Doepfer
Re: AW: [Doepfer_a100] Broken A-124
2014-04-15 by steve mantz
I'd be interested to find out what the issue is myself here. Mine (bought s/h) has exactly the same issue. Did post about this ages ago but haven't been using the modular much.
My Wasp was working fine, had it out of the case for a while and on putting it back in got exactly those symptoms. I've tried swapping the CD4069, the CA3080 and even the 5532 with no change at all. Examining the board shows no obvious shorts / damage / solder bridges or dry joints.
Steve
Re: [Doepfer_a100] Broken A-124
2014-04-15 by Florian Anwander
Unfortunately the Service Manual for the WASP does not contain the exact
IC type. But there exist buffered and unbuffered versions: CD4069BE is
the buffered CD4069UB or CD4069UBE is the unbuffered one. Maybe the
original circuit requires the unbuffered ones, whil you usually will get
the buffered ICs if you order a CD4096 at the usual shops.
Am 15.04.2014 11:16, schrieb steve mantz:
> Steve
