Doepfer
Two inputs mixer ?
Two inputs mixer ?
2012-06-10 by Pierre
Dear Dieter Doepfer,
I'm facing many situations were it could be useful to have a simple mixer with only two inputs. Dry/wet mix, adding another CV to a VCA or a VCF, mixing only two VCO ...
A dual module with a layout similar to the A-133 or A-132-3 would be so cool.
A lin/exp switch and another one for bipolar operation ?
Some alternate behaviour to scale (offset, reverse) a signal when there's only one input in use ?
Cheers,
Pierre
Re: Two inputs mixer ?
Hi Ernst,
Didn't try it yet.
And you're right : that covers the functions of a two input mixer, and much more.
But for my needs, that's the same 8HP as a A-138. Actually, a A-134-2 with knobs would be great !-)))
Perhaps that's what I'll purchase in  the end : an A-134-2 with an A_176 CV source.
Pierre
--- In Doepfer_a100@yahoogroups.com, achtung_999 <heinrich.himmelwasser@...> wrote:
> Hi Pierre,
> Have you tried the A134? I use that module in the crossfade mode for some
> of the things you mention.
> Ernst
> Op 10 jun. 2012 16:19 schreef "Pierre" <pfichoux@...> het volgende:
Re: [Doepfer_a100] Two inputs mixer ?
2012-06-10 by achtung_999
Hi Pierre,
Ernst
Op 10 jun. 2012 16:19 schreef "Pierre" <pfichoux@yahoo.com> het volgende:
> cool.
> Cheers,
> Pierre
