Mounting?
2005-12-31 by John Kantor
I'd like to offer mounted fine-art images as one of my products, but I don't know much about it. What are the preferred methods for inkjet prints?
2005-12-31 by Steven Karafyllakis
Hi John; One nice thing about inkjet papers, especially the heavywight, is that you don't need to drymount smaller sizes. Some people hinge the window to the backboard, slip the print in and align it then either tape the corners down or use corner mounts. Another alternative is to tape the print directly to the window matte with low-tack acid free artist's tape. I prefer this as it allows some tensioning of the print, and ensures it will never be out of alignment. And if want to, you can still dry-mount most papers-but why bother? Steve Karafyllakis --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John Kantor" <jkantor@m...> wrote: > > I'd like to offer mounted fine-art images as one of my products, but I > don't know much about it. What are the preferred methods for inkjet > prints? >
2006-01-01 by kenseidman
I've just mounted my first 24 x 30 inch print onto foamcore using the tape hinge method. Results are not satisfactory for this size and paper (Kodak Pro Glossy paper). Ripple is evident. I've got a dry mounting press but it is not large enough for this size print (unless I try to dry mount in sections, which seems error prone to me ?). Any suggestions for other mounting methods for such a large print? Thanks, Ken --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven Karafyllakis" <steve@s...> wrote:
> ... > One nice thing about inkjet papers, especially the heavywight, is > that you don't need to drymount smaller sizes. Some people hinge the > window to the backboard, slip the print in and align it then either > tape the corners down or use corner mounts. > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John Kantor" > <jkantor@m...> wrote: > > > > I'd like to offer mounted fine-art images as one of my products, > but I > > don't know much about it. What are the preferred methods for > inkjet > > prints? > > >
2006-01-02 by Steven Karafyllakis
Hi Ken; I'm not too surprised it doesn't work at that size; that leaves you with sending it out to a photolab for either dry-mounting or cold- mounting. I would test a smaller finished print in your dry-mount press to see how it responds to the heat-if you use a low-temp RC tissue it should work. If it doesn't work, look for a place that does cold-mounting-there's an adhesive and a vacuum press involved (I think-does anyone else have details on this process?)and I have no idea what the archival proerties of the adhesive might be. Perhaps Greg or Tyler can give us more details on this, along with any other methods available? Steve Karafyllakis --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "kenseidman" <Seidmank@e...> wrote: > > I've just mounted my first 24 x 30 inch print onto foamcore using the > tape hinge method. Results are not satisfactory for this size and > paper (Kodak Pro Glossy paper). Ripple is evident. I've got a dry > mounting press but it is not large enough for this size print (unless > I try to dry mount in sections, which seems error prone to me ?). > > Any suggestions for other mounting methods for such a large print? > Thanks, > Ken > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven > Karafyllakis" <steve@s...> wrote: > > ... > > One nice thing about inkjet papers, especially the heavywight, is > > that you don't need to drymount smaller sizes. Some people hinge the > > window to the backboard, slip the print in and align it then either > > tape the corners down or use corner mounts. > > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John Kantor" > > <jkantor@m...> wrote: > > > > > > I'd like to offer mounted fine-art images as one of my products,
> > but I > > > don't know much about it. What are the preferred methods for > > inkjet > > > prints? > > > > > >
2006-01-02 by scott_now_coming
Ken, Have you mounted the photo behind glass yet? I'm sure if you place it in a frame with a good stiff backing board, the photo will look great. I use that stuff peg-board is made of, only it's smooth and doesn't have the holes. I forget what the "technical" name is, but I bought it at HomeDepot. Scott --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "kenseidman" <Seidmank@e...> wrote: > > I've just mounted my first 24 x 30 inch print onto foamcore using the > tape hinge method. Results are not satisfactory for this size and > paper (Kodak Pro Glossy paper). Ripple is evident. I've got a dry > mounting press but it is not large enough for this size print (unless > I try to dry mount in sections, which seems error prone to me ?). > > Any suggestions for other mounting methods for such a large print? > Thanks, > Ken > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven > Karafyllakis" <steve@s...> wrote: > > ... > > One nice thing about inkjet papers, especially the heavywight, is > > that you don't need to drymount smaller sizes. Some people hinge the > > window to the backboard, slip the print in and align it then either > > tape the corners down or use corner mounts. > > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John Kantor" > > <jkantor@m...> wrote: > > > > > > I'd like to offer mounted fine-art images as one of my products,
2006-01-02 by Greg
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "scott_now_coming" <scott_now_coming@y...> wrote: > > Ken, > > Have you mounted the photo behind glass yet? > > I'm sure if you place it in a frame with a good stiff backing board, > the photo will look great. > > I use that stuff peg-board is made of, only it's smooth and doesn't > have the holes. I forget what the "technical" name is, but I bought > it at HomeDepot. > > Scott Masonite? If not then it is probably MDF particle board, which seems to be more glue than wood chip. My brother uses the mDF to make speaker cabinets because it is dimensionaly stable, extremely dense, and extremely stiff. And since it is an engineered product, you can get it in really thick sheets like 1.5 inches. It does dull your cutting tools faster than "normal" wood and you really should use a good dust mask when cutting it, a real filter would be better.
