Doepfer
A-108 opinions?
A-108 opinions?
2008-09-22 by pmclean_80207
Folks,
I'm thinking about adding a filter to my A-100.  I have an A-122, and A-
121 and A-123 all of which I like, but I find myself looking for a
filter with a more Moog-like sound.  I like the flexibility of the A-
108.  Any opinions about it's sound and how it compares to the A-120?
Re: A-108 opinions?
2008-09-22 by thomasborax
agreed with others regarding the a108.  interestingly, my music is
primarily "out" or experimental, yet the "noisy" or "wierd" filters
such as 106 and wasp do not get plugged in as much as the more
straightforward 108.
honestly, i can hardly imagine a more beautiful sounding filter.
it's flexible, huge sounding, and it can get totally wacked out and
crazy if you patch inthe feedback loop.
-t
--- In Doepfer_a100@yahoogroups.com, "pmclean_80207"
<pmclean_80207@...> wrote:
> Folks,
and A-
A-
120?
> Thanks
Re: [Doepfer_a100] A-108 opinions?
2008-09-22 by Bakis Sirros
i think the A108 is a great and warm filter that is closer to moog sound than the other doepfer filters. its one of my favourite A100 filters.
Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist
[Doepfer_a100] group owner
www. parallel - worlds - music. com
www. myspace. com/ parallelworldsmusic
www. myspace. com/ interconnectedmusic
www. myspace. com/ memorygeist
www. DiN. org. uk
www. musicamaximamagnetica. com
www. shimarecords. co. uk
www. rubberrecords. gr
Athens - Greece
--- On Mon, 9/22/08, pmclean_80207 <pmclean_80207@yahoo.com> wrote:
Subject: [Doepfer_a100] A-108 opinions?
To: Doepfer_a100@yahoogroups.com
Date: Monday, September 22, 2008, 6:13 PM
Folks,
2008-09-22 by achtung_999
The A108 is really good!It's my favourite next to the A102 and the Wasp
filter.
I also own the A123 and the A121 and A122. And some more :-)
I just sold my A120 which was okay.. but I definately prefer the A108
because it is more versatile.
It can sound like the A120 if you take the controls down a bit. The beauty
is that it can also go a bit more dirty.
I tried the A120 next to the A108 and it is definatly possible to make them
sound the same.
The beauty is I think in the 6db/oct output and the 48db/oct output.
Nice bonus is the bandpass.
I can't recommend the a108 more..
Greetings.
ernst
On Mon, Sep 22, 2008 at 6:10 PM, Bakis Sirros <synth_freak_2000@yahoo.com>wrote:
> www. DiN. org. uk
> Athens - Greece
> --- On Mon, 9/22/08, pmclean_80207 <pmclean_80207@yahoo.com<pmclean_80207%40yahoo.com>>
> wrote:
> From: pmclean_80207 <pmclean_80207@yahoo.com <pmclean_80207%40yahoo.com>>
> To: Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com>
> Folks,
> Thanks
Re: [Doepfer_a100] Re: A-108 opinions?
Totally agree with that.My music is very 'out there' and the A106 has never
featured much in my tracks.
It's mainly the a108 and the a102. Okay okay and the Wasp ;-)
Ernst
> -t
> --- In Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com>,
> "pmclean_80207"
> > Folks,
> and A-
> A-
> 120?
> > Thanks
Re: A-108 opinions?
2010-03-26 by jalmari3
I have a question regarding A-108 pots.
My A-108 audio input is very sensitive to distortion. Often I set the Audio Level knob below 9 o'clock and then dialing the "right" sound is difficult. The pot is A50K, which I assume means the attenuation is already non-linear. Is there a way to improve "resolution" at the low end without sacrificing range? In other words, I would like less sensitivity at near counter clockwise position.
The other pots are B50K (linear?). If I swap all except Frequency pot to A50K, do I get less sensitivity at near counter clockwise position wihtout loss of range here too? Attenuating would then work like with Cwejman modules, which I prefer?
2010-03-26 by Florian Anwander
Hi Jari
replacing the potentiometer doesn't change anything. I don't have the
schematics of the A108 here, but there is usually an input opamp, which
has assumingly a too high amplification due to a defective or wrong
feedback resistor. For dedicated error tracing some measuring equipment
(oscilloscope, ohmmeter) and mesauring know how is needed.
I am sure Dieter will jump in soon.
Florian
2010-03-26 by Bakis Sirros
i also put my A108 audio input (of all 3 A108's of mine) to around 9 o'clock for non-distorted input.
so, i think this behavior of the A108 is normal and not defective.
www. DiN. org. uk
www. vu-us. com
--- On Fri, 3/26/10, Florian Anwander <fanwander@mnet-online.de> wrote:
Subject: Re: [Doepfer_a100] Re: A-108 opinions?
Date: Friday, March 26, 2010, 10:48 AM
      Hi Jari
Florian
2010-03-26 by achtung_999
Same here..
On Fri, Mar 26, 2010 at 11:53 AM, Bakis Sirros
> www. DiN. org. uk
> www. vu-us. com
> --- On Fri, 3/26/10, Florian Anwander <fanwander@mnet-online.de<fanwander%40mnet-online.de>>
> wrote:
> From: Florian Anwander <fanwander@mnet-online.de<fanwander%40mnet-online.de>
> Hi Jari
> Florian
Hi
> Same here..
If Dieter won't have the time to answer today, I'll have a look at the
schematics at home.
Basically I think it should be not normal that the signal already
distorts over 9 o'clock position. At the most gear I own the 3 o'clock
position is where an input level is set to 100%. I'd also understand
below 12 o'clock damping, above amplification, but 9 o'clock position is
too low.
Maybe it is a designflaw which has never been detected, because they
test only with monophonic saw or - even more undetectable - with rectangle.
Florian
i do not think its a design flow...(Dieter?)
after 9 o'clock (and in combi with the resonance knob) is where all the fun starts....     :-)
www. DiN. org. uk
www. vu-us. com
> From: Florian Anwander <fanwander@mnet-online.de>
> Date: Friday, March 26, 2010, 1:42 PM
> Hi
> > Same here..
> mine) to around 9
> and not defective.
> look at the
> schematics at home.
> already
> the 3 o'clock
> understand
> o'clock position is
> too low.
> because they
> with rectangle.
> Florian
>     Doepfer_a100-fullfeatured@yahoogroups.com
AW: [Doepfer_a100] Re: A-108 opinions?
2010-03-27 by yahoo@doepfer.de
I was not in the company yesterday as I had to attend a boring "safety at work" seminar because of the German law (unfortunately only ~5% of my time I'm able to do what I like most: design of new modules/units or playing with them).
The audio input of the A-108 is very sensitive (much more than e.g. the A-120). Many users recommended to have more sensitive inputs for clipping/distortion available. If the audio input resistor R1 (standard value 10k) is replaced e.g. by 47k or 100k the input becomes 5/10 times less sensitive.
Best wishes
Dieter Doepfer
P.S.
These are the law codes for the potentiometers used in the A-100:
A = log
B = linear
C = inverse log.
