Digital BW, The Print
what type of calibration system
RE: [Digital BW] what type of calibration system
2006-03-04 by Paul Roark
> What type of calibration system is recommended for b&w work?
Most will say that a well-profiled monitor, using Spyder2Pro (which I have)
or equivalent is required.  I found that for B&W the Adobe Gamma, done
carefully, did a good job if grayscale is all one is judging.
Paul
www.PaulRoark.com
Re: [Digital BW] what type of calibration system
2006-03-04 by CDTobie@aol.com
In a message dated 3/3/06 11:22:40 PM, paul.roark@... writes:
For black and white visual monitor calibrators are... more acceptable? less
unacceptable? something like that... than for color work. But this is still
predicated on using a CRT. You need to effectively set you blackpoint to avoid
clipping blacks, set your whitepoint to avoid blowing out whites, and define a
detailed gamma correction (which is why it was called Adobe Gamma in the first
place). Adobe doesn't even recommend Adobe Gamma for LCDs, since they don't
start with a smooth, gamma shaped response curve, that can be nudged to the
preferreed gamma with a single point, visual correction. Instead they look rather
like stock market graphs, and require a point-by-point correction curve to
balance that out. So seeing a good representation of your nice smooth,
curve-corrected black and white printer output requires nice, smooth, curve corrected
monitor output... which is not something you are going to get on an LCD without,
as Paul puts it, a Spyder or equivalent.
C. David Tobie
Product Technology Manager
ColorVision, Inc.
CDTobie@...
www.colorvision.com
2006-03-04 by mxgo95747
I have a Sypder2 for calibrating my Apple LCD, I then print an image on my Epson 2400
with an ABW setting of normal (or dark) and change, by eyeball, my "color settings" custom
dot gain curve to match the LCD 21 step curve image.  I always seem to be off just slightly
on the range from about 80 to 100% settings.
Now, what will the Spyder2Pro unit do, from what I stated above, for me?  If the
Spyder2Pro unit gets me closer to "what you see, is what you get" status, is there an
upgrade for my Spyder2 unit to the Sypder2Pro calibration status?
Martin
In a message dated 3/4/06 2:03:45 PM, mxgo95747@... writes:
> Epson 2400
> settings" custom
> off just slightly
> the
> there an
Certainly Spyder2PRO would allow you to choose a custom gamma, or even tweak
your response curve to a "non-gamma" shape, which seems to be what you are
descibing above. Personally, I prefer to make my corrections at the other
(printer profile) end, so using a color managed B&W system, or using Roy Harrington's
black and white preview profile tool with your current printing method, would
be the choices I would prefer; but now we've gone from upgrading your Spyder
software to upgrading to the PrintFIX PRO Suite with Spyder2PRO, to build
those curves... so I'm getting you in deeper and deeper.
C. David Tobie
ColorVision, Inc.
CDTobie@...
www.colorvision.com
> I then print an image on my Epson 2400 with an ABW ...
The Epson "Advanced B&W" is not a color managed system.
> ... and change, by eyeball, my "color settings" custom
This is the step we're trying to get away from by using the color managed
("CM") workflows.  A perfect custom dot gain curve can be very good, but
most of us would rather not have to do this.
I've never seen a perfect system, but the CM approaches are better than my
custom curves.
Paul
www.PaulRoark.com
2006-03-05 by lou4photo
"I've never seen a perfect system, but the CM approaches are better
than my
custom curves."
Just to add a note to Paul's point, I had my 4800 color profile made
for me by Ethan Hanson at Dry Creek. In addition to the beautiful color
profile he created (including a nice gamut chart of your paper/printer)
for Ilford Sm Pearl, he gave me a group of B&W profiles to try drawn
from the same data set. These profiles covered Neutral, Platinum,
Selenium, Cool tone, Sepia and Brown tone. All I can say is WOW! Dead
on WYSIWYG and the various tones are STUNNING! The Platinum tone is
especially delicate and beautiful. I know some will always want to
fiddle with in between values in ABW, but for me this is printing
Nirvana.
Lou Meluso
2006-03-06 by Howard Rodkin
I'm pretty confused by the range of Colorvision products and I'm not
even sure how to ask the question.
