Re: [Doepfer_a100] Re: Damaged A-143-1 Env/LFO Generator
2010-10-31 by James Husted
On Oct 31, 2010, at 2:55 PM, Bakis Sirros wrote: > then maybe somehow channel 4 does not receive power? > I was thinking that also. I don't have mine with me now but IIRC there is a ribbon cable running between the separate channel PCBs - you can try dis-connecting the ribbon an connecting one of the ends from a working channel to the channel 4 board alone. If it fire up it may be a faulty ribbon connector which if there is enough slack you may be able to take apart and re-swage the connector next to where it was on a unused part of the ribbon. -James [Non-text portions of this message have been removed]
