Regarding paper thickness
2006-03-15 by deandadin
I am looking to find out what the GSM thickness rating is. How does the GSM rating compare to mm thickness. For example, how many mm is a paper with a GSM of 255? How many GSM is a paper that is 1.3 mm? I am also interested in finding out the maximum thickness of papre an Epson 2200 will handle. Thanks a lot and I appreciate any response. Steve
2006-03-15 by Andrew Rodger
Steve, I am no expert but I think the equation relies on a third component: density Different papers have differing density. I expect you could obtain this information from the relevant manufacturer if you state the types of paper you would be using. Drew
On 15 Mar 2006, at 05:10, deandadin wrote: > I am looking to find out what the GSM thickness rating is. How does > the GSM rating compare to mm thickness. For example, how many mm is a > paper with a GSM of 255? How many GSM is a paper that is 1.3 mm? I am > also interested in finding out the maximum thickness of papre an Epson > 2200 will handle. Thanks a lot and I appreciate any response. Steve
2006-03-15 by alanrew42
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "deandadin" <deandadin@...> wrote: > > I am looking to find out what the GSM thickness rating is. How does > the GSM rating compare to mm thickness. For example, how many mm is a > paper with a GSM of 255? How many GSM is a paper that is 1.3 mm? I am > also interested in finding out the maximum thickness of papre an Epson > 2200 will handle. Thanks a lot and I appreciate any response. Steve > The answer to both of your questions depends on the density of the paper material. A dense paper which is 0.5mm thick may be heavier (in GSM, grams per square metre) than a less dense paper 0.6mm thick. In addition to this, an inkjet paper will in general be made up of several layers of different materials with different densities and thicknesses. So a thicker version of the same paper may simply have one of the layers thicker but the other layers the same thickness. In this case the weight would not be directly proportional to the thickness but be something like (a + bx) where a and b are constants and x is thickness. In terms of the Epson 2200, I believe the manual tells you somewhere what thicknesses are possible, and what the criteria are for using the paper thickness lever and/or the rear feed slot. I've also found that paper _stiffness_ is an issue when using the normal paper feed path on the 2100/2200: if the paper is hard to bend, the take-up rollers can slip on the paper & leave skid marks while trying to drag the paper through the normal (bent) path. Regards, Alan
2006-03-15 by Diana York~Hawk Mtn Papers
GSM is a measure of density - grams per square meter. Paper of the same thickness can have different density depending on the fiber composition and sheet formation. An alpha cellulose (wood based) sheet will usually have a higher GSM per mil (1/1000 inch) caliper than a cotton based paper. For example: our Grayhawk (high alpha cellulose) paper is 12 mil caliper and 235 GSM. Our Merlin (100% cotton) paper is 15 mil and 255 GSM and our Condor (100% cotton) paper is 20 mil and 325 GSM while our Kestrel (100% cotton heavily textured) paper is 25 mil and 325 GSM. Kestrel is manufactured on an entirely different paper machine with a different fiber length and composition than Merlin and Condor. Clear as mud -right <G>! Diana York mailto:diana@... Hawk Mtn Papers www.hawkmtnartpapers.com 888-807-2248
-----Original Message----- From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of deandadin Sent: Wednesday, March 15, 2006 12:10 AM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] Regarding paper thickness I am looking to find out what the GSM thickness rating is. How does the GSM rating compare to mm thickness. For example, how many mm is a paper with a GSM of 255? How many GSM is a paper that is 1.3 mm? I am also interested in finding out the maximum thickness of paper an Epson 2200 will handle. Thanks a lot and I appreciate any response. Steve
2006-03-15 by Jim Doyle
Thanks Diana, for Sharing that..you just saved me from writing a lengthly email.. You couldnt have said it any better.. Cheers Jim Doyle J. Doyle Enterprises LLC 114 Old Orchard Rd Cherry Hill, NJ 08003 856-424-8660 http://www.shadesofpaper.com AOL IM: Brokerup99
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of Diana
Sent: Wednesday, March 15, 2006 7:37 AM
Subject: RE: [Digital BW] Regarding paper thickness
sheet
based paper.
and
Condor
an
888-807-2248
deandadin
Please visit the Group Homepage to check the Files, and other resources as
they are often being updated.
If you wish to receive no emails or just a daily digest, or you wish to
unsubscribe, please edit your Membership preferences by visiting this same
page.
Please follow these basic guidelines:
- As threads develop, trim off excess portions of earlier messages to keep
them short.
- Good manners are required at all time. No personal attacks or flames.
Hostile, aggressive or argumentative users may be removed from the
membership without notice.
- Keep your posts and threads related to the group topic of digital B&W
printing. Users who persistently make off-topic posts may be removed from
the membership.
