Doepfer
Damaged A-143-1 Env/LFO Generator
2010-10-31 by jonathan.heslop
Having recently acquired a damaged A-136, I have now ended up with a damaged A-143-1. At least the Waveshaper was sold as damaged, the A-143-1 was sold as new :(
Channel's 1, 2 and 3 seem fine. Neither of the two LED's on channel 4 light up and the output's seem to do nothing. I noticed on the back of the module channel 4 is the first channel to receive power from the bus. I guess this could be a case of the module's power having been plugged in upside down. The waveshaper had the same problem and replacing the two amp's fixed it. There was visible burn markings on the solder of the waveshaper, channel 4 on the A-143-1 looks fine, I can't viably see anything wrong with it, channel 4 looks identical to 1, 2 and 3. I guess replacing the four chips (Amps?) on the PCB would be the first thing to try?
Thanks for any help,
Jonathan
Re: Damaged A-143-1 Env/LFO Generator
"on channel 4 light up and the output's seem to do nothing" I guess that's not quite true:
http://soundcloud.com/user8805415/a-143-1-test
In the above test: A-110 Saw -> VCA -> Record. A-143-1 ENV out (all four in turn) -> A-110 CV1 input.
Jonathan
--- In Doepfer_a100@yahoogroups.com, "jonathan.heslop" <jonathan.heslop@...> wrote:
> Jonathan
Re: [Doepfer_a100] Damaged A-143-1 Env/LFO Generator
2010-10-31 by Guy Drieghe D.
Jonathan,
I don't have access to any of the modules you're referring too,
but in general -- assuming they've been powered backwards,
the first things to go are the electrolytic (or tantalum) caps
near the power connector. Burn markings are most likely
coming from those caps which "crossed over to the dark side".
Replace these first, then work your way down to any other
possible tantalum caps, the IC's, then the transistors...
though there is no definite way of components knowing
which components die first.
YMMV.
_g
> Jonathan
2010-10-31 by Florian Anwander
Hi Guy
Doepfer uses 25V caps ... it doubt they would be destroyed by wrong
polarization.
Florian
Now why didn't I think of that :) I tried swapping all 4 chips from channel 3, No joy though.
I'm guessing channel 3 and 4 chips are identical?!?
Jonathan
--- In Doepfer_a100@yahoogroups.com, Florian Anwander <fanwander@...> wrote:
> Hello
> if the chips are socketed, try swapping the chips of pcb 4 with other
> pcbs. I suspect 555 to be dead. TL082 usually survive wrong powersupply
> at 12V.
> Florian
2010-10-31 by Tony Rolando
On 10/31/10 2:32 PM, Florian Anwander wrote:
> Hi Guy
I second other recommendations to swap those IC, esp. if socketed, it is
really easy and fast. 25V cap would not likely be destroyed by reverse
power.
Tony
> > Hi Guy
I agree that electrolytes don't blow as fast as tantalums.
The latter ones I've seen blowing skyhigh with reversed power.
Still, if there's burn markings, chances are it's from a cap.
Personally I use 35V or 50V electro's on a -/+12V rail.
25V is a bit too close for comfort for me.
My rule of thumb is twice the rail plus 2 or 3V minimum.
To be on the safe side, I'd prefer checking the area around
the power connector first, before starting to swap IC's at random.
Or at least, remove the IC's from their sockets, and measure
the power pins of those first.
_g
> power.
> Tony
Re: [Doepfer_a100] Re: Damaged A-143-1 Env/LFO Generator
2010-10-31 by Bakis Sirros
then maybe somehow channel 4 does not receive power?
Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist
[Doepfer_a100] group owner
www. parallel - worlds - music. com
www. myspace. com/ parallelworldsmusic
www. myspace. com/ interconnectedmusic
www. myspace. com/ memorygeist
www. DiN. org. uk
www. musicamaximamagnetica. com
www. vu-us. com
--- On Sun, 10/31/10, jonathan.heslop <jonathan.heslop@yahoo.co.uk> wrote:
From: jonathan.heslop <jonathan.heslop@yahoo.co.uk>
Subject: [Doepfer_a100] Re: Damaged A-143-1 Env/LFO Generator
To: Doepfer_a100@yahoogroups.com
Date: Sunday, October 31, 2010, 11:47 PM
Jonathan
> Hello
> at 12V.
> Florian
