vco(a155) with random running mode or vc
> addressable steps would be awesome
balis,
i think that the added features of the a-154 would certainly expand the
possibilities of using the sequencer as a "grahic vco", my experiments in
this area ( both with a previously owned serge tkb and the a-155 ) have led
me to feel that the "graphic vco" idea has merit for control waveforms but
when reaching audio frq`s, there isn`t enough variation to merit the extra
effort - the standard waveform choices provide a reasonable spread of
harmonic series for "day to day" use and the addition of things like linear
fm and various waveshapers ( doepfer a-136 is nice, i can also recommend the
blacet/wiard  mini-wave ) provide enough extra waveform variety with less
effort and less expensive circuitry. better, IMHO, to make it the "best"
sequencer it can be and if audio use is limited, so be it.
not to have you think i`m a complete reactionary, i think that there is good
work to be done in the complex vco area and i`m waiing for someone to have
the vision to extend their linear fm vco to  thru zero operation which is a
definite improvement over regular ( ala a-111 ) fm, just as one simple
example.
best,
dave
2002-12-02 by Joe Buechler
> the possibilities of using the sequencer as a "grahic vco", my
> experiments in this area ( both with a previously owned serge tkb
> waveforms but
> extra
> of
> linear
> recommend the
> less
I dunno, you've probably played with this concept much more than I
have. I currently have a bank of Regelwerk faders patched to the A155
via the A191 so it can be used as a true graphic VCO, and biased the
pre-out jack with a negative voltage. I can get quite dramatic changes
in the harmonic content by adjusting the faders in real time, and
I can also record the waveshaping session on a midi sequencer.
It's possible that I could do something very similar with the
distortion/waveshaper, but it doesn't seem like there would be
anywhere near as much control.
In any case, it's a lot of fun.
Joe
2002-12-02 by bakis Sirros
hi joe,
and why do you need to add a negative voltage to the
pre out of the a155?i thought that ,in order to use
the a155 as a graphic vco, all you had to do is pass
it thru a filter module to transform its voltage
output to AC.
bakis.
> certainly expand
> "grahic vco", my
> owned serge tkb
> for control
> > waveforms but
> > extra
> reasonable spread
> > of
> > linear
> nice, i can also
> > recommend the
> > less
> much more than I
> patched to the A155
> VCO, and biased the
> real time, and
> sequencer.
> with the
> there would be
> Joe
synthfreak(parallel worlds)
athens-greece
[Doepfer_a100] group owner-moderator
2002-12-04 by Joe Buechler
Hi bakis
You're right about that. It works without the negative voltage. Just
being anal, I guess.
Joe
--- In Doepfer_a100@y..., bakis Sirros <synth_freak_2000@y...> wrote:
> hi joe,
> output to AC.
> bakis.
> > certainly expand
> > "grahic vco", my
> > owned serge tkb
> > for control
> > > waveforms but
> > > extra
> > reasonable spread
> > > of
> > > linear
> > nice, i can also
> > > recommend the
> > > less
> > much more than I
> > patched to the A155
> > VCO, and biased the
> > real time, and
> > sequencer.
> > with the
> > there would be
> > Joe
> athens-greece