2006-01-02 by James Parker
MDF has a lot of urea formaldehyde in it. There is a version that doesn't, but is more expensive and not generally available through home centers like Lowe's and Home Depot. It can't be good for long-term preservation of prints. Plus it's heavy. Masonite (or hardboard as it is known generically) may also have the same issues with outgassing as other woods. Tempered Masonite (the dark brown stuff) is harder and more dimensionally stable. I've heard of folks mounting to aluminum and then to mdf or gatorfoam. I don't know where they get large prints mounted to aluminum, but there is a product that is used in the display trade that is fairly thin, called Dibond. I've been looking for a local source to cold-mount to this substrate, but so far no luck. I'm in the Detroit area, so if anyone has any suggestions? Jim On 1/2/06 7:18 AM, "DigitalBlackandWhiteThePrint@yahoogroups.com" <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
> Subject: Re: Mounting? > > --- In > DigitalBlackandWhiteThePrint@yahoogroups.com, "scott_now_coming" > <scott_now_coming@y...> wrote: >> >> Ken, >> >> Have you mounted the photo behind glass yet? >> >> I'm sure if you place it in a frame with a good stiff backing > board, >> the photo will look great. >> >> I use that stuff peg-board is made of, only it's smooth and doesn't >> have the holes. I forget what the "technical" name is, but I bought >> it at HomeDepot. >> >> Scott > > > Masonite? If not then it is probably MDF particle board, which seems > to be more glue than wood chip. My brother uses the mDF to make > speaker cabinets because it is dimensionaly stable, extremely dense, > and extremely stiff. And since it is an engineered product, you can > get it in really thick sheets like 1.5 inches. It does dull your > cutting tools faster than "normal" wood and you really should use a > good dust mask when cutting it, a real filter would be better.
I like the idea of aluminium, but I haven't been able to find a source who does this, either. Scott --- In DigitalBlackandWhiteThePrint@yahoogroups.com, James Parker <dakota.kid@m...> wrote: > > MDF has a lot of urea formaldehyde in it. There is a version that doesn't, > but is more expensive and not generally available through home centers like > Lowe's and Home Depot. It can't be good for long-term preservation of > prints. Plus it's heavy. > > Masonite (or hardboard as it is known generically) may also have the same > issues with outgassing as other woods. Tempered Masonite (the dark brown > stuff) is harder and more dimensionally stable. > > I've heard of folks mounting to aluminum and then to mdf or gatorfoam. I > don't know where they get large prints mounted to aluminum, but there is a > product that is used in the display trade that is fairly thin, called > Dibond. I've been looking for a local source to cold-mount to this > substrate, but so far no luck. I'm in the Detroit area, so if anyone has any > suggestions? > > Jim > > On 1/2/06 7:18 AM, "DigitalBlackandWhiteThePrint@yahoogroups.com" > <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote: > > > Subject: Re: Mounting? > > > > --- In > > DigitalBlackandWhiteThePrint@yahoogroups.com, "scott_now_coming" > > <scott_now_coming@y...> wrote: > >> > >> Ken, > >> > >> Have you mounted the photo behind glass yet? > >> > >> I'm sure if you place it in a frame with a good stiff backing > > board, > >> the photo will look great. > >> > >> I use that stuff peg-board is made of, only it's smooth and doesn't > >> have the holes. I forget what the "technical" name is, but I bought > >> it at HomeDepot. > >> > >> Scott > > > > > > Masonite? If not then it is probably MDF particle board, which seems > > to be more glue than wood chip. My brother uses the mDF to make > > speaker cabinets because it is dimensionaly stable, extremely dense, > > and extremely stiff. And since it is an engineered product, you can > > get it in really thick sheets like 1.5 inches. It does dull your > > cutting tools faster than "normal" wood and you really should use a > > good dust mask when cutting it, a real filter would be better. >
2006-01-02 by Phil Lindsay
Hi: 3M makes a spray adhesive called Vac-U-Mount". My vacuum press can not handle 24 x 36 so I had to use hand roller pressure instead. It seems to have worked. Phil Lindsay On Jan 1, 2006, at 8:28 PM, Steven Karafyllakis wrote: > Hi Ken; > > I'm not too surprised it doesn't work at that size; that leaves you > with sending it out to a photolab for either dry-mounting or cold- > mounting. I would test a smaller finished print in your dry-mount > press to see how it responds to the heat-if you use a low-temp RC > tissue it should work. If it doesn't work, look for a place that > does cold-mounting-there's an adhesive and a vacuum press involved > (I think-does anyone else have details on this process?)and I have > no idea what the archival proerties of the adhesive might be. > Perhaps Greg or Tyler can give us more details on this, along with > any other methods available? > > Steve Karafyllakis > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "kenseidman" > <Seidmank@e...> wrote: > > > > I've just mounted my first 24 x 30 inch print onto foamcore using > the > > tape hinge method. Results are not satisfactory for this size and > > paper (Kodak Pro Glossy paper). Ripple is evident. I've got a dry > > mounting press but it is not large enough for this size print > (unless > > I try to dry mount in sections, which seems error prone to me ?). > > > > Any suggestions for other mounting methods for such a large print? > > Thanks, > > Ken > > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven > > Karafyllakis" <steve@s...