- By posting on this forum you agree to abide by the group rules and
guidelines, and to abide by the actions and decisions of the group Owner and
Moderators. See Group Topic, Rules and Guidelines in the Files section:
http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT
YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND
MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS,
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE OWNER AND
MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY
TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR
ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY
THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER
MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
SPONSORED LINKS Digital wedding photography Learn digital photography
Digital photography college
Digital photography Digital photography web site Digital
photography course
YAHOO! GROUPS LINKS
a.. Visit your group "DigitalBlackandWhiteThePrint" on the web.
b.. To unsubscribe from this group, send an email to:
DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
Checked by AVG Free Edition.
Version: 7.1.385 / Virus Database: 268.2.2/280 - Release Date: 3/13/2006
[Non-text portions of this message have been removed]2006-03-15 by djon43
> On 15 Mar 2006, at 05:10, deandadin wrote: how many mm is a > > paper with a GSM of 255? How many GSM is a paper that is 1.3 mm? I am > maximum thickness of papre an Epson > > 2200 will handle. GSM isn't thickness, it's weight... though thicker papers usually are higher GSM. I use 300 GSM Moab Entrada sometimes, 205 GSM Moab Kayenta a lot (instead of Epson Enhanced Matte). Neither feeds fully properly through the top but both are trouble-free through the back. The 300 can be MADE to work from the top by bending it, breaking its spine, but it's easier simply to feed from the back. The 205 feeds fairly reliably as single sheets from the top, but I want 100% reliability so I feed it from the back as well. It'd be nice if we could use the top feeder with every sort of paper, irrespective GSM and thickness, saving desktop space...but that's not the way the 2200 was designed. For stacking paper in the top feeder, paper surface friction also becomes a challenge, in addition to issues of GSM and thickness...
2006-03-16 by deandadin@aol.com
Hello Diana, I am trying to send you mail and I can't get the mail out to you. I am interested in finding out about your papers. Is there another address to E mail you. Thanks Steve [Non-text portions of this message have been removed]
2006-03-16 by alanrew42
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Diana York~Hawk Mtn Papers" <diana@...> wrote: <snip> > For example: our Grayhawk (high alpha cellulose) paper is 12 mil caliper and > 235 GSM. Our Merlin (100% cotton) paper is 15 mil and 255 GSM and our Condor > (100% cotton) paper is 20 mil and 325 GSM while our Kestrel (100% cotton > heavily textured) paper is 25 mil and 325 GSM. Kestrel is manufactured on an > entirely different paper machine with a different fiber length and > composition than Merlin and Condor. > Clear as mud -right <G>! > > Diana York mailto:diana@... > Hawk Mtn Papers www.hawkmtnartpapers.com > 888-807-2248 Further to Diana's detailed info, there is some more data about paper weights and thicknesses on Keith Cooper's excellent web site: http://www.northlight-images.co.uk/article_pages/imageprint_media_settings.html HTH Alan
2006-03-17 by Diana York~Hawk Mtn Papers
Thank you for posting that informative link! I have printed the charts and added to my paper info file for future reference. If you really want to get confused, add basis weight into the mix - I had a lengthy phone conversation with someone yesterday regarding that subject as they were trying to equate papers to offset print paper values of pounds. But you need to know which reference basis weight you are speaking of, and there are a few. Thanks again! Diana York ~ Hawk Mountain Papers Professional Inkjet Photo & Fine Art Papers toll free 888-807-2248 www.hawkmtnartpapers.com <http://www.hawkmtnartpapers.com>
-----Original Message----- From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of alanrew42 Sent: Thursday, March 16, 2006 8:13 AM Further to Diana's detailed info, there is some more data about paper weights and thicknesses on Keith Cooper's excellent web site: http://www.northlight-images.co.uk/article_pages/imageprint_media_settings.h tml HTH Alan
2006-03-17 by alanrew42
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Diana York~Hawk Mtn Papers" <diana@...> wrote: > > Thank you for posting that informative link! I have printed the charts and > added to my paper info file for future reference. > If you really want to get confused, add basis weight into the mix - I had a > lengthy phone conversation with someone yesterday regarding that subject as > they were trying to equate papers to offset print paper values of pounds. > But you need to know which reference basis weight you are speaking of, and > there are a few. > Thanks again! > > Diana York ~ Hawk Mountain Papers > Professional Inkjet Photo & Fine Art Papers > toll free 888-807-2248 > www.hawkmtnartpapers.com <http://www.hawkmtnartpapers.com> There's a good link for explaining the metric paper size system (A3, A4 etc) here http://www.cl.cam.ac.uk/~mgk25/iso-paper.html This covers A, B and C series paper sizes as well as envelope sizes, the history of the ISO system and some 'Hints for North American paper users'. Regards, Alan
