> > Hi all/Dieter
> > I have a module that puts out voltages in the range 0 to +4V. I
> > would like to offset and amplify this voltage range to -4 to +4V
> > (that is amplify x2 and offset by -4V).
> > Is this the right module to do this job?
> > Thanks
> > Richard
> Yes, but you have to change the position of the JP3 jumper. The factory
> setting is 0...+5V offset (upper position of the jumper). You have to change
> it to the lower position (-5V...+5V offset).
> Best wishes
> Dieter Doepfer
