Doepfer
DIY Kit #1 power question
2012-06-05 by Sander Schuurman
I've assembled the Doepfer A-100 DIY Kit #1 in a wooden Ikea Rast cabinet.
When connecting the Transformer to the power supply board a question came into my mind.
In the instructions it says for the ground connection -> "housing (only if a metal case is used)".
I'm having a wooden cabinet, but inside I'm not using the doepfer rails, but a 19" rackmount rail, and it has quit a bit of aluminum.
Do I need to connect the ground to that then?
Or if not, where should I connect the ground to� Or nowhere at all?
thnx,
Sander Schuurman
sander@sentoplene.com
@sentoplene
Re: [Doepfer_a100] DIY Kit #1 power question
2012-06-05 by achtung_999
Personally I'd say it won't hurt to ground those rails...
But let's see what Dieter has to say.
On Tue, Jun 5, 2012 at 6:19 PM, Sander Schuurman <sander@sentoplene.com> wrote:
> Hi,
> Or if not, where should I connect the ground to… Or nowhere at all?
> thnx,
> Sander Schuurman
> @sentoplene
AW: [Doepfer_a100] DIY Kit #1 power question
2012-06-06 by yahoo@doepfer.de
Right. It's OK to GND the metal parts of the case.
Best wishes
Dieter Doepfer
> -----Ursprüngliche Nachricht-----
> Von: Doepfer_a100@yahoogroups.com
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von achtung_999
> Gesendet: Dienstag, 5. Juni 2012 19:21
> An: Doepfer_a100@yahoogroups.com
> Betreff: Re: [Doepfer_a100] DIY Kit #1 power question
> > Hi,
> Rast cabinet.
> aluminum.
> > thnx,
> > Sander Schuurman
> > @sentoplene
> > Yahoo! Groups Links