 I'm a serious, but not professional photographer, who both scans slides
and negatives and shoots digitally. I have a 19' Dell flatbed monitor,
and an Epson 2400 printer. By following the Epson manual my prints are
close, but only close, and the monitor and especially the print with
preview are not. How close will the Spyder2 Suite get me to seriously
managing my color through to the final print? I guess the question is
what can I expect from each of the products?
Howard
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of
CDTobie@...
Sent: Saturday, March 04, 2006 2:16 PM
Subject: Re: [Digital BW] what type of calibration system
on my
> Epson 2400
"color
> settings" custom
be
> off just slightly
me?  If
> the
status, is
> there an
tweak
are
other
Harrington's
would
Spyder
build
C. David Tobie
ColorVision, Inc.
CDTobie@...
www.colorvision.com
Please visit the Group Homepage to check the Files, and other resources
as they are often being updated.
If you wish to receive no emails or just a daily digest, or you wish to
unsubscribe, please edit your Membership preferences by visiting this
same page.
Please follow these basic guidelines:
- As threads develop, trim off excess portions of earlier messages to
keep them short.
- Good manners are required at all time. No personal attacks or flames.
Hostile, aggressive or argumentative users may be removed from the
membership without notice.
- Keep your posts and threads related to the group topic of digital B&W
printing. Users who persistently make off-topic posts may be removed
from the membership.
- By posting on this forum you agree to abide by the group rules and
guidelines, and to abide by the actions and decisions of the group Owner
and Moderators. See "Group Topic, Rules and Guidelines" in the Files
section:
http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT
YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
"MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
"OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE
OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA;
(iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE
PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW,
THE PRINT YAHOO GROUP.
SPONSORED LINKS
Digital
<http://groups.yahoo.com/gads?t=ms&k=Digital+wedding+photography&w1=Digi
tal+wedding+photography&w2=Learn+digital+photography&w3=Digital+photogra
phy+college&w4=Digital+photography&w5=Digital+photography+web+site&w6=Di
gital+photography+course&c=6&s=188&.sig=Umur-3rsLOic7dZMwVL94w>  wedding
photography
Learn
<http://groups.yahoo.com/gads?t=ms&k=Learn+digital+photography&w1=Digita
l+wedding+photography&w2=Learn+digital+photography&w3=Digital+photograph
y+college&w4=Digital+photography&w5=Digital+photography+web+site&w6=Digi
tal+photography+course&c=6&s=188&.sig=emApqtvj0kHQhppIzRrNgw>  digital
photography
Digital
<http://groups.yahoo.com/gads?t=ms&k=Digital+photography+college&w1=Digi
gital+photography+course&c=6&s=188&.sig=aIiABJLTZsUnmWBs4mZwuA>
photography college
Digital
<http://groups.yahoo.com/gads?t=ms&k=Digital+photography&w1=Digital+wedd
ing+photography&w2=Learn+digital+photography&w3=Digital+photography+coll
ege&w4=Digital+photography&w5=Digital+photography+web+site&w6=Digital+ph
otography+course&c=6&s=188&.sig=pJmwqgVzec3JGBtWYlPbOg>  photography
Digital
<http://groups.yahoo.com/gads?t=ms&k=Digital+photography+web+site&w1=Dig
ital+wedding+photography&w2=Learn+digital+photography&w3=Digital+photogr
aphy+college&w4=Digital+photography&w5=Digital+photography+web+site&w6=D
igital+photography+course&c=6&s=188&.sig=BMII8rtDZlAtVdZsPhaZqw>
photography web site
Digital
<http://groups.yahoo.com/gads?t=ms&k=Digital+photography+course&w1=Digit
al+wedding+photography&w2=Learn+digital+photography&w3=Digital+photograp
hy+college&w4=Digital+photography&w5=Digital+photography+web+site&w6=Dig
ital+photography+course&c=6&s=188&.sig=OrnrutXVhHZu-7E7ccLtuw>
photography course
  _____
YAHOO! GROUPS LINKS
*          Visit your group "DigitalBlackandWhiteThePrint
<http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint> " on the
web.
*          To unsubscribe from this group, send an email to:
 DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com
<mailto:DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com?subject
=Unsubscribe>
*          Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/>  Terms of Service.