> wrote: > > > ... > > > One nice thing about inkjet papers, especially the heavywight, > is > > > that you don't need to drymount smaller sizes. Some people hinge > the > > > window to the backboard, slip the print in and align it then > either > > > tape the corners down or use corner mounts. > > > > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John > Kantor" > > > <jkantor@m...> wrote: > > > > > > > > I'd like to offer mounted fine-art images as one of my > products, > > > but I > > > > don't know much about it. What are the preferred methods for > > > inkjet > > > > prints? > > > > > > > > > > > > > > > > Please visit the Group Homepage to check the Files, and other > resources as they are often being updated. > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > If you wish to receive no emails or just a daily digest, or you > wish to unsubscribe, please edit your Membership preferences by > visiting this same page. > > Please follow these basic guidelines: > - As threads develop, trim off excess portions of earlier messages > to keep them short. > - Good manners are required at all time. No personal attacks or > flames. Hostile, aggressive or argumentative users may be removed > from the membership without notice. > - Keep your posts and threads related to the group topic of digital > B&W printing. Users who persistently make off-topic posts may be > removed from the membership. > - By posting on this forum you agree to abide by the group rules > and guidelines, and to abide by the actions and decisions of the > group Owner and Moderators. See �Group Topic, Rules and Guidelines� > in the Files section: > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE > PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE > �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL > NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, > CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, > DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER > INTANGIBLE LOSSES (EVEN IF THE �OWNER� AND �MODERATORS� OF DIGITAL > BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF > SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE > THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO > OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR > CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO > GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE > PRINT YAHOO GROUP. > > > > > SPONSORED LINKS > Digital wedding photography Learn digital photography Digital > photography college > Digital photography Digital photography web site Digital > photography course > > YAHOO! GROUPS LINKS > > Visit your group "DigitalBlackandWhiteThePrint" on the web. > > To unsubscribe from this group, send an email to: > DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > [Non-text portions of this message have been removed]
2006-01-02 by kenseidman
My 24 x 32 inch print is not mounted behind glass. I would actually need to get a 32 x 40 inch piece of plexiglass for the matted print and haven't looked into this option yet. I suspect it would help some but not entirely eliminate the ripples (based on previous experience mounting Ilfochrome/Cibachrome prints behind glass). In general I prefer not to put glass or plexi over my prints (I spray them with PremierArt PrintShield for both increased surface gloss, reduced gloss differential, and longevity). I will probably experiment on some smaller prints with my dry mounting press use the 'sectional approach' next weekend... I should mention that the ripples do not show up under floodlights when viewed anywhere within about 60 deg left or right of center... but at greater angles, or without the flood lights on they show up. So, when I approach the print in my living room I am at a large angle (> 60 deg) and they are quite obvious. I just found a product listed in the Light Impressions catalog called Gudy 831 that is an archival pressure sensitive cold mounting adhesive (http://www.lightimpressionsdirect.com, search for 'Gudy', item 20719, $75 for 33 ft.). It comes in 24 inch rolls. Anyone have any experience with it or similar products that don't require a special press? Ken > Have you mounted the photo behind glass yet? > I'm sure if you place it in a frame with a good stiff backing board, > the photo will look great. --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven Karafyllakis" <steve@s...> wrote:
> > Hi Ken; > > I'm not too surprised it doesn't work at that size; that leaves you > with sending it out to a photolab for either dry-mounting or cold- > mounting. I would test a smaller finished print in your dry-mount > press to see how it responds to the heat-if you use a low-temp RC > tissue it should work. If it doesn't work, look for a place that > does cold-mounting-there's an adhesive and a vacuum press involved > (I think-does anyone else have details on this process?)and I have > no idea what the archival proerties of the adhesive might be. > Perhaps Greg or Tyler can give us more details on this, along with > any other methods available? > > Steve Karafyllakis > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "kenseidman" > <Seidmank@e...> wrote: >> I've just mounted my first 24 x 30 inch print onto foamcore using >> the tape hinge method. Results are not satisfactory for this >> >> size and paper (Kodak Pro Glossy paper). Ripple is evident. I've >> got a dry mounting press but it is not large enough for this size >> print (unless I try to dry mount in sections, which seems error >> >> prone to me ?).
