> On 13 Jul 2015, at 13:33, Zubo Karijes zubo.karijes@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
> Hi Neil,
> Thanks for your reply. I am not having issues with the cock noise but the feedback which seems to have a problem. I am not comparing it to 188-1 but to a few videos that I saw about 188-2. In fact, single stage outputs don't yield a clean sound either…. I guess I should send it back...
> Much Appreciated
> Zlatko
> On Sunday, July 12, 2015 9:43 PM, "Neil Kagan blinkenlicht@yahoo.com [Doepfer_a100]" <Doepfer_a100@yahoogroups.com> wrote:
> The output switch is identified on the website as an error. The 188-2 outputs always have some clock noise apparent; again this is flagged up on the website. Also check you have the attenuators set to the centre as they are polarisers.
> The 188-1 is cleaner if that's what you are after but you have less options!!
> Neil
> Sent from my iPhone
>> On 12 Jul 2015, at 20:00, Zubo Karijes zubo.karijes@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
>> Hi All,
>> I bought a new 188-2 and have the following issues: The output channels are swapped - the top row of dials affects the second channel…+ much worse, the output always seems to have some feedback going on even if the dial is at zero, I cannot get a clean response demonstrated in some Youtube videos…. Any ideas? Docs about the trim settings?
>> Cheers
>> Zlatko