  _____
2006-03-06 by CDTobie@aol.com
In a message dated 3/6/06 3:18:32 PM, hrodkin@... writes:
I'd go through them all, but its probably not necessary if we approach it
this way: If you want to control your prints, you want a spectro-based printer
profiler. For ColorVision that means PrintFIX PRO, and the bundle that adds
monitor calibration to that adds Spyder2PRO, the high end monitor calibrator, for
only around a hunderd bucks more, so thats the thing to get: PrintFIX PRO
Suite. If you are determined to work with your canned printer profiles instead of
custom profiling your printer, then you can decide if you want the extra
features of Spyder2PRO (projector calibration, multiple monitor matching, ambient
light correction) or if   you just want to calibrate you monitor to common
settings, in which case Spyder2 would be sufficient.
Oh, and since this is the B&W list, I'll mention that the PrintFIX PRO Suite
would be of use in tuning B&W print systems as well... <G>
C. David Tobie
ColorVision Business Unit
Datacolor Inc.
CDTobie@...
www.colorvision.com
Where do the Printfix Suite and the Spyder2 Suite fit into this mix. The
Printfix Suite also seems to have hardware for both printer and monitor
and the Spyder2 Suite comes with a software only printer management
system. Your response has helped me understand the two ends, but I'm
still a bit confused about the value of the solutions in the middle. I
want to get the job done, but money, of course is always a factor.
Thanks very much for you time and help.
Howard
CDTobie@...
Sent: Monday, March 06, 2006 3:41 PM
slides
it
printer
adds
calibrator, for
PRO
instead of
matching, ambient
common
Suite
C. David Tobie
Datacolor Inc.
CDTobie@...
www.colorvision.com
same page.
keep them short.
section:
SPONSORED LINKS
Digital
photography
Learn
photography
Digital
photography college
Digital
Digital
Digital
photography course
  _____
YAHOO! GROUPS LINKS
web.
=Unsubscribe>
  _____
In a message dated 3/6/06 5:00:35 PM, hrodkin@... writes:
I would not recommend PrintFIX (as opposed to PrintFIX PRO) at this time, as
it supports only specific printer models, and that list is getting older. Its
also not as accurate as PrintFIX PRO. The software in the Spyder2 Suite is a
software only version of PrintFIX PRO called PrintFIX PLUS, where there are
premeasured starting points for a range of printers that you can work from, to
tweak a profile for your particular printer, inks, and paper. There will be more
of these starting points on the ColorVison website later on. This may prove
to be a very good alternative for those who don't want to spring for the cost
of the spectro in PrintFIX PRO... its a new product, and there hasn't been much
chance for user feedback yet, so we'll have to wait to see what people think.
I suspect this solution will be preferable to previous generations of
software-only printer profilers, especially once the website kicks in with broader
starting points. I was certainly impressed with what I could get it to do.
More relevant to this list, PrintFIX PLUS may prove of interest for B&W work
as well, in the long run; since anyone with a copy of PrintFIX PRO will be
able to load measurement sets to the CV website, where PLUS users can access them
as starting points for their own profile building. This could be extended to
Curves building, B&W profile building, lots of interesting stuff.
C. David Tobie
Datacolor Inc.
CDTobie@...
www.colorvision.com
Thank you so much for the additional info. I now have a much clearer
understanding of all the options. It sounds like the Spyder2 Suite may
be a good solution for me right now. I'll definitely provide some
feedback once I get it up and going.
Thanks again,
Howard
CDTobie@...
Sent: Monday, March 06, 2006 6:19 PM
The
monitor
time, as
older. Its
is a
are
from, to
be more
prove
cost
been much
think.
with broader
do.
work
be
access them
extended to
C. David Tobie
Datacolor Inc.
CDTobie@...
www.colorvision.com
same page.
keep them short.
section:
SPONSORED LINKS
Digital
photography
Learn
photography
Digital
photography college
Digital
Digital
Digital
photography course
  _____
YAHOO! GROUPS LINKS
web.
=Unsubscribe>
  _____
Re: what type of calibration system
2006-03-07 by Hal Gage
On the topic....
I have been thinking about buying equipment/software to calibrate my
LCD monitor, digital projector, and Epson 2200/7600 prints. I teach
Photoshop in seminar form here in Anchorage, Alaska and would like to
offer the service of calibrating photographers monitors and printing
system (I am on a Mac but want to cover Mac and PC systems). Are
there restrictions in the license and/or hardware that would stop me
from doing this?
I have looked at the PrintfixPro Suite and found it on sale for $549
at Calibration-Direct http://www.calibration-direct.com/
prodprintfixsuitepro.html
Two questions:
1) Is this a good calibration system to get into or is there a better
choice?