Phil, Thanks for the info. I notice that 3M makes several Adhesive Sprays http://www.framingsupplies.com/3M/InformationAdhesiveSprays.htm Options so far are: 1. 3M Vac-U-Mount (or something similar, e.g. PhotoMount?) w/hand roller 2. Dry mount print in sections 3. Gudy 831 Cold-Mounting Adhesive (see my earlier post) 4. 32 x 40 inch plexiglass to perhaps flatten out ripples Ken -- In DigitalBlackandWhiteThePrint@yahoogroups.com, Phil Lindsay <fotophil@p...> wrote:
> > Hi: > > 3M makes a spray adhesive called Vac-U-Mount". My vacuum press can > not handle 24 x 36 so I had to use hand roller pressure instead. It > seems to have worked. > > Phil Lindsay > On Jan 1, 2006, at 8:28 PM, Steven Karafyllakis wrote: > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "kenseidman" > <Seidmank@e...> wrote: > I've just mounted my first 24 x 30 inch print onto foamcore using > the > tape hinge method. Results are not satisfactory for this size and > paper (Kodak Pro Glossy paper). Ripple is evident. I've got a dry > mounting press but it is not large enough for this size print > (unless > I try to dry mount in sections, which seems error prone to me ?). > > Any suggestions for other mounting methods for such a large print? > Thanks, > Ken
2006-01-02 by Finn Krogvig
Look at this - near the end of the page Stephen Livick describes an interesting product called Lascaux acrylic adhesive 360 HV. http://www.livick.com/method/inkjet/pg1.htm I have not used it myself... MVH FinnK ----------------------- Finn Krogvig -----Opprinnelig melding----- Fra: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] På vegne av kenseidman Sendt: 3. januar 2006 00:02 Til: DigitalBlackandWhiteThePrint@yahoogroups.com Emne: [Digital BW] Re: Mounting? Phil, Thanks for the info. I notice that 3M makes several Adhesive Sprays http://www.framingsupplies.com/3M/InformationAdhesiveSprays.htm Options so far are: 1. 3M Vac-U-Mount (or something similar, e.g. PhotoMount?) w/hand roller 2. Dry mount print in sections 3. Gudy 831 Cold-Mounting Adhesive (see my earlier post) 4. 32 x 40 inch plexiglass to perhaps flatten out ripples Ken -- In DigitalBlackandWhiteThePrint@yahoogroups.com, Phil Lindsay <fotophil@p...> wrote: > > Hi: > > 3M makes a spray adhesive called Vac-U-Mount". My vacuum press can > not handle 24 x 36 so I had to use hand roller pressure instead. It > seems to have worked. > > Phil Lindsay > On Jan 1, 2006, at 8:28 PM, Steven Karafyllakis wrote: > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "kenseidman" > <Seidmank@e...> wrote: > I've just mounted my first 24 x 30 inch print onto foamcore using > the > tape hinge method. Results are not satisfactory for this size and > paper (Kodak Pro Glossy paper). Ripple is evident. I've got a dry > mounting press but it is not large enough for this size print > (unless > I try to dry mount in sections, which seems error prone to me ?). > > Any suggestions for other mounting methods for such a large print? > Thanks, > Ken Please visit the Group Homepage to check the Files, and other resources as they are often being updated. http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. Please follow these basic guidelines: - As threads develop, trim off excess portions of earlier messages to keep them short. - Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice. - Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership. - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See Group Topic, Rules and Guidelines in the Files section: http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP. _____ YAHOO! GROUPS LINKS * Visit your group "DigitalBlackandWhiteThePrint <http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint> " on the web. * To unsubscribe from this group, send an email to: DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com <mailto:DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com?subject =Unsubscribe> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> . _____ [Non-text portions of this message have been removed]
