Digital BW, The Print
Re: [Digital BW] Re: Proofing on the R2400
2006-02-22 by Gary Brown
Ginny:
I'm a little confused, it seems by your message this morning that you have
had you just received your 2400. You have asked many many questions about
how to use it, what paper to use, etc. It's obvious that when it comes to
the 2400, you have not yet made it to "novice". Yet when Mindy asked a
question about paper feeding, even though your answer was correct, in your
response you said "I've never had a problem as long as you don't stack the
VFA" which implies you are an experienced 2400 user. I guess my question is,
if in fact you are an experienced user, why do you ask so many questions. If
you are not why do you imply that you are.
There are many experts that participate in this forum (you all know who you
are), but there are also many that respond as experts when they shouldn't
(you also know who you are).
I've already unrolled the fire hose.
Gary
www.pbase.com/garyallenbrown
To: <DigitalBlackandWhiteThePrint@yahoogroups.com>
Sent: Wednesday, February 22, 2006 11:20 AM
Subject: [Digital BW] Re: Proofing on the R2400
  Altho the driver DEFAULTS to the single feeder in the rear, after it
does, I merely set it back to the normal sheet feeder. (You then can
save the setting) I've never had a problem as long as you don't stack
the VFA. I usually only place one or 2 sheets in the normal feeder at
a time.
Best
Ginny
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "mindystricke"
<mindystricke@...> wrote:
>  Hi everyone-
> I have a question about the link everyone keeps referring to:
> http://www.cjcom.net/digiprnarts.htm
> I tried to follow the instructions for simple straightforward black
> and white printing using epson enhanced matte paper to proof in
quarter sheets to save
> money,  with the Velvet fine Art paper setting.  However, it turns
out that you need to use
> the single paper feeder in the back just to make the Velvet Fine Art
choice available, and
> then a  quarter size sheet is too small to be fed back there.
> I went back to the main feeder and used the enhanced matte setting.
 It didn't look so
> great.
> Should I try using an ICC profile instead of the Advanced B&W
driver?   Should I use the
> front feeder?  Should I just proof on Velvet Fine Art at a larger
size?  I have been so
> frustrated getting started with digital
> printing.  There are so many variables, I find it so difficult to
isolate why a print isn't
> looking good.
> Thanks for everyone's help in advance.  I am determined to figure
> this all out.
>  Mindy
Please visit the Group Homepage to check the Files, and other resources as
they are often being updated.
If you wish to receive no emails or just a daily digest, or you wish to
unsubscribe, please edit your Membership preferences by visiting this same
page.
Please follow these basic guidelines:
- As threads develop, trim off excess portions of earlier messages to keep
them short.
- Good manners are required at all time. No personal attacks or flames.
Hostile, aggressive or argumentative users may be removed from the
membership without notice.
- Keep your posts and threads related to the group topic of digital B&W
printing. Users who persistently make off-topic posts may be removed from
the membership.
- By posting on this forum you agree to abide by the group rules and
guidelines, and to abide by the actions and decisions of the group Owner and
Moderators. See "Group Topic, Rules and Guidelines" in the Files section:
http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT
YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
"MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS,
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  "OWNER" AND
"MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY
TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR
ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY
THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER
MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
Yahoo! Groups Links
2006-02-23 by ginnylady33
"I guess my question is,  if in fact you are an experienced user, why
who you
shouldn't
> (you also know who you are)."
Gary,
The explanation is pretty simple:
 My answer to the query posed about VFA was based on extensive
experience with the R1800. As you noted, I have little experience with
the 2400 since I recently received it. But, from looking at the unit
and fiddling with it some, the feed mechanisms on the 2400 and 1800
appear very similar so I assumed that the VFA would load equally well
on both via the standard feed method.
 Like many of us, I am expert or 'experienced' in some things and a
novice in others. I consider myself an expert in 'real' darkroom film
processing, paper developing and shooting with the Zone system. I
would rate myself as pretty darn 'competent' at digital processing in
Photoshop and digital printing on a 1280 or my newer 1800.
 I'm a novice when it comes to the 2400 and the Advanced B&W settings
since I've never used them. But, I ask lotsa questions, read what is
recommended (Such as Clayton's masterful articles) and learn very quickly.
 I would never casually give an opinion of conviction unless I was
pretty darn sure that what I said was true.
 I hope this clarifies the seeming conflicts of my posing some rather
naive questions and also volunteering some definitive answers in other
areas.
  Best
  Ginny
2006-02-23 by Gary Brown
- I hope this clarifies the seeming conflicts of my posing some rather
-naive questions and also volunteering some definitive answers in other
-areas.
It does,
Gary