2) Is there a better price I should look into for this system out there?
Hal Gage
(listserve lurker)
Wow, what a great reply. Thanks David. Adding in a $89 Spyder2express
to the deal sound very doable.
Although you said that this as the best choice under $1000, what
other choices would you recommend above the $1000 mark? And would I
really be gaining that much?
Thanks again,
Hal Gage
2006-03-08 by Greg
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Hal Gage
Xrite Pulse, Xrite Profiler (Gold or Platinum) with some kind of
measurement device, Gretag MacBeth i1 Photo, Gretag MacBeth Profile
Maker Pro and some kind of measuring device, Heidelberg Prinect
Profile Toolbox and some kind of device. There are a couple of others
that escape me at the moment. Take a trip to http://www.chromix.com
A pigment or dye question
2006-03-08 by Frank Vincent
Has anyone discussed this link on this forum before?
http://www.marrutt.com/digital-ink-myths-2.php
Frank Vincent
RE: [Digital BW] A pigment or dye question
2006-03-08 by Paul Roark
My tests and all I know indicate pigments are much better than dyes on the
types of media generally preferred on this forum.  The Iris images are not
renowned for their lightfastness -- rather the reverse from what I heard
from some serious galleries the last time I asked.
Dyes do best on special media with swellable coatings.  Even on these they
are not nearly as good as the carbon pigments used by most here on the rag
and glossy papers we use, according to my tests comparing them side by side.
So, I would take the implications of what the web page above says with a
grain of salt.
Paul
www.PaulRoark.com
Re: [Digital BW] A pigment or dye question
2006-03-08 by Larry Heath
Is there any doubt that the person writing the article above  would be saying what is said?
Tony Martin is President of Lyson USA.
A premier purveyor of dye based inks.
From Lyson's  US website as follows,
Independent testing carried out by Wilhelm Imaging Research, Inc. of Grinnell, Iowa has shown that a Lysonic ink set has an estimated life of 65-75 years on a pure cotton paper in average indoor display without noticeable fading*.
Notice what is said, specifically, "a pure cotton paper", I am not real sure just how many pure cotton papers I use. I have the feeling I would have to go a ways to find a pure cotton paper. I am under the impression that any number archival papers use cotton fiber as a base, but, are prepared in such manor as to provide buffers and other substances to enhance longevity and or surface texture and just how the paper absorbs the substances placed on the surface as well as how the substances are conveyed into the base of the paper or not.
Color gamut is a moot point in this forum, is it not?  i.e. "DigitalBlackandWhiteThePrint".  Will an apparent greater color gamut in a dye based ink set as opposed to a pigmented ink set produce a greater Dmax black or better highlights? Can't say for sure one way or another, but I am willing to guess that it will not. While I have produced some pleasing B&W prints using MIS pigmented color ink sets I am pretty sure that these prints will not last as long as a pigmented multi black ink set on a paper of known archival quality. On top of that, producing B&W using color inks, is not a point and shoot deal and they do or can have some characteristics that are not pleasing and are difficult to control.
Is pigmented digital B&W printing, using multi-level black ink sets the best that can be had in the digital realm, a myth? My opinion is that it is not. I am pretty sure that the right B&W ink set on a compatable paper can do a heck of a lot better than, 65 to 75 years. Check Wilhelm for specifics on pigmented B&W prints, and see what they have to say.
Larry Heath
2006-03-08 by Ernst Dinkla
> Larry Heath
Larry,
Wilhelm tested dye inks on pure cotton in the past. That is
paper without any inkjet coating like you would use in
intaglio printing etc. Arches for Iris, BFK Rives. This
testing was based on tests done for the Iris printer with dye
inks from several sources. Lyson made an ink like that
(Lysonic) and their Lysonic-E and Fotonic were further
developments from that ink but adapted for the Epson 9000 etc.
The CMYK sets tested like quoted on the pure cotton papers but
failed miserably when used on inkjet coated papers that were
then introduced, Hahnemuhle German Etching for example. CcMmYK
sets were worse on all papers. The dye inks on pure cotton
show far less detail and color gamut + they are not waterproof
(dye on inkjet coated paper is better but doesn't get near
pigment ink on coated paper).
The Lyson websites have misleading quotes from their own
tests. Lysonic E which has a lousy color gamut are tested on
CcMmYK printers, Fotonic which has a good color gamut but cm
inks that fade is tested on CMYK printers. The dye ink
competition was tested on CcMmYK printers (Van Son). The test
itself should be Wilhelm like according to Lyson, the
interpretation in years is Lyson like. I have used Epson,
Lysonic-E, Fotonic and Van Son dyes in an Epson 9000 and they
all faded.
So far no dye ink has beaten the pigment inks in longevity.
The HP dyes in combination with the right HP papers are
probably the best on the market right now and are Wilhelm
tested. The choice of papers is limited though.
Ernst
           Ernst Dinkla
www.pigment-print.com
(         unvollendet         )
2006-03-08 by Steve Kale
Colour gamut is far from mute and the capability of the black ink is very
important for the breadth of tonal range we have to play with.
> From: Larry Heath <lgheath@...>
2006-03-08 by alanrew42
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ernst Dinkla
<snip>
Larry, I totally agree, that's the most important point about this
article, the author is bound to be an evangelist for dye based inks
and whatever papers they have been tested with. Although the article
is very well written, it should be taken with a large pinch of salt
(not a grain, as Paul R suggested :-)).
Having said that, the author omitted to mention metamerism problems
with pigments, which makes me wonder whether Lyson dyes also suffer
from this problem.
> Larry,
Ernst,
Thanks for all this really detailed and valuable information. This
should be publicised more widely.
I've not used Fotonic inks, but comparing 3-D gamut plots of profiles
from the Lyson web site with profiles made for my Epson 2100 with UC
inks, the Fotonic gamut is significantly smaller. So I'm assuming that
Lyson's claims about gamut are dubious. It's interesting that the 2-D
gamut plots shown on Lyson's web site compare Lyson Fotonic inks with
the standard Epson inks in an Epson 870, which is now quite an old
printer by modern standards. Definitely a case of selective reporting!
Have you made profiles for Fotonic inks & seen better gamuts than
those in the standard Lyson profiles? How do they compare with modern
ink gamuts?
I have an interest in all this as I've been thinking about switching
to Lyson Fotonics in my 2100 after finally getting fed up with the
metamerism problems with the UC inks.
> The dye ink
> all faded.
Can you suggest a current HP A3-sized printer for both colour & B&W
printing? It may be cheaper for me to switch printers than put new
inks in my 2100. I hadn't previously considered HP because third party
ink (and driver/RIP) support seems better for Epson generally.
Thanks in anticipation,
Alan
2006-03-08 by CDTobie@aol.com
In a message dated 3/7/06 8:45:12 PM, hollidaypr@... writes:
Marrutt is the British reseller for Lyson, who were long proponents of
archival and semi-archival dye inks, even after the Epson move to pigments had
begun. Lyson eventually found it necessary to move into the pigment market to
remain competitive, but are dye-based at heart. This document needs to be viewed in
that context.
C. David Tobie
Datacolor Inc.
CDTobie@...
www.colorvision.com
> from this problem.
Lyson dyes have not been free of metamerism. For example the
Small Gamut set as the name implies not a very colorful inkset
for B&W printing had a lot metamerism as reported by users here.
For low metamerism you probably are better off with the
extended inksets with more grey inks. Composite grey (build
with CMY etc) usually is more metamerism prone.
I have done my best on many lists over the past 3 years to
reveal that the test pages of Lyson are misleading. They must
have seen my comments as true Lyson lovers were commenting my
messages and reporting back to base. Nothing changed though
but one particular Lyson lover switched to Lyson pigment ink.
The pages are still there. It doesn't work that way.
The tests, the printers, the papers, the technology are all
old news. But the pages still do what Lyson likes.
> ink gamuts?
At that time we used Lyson or Hahnemuhle profiles.
Now that UC K3 inks are at a gamut level that was only
possible with dye inks in the past you shouldn't look back.
Even HP is switching to pigment inks while their dye ink +
compatible papers had a fade resistance that surpassed any
other recent dye combination. But less waterproof than pigment
inks and bound to few paper choices.
If you insist that dye will solve your problems than you may
find equivalent (to Lyson) quality dye inks in Epson's own dye
ink and compatible papers and in Lincoln inks that were based
on Ilford Archiva dye inks. Both have been tested by Wilhelm.
Both perform best (fade resistance) on gelatine coated papers
and not good on matte papers. Less waterproof than pigment inks.
I don't think you will be satisfied by that change. The
reduction of metamerism in inkjet printing is a slow process.
Since it became part of the quality criteria (in CMYK offset
printing it isn't really an issue on a practical level).
Manufacturers are aware of it and Epson shows progress since
its earliest pigment models. I think you may find more
improvement in a 2400 (or possibly the Canon/HP pigment
competition) than in switching to dye inks.
>> The dye ink
>> all faded.
I have no experience with the HP printers. Some have been
discussed here in relation to B&W printing. There's a dye
model with an extra set of grey inks. But as said there's a
new HP pigment model with an extended set of inks.
           Ernst Dinkla
(         unvollendet         )
2006-03-08 by Andrew Rodger
It may be relevant to this conversation to note that Lyson have been
or are being bought out by Nazdar. What implications this has for
their inks in the future I don't know.
http://www.nazdar.com/pr_2006_nazdar_lyson.asp
Drew
( a Fotonic user )
see also amdig@yahoogroups.com
> pigments had
> market to
> to be viewed in
> that context.
> C. David Tobie
> Datacolor Inc.
> CDTobie@...
> www.colorvision.com
2006-03-08 by lulalake_1999
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Larry Heath"
they have to say.
> Larry Heath
Yeah, I have a hard time believing the article considering the
motivations of the then/now? CEO of Lyson. It's like trusting Kodak
with their longivity test results, or Enron with their financial
reports, or several prominent current US administration officials
with truth.
Jules
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "alanrew42"
> <snip>
> from this problem.
Not to forget that Lyson has no problem selling a full line of pig
inks that Tony is now disparaging.
No wonder they caved (no pun intended) and sold out.
Jules
> Drew
> ( a Fotonic user )
Wonder who will be happy with that purchase. Nazdar has been
successful in the US with silkscreen inks but never was able
to get a foothold in Europe. Competition by Sericol, Marabu,
Dubuit, Proll, Wiederhold and smaller companies kept the US
suppliers away. Lyson must have part of the market in wide
format solvent + textile printers + third party prosumer dye
and pigment but for all markets the competition is strong too
with for example Sericol again for the UV cure and Solvent
inks. Sericol is now owned by FujiFilm. I don't think Nazdar
is interested in the inkjet inks for prosumers but seeks
compensation for less silkscreen ink sales in the solvent wide
format inkjet market. All the old silkscreen ink manufacturers
try to find other markets.
Ernst
           Ernst Dinkla
(         unvollendet         )
2006-03-08 by john dean
Yes. I used their monochrome quad and small gamut inks for years, back
in the days before I was happy with the Cone or Mis pigments. The
metamerism is bad. The strange test results they have on their website
are retarded looking. They promised me for 2 years that they would
publish reliable permanence data on the Small Gamut set. I don't think
they ever did. I moved on a long time agao. They alway had some sad
excuse about the metamerism in these dyes. I belive the last thing
Tony Martin wrote me was, oh we don't consider this reddening under
tungsten light to be actually metamerism, we think of it as just the
way things actually look under incandescent light.
Please.
And, yes their color pigments suffer from metamerism too (which are in
the small gamut set along with monochrome dyes). Their whole thing was
promoting that their dyes did better on glossy media which is a non
issue these days.
As to their Cave Paints pigments - I can only wonder who actually
makes them.
john
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "lulalake_1999"
> > <snip>
> > from this problem.
> Jules
In an art catalog I saw another set of "tests" that tended to show dyes were
almost as good as pigments when they were sprayed with a UV spray.  However,
when I read the fine print, the trick used became clear.  They had coated
the dye test strip with a UV blocking subtance, and the pigments were
totally un-protected.  Then they used only UV light for the fading.  Of
course, the UV blocker was essentially opaque to the UV light, whereas the
pigs got a full dose of very damaging UV.  Using UV light as the test source
terribly skewed the results.  As Wilhelm has noted, in indoor display, it is
visible light (assuming no serious airborne pollutants) that does the
fading.
Paul
www.PaulRoark.com
That's right. He told us here that it is the blue spectrum that
actually does most of the damage, not the uv, because the blue
spectrum is much larger in total output.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark"
dyes were
However,
coated
whereas the
test source
display, it is
> fading.
> Paul
> www.PaulRoark.com
