Digital BW, The Print
EZ B&W mixing warm & neutral carts
2005-01-09 by Randy Rancier
I haven't posted a message in a long while, several months, but I've
been wanting to post my findings as to various degrees of warm vs.
neutral prints by mixing the warm and neutral cartridges (carts) on
my Epson C84.  Maybe someone has already posted this info but I
haven't seen it and maybe this will be helpful to others using the
EZ B&W inks, which are absolutely great.  The C84 & C86 are only
fair when printing color as compared to Epsons photo grade printers,
but are wonderful for B&W with the EZ ink sets.
Before giving you the particulars below here is my results rating
from neutral to the warmest prints.
CW = Cyan warm cart; MN = Magenta neutral cart and so on...  There
are only 8 different combinations of the warm and neutral carts.
1. CN-MN-YN  the most neutral print
2. CN-MN-YW  a little warmer
3. CW-MN-YN
4. CN-MW-YN
5. CW-MN-YW
6. CW-MW-YN
7. CN-MW-YW
8. CW-MW-YW  obviously the warmest
I found very little difference between combinations 3&4, and also
between 6&7 and with further testing might flip-flop.  There was a
more decernable difference between the other steps.
This is how I performed the test and other useful info:  I have the
neutral set of carts (cartridges) and a warm set of carts.  Both
sets are used with the Eboni black since the shades between warm and
neutral is determined in the midtones and highlights.  One thing
everyone should know if you don't already is that the ink in the
cyan (C), magenta (M), and the yellow (Y) in both the warm carts and
the neutral carts is exactly the same ink.  In other words when
refilling the warm and neutral carts all you need is one bottle of
the warm and one bottle of the neutral for each of the C,M, and Y
carts.  I comfirmed this with MIS and Paul Roark.  I used a Epson
C84 printer with Epson Heavyweight Matte Paper, which has optical
brightners (OB).  I find that in general papers with OB's print
colder or more neutral and those without OB's tend to print warmer.
The rating from the most neutral to warmest was by sight and
therefore somewhat subjective, but isn't that the way it is with
everything about B&W prints.
Hope this is helpful,
Randy
Re: EZ B&W mixing warm & neutral carts
2005-01-09 by scott_now_coming
"One thing
carts. I comfirmed this with MIS and Paul Roark. "
That's great news since you only need to buy 2 bottles of ink.
But what puzzles me is, how do you get all of those "shades" with
just two inks?
The HP 59 carts have 3 "shades" of grey. You would think those prints
would look better than the MIS, but I like the MIS EZ better.
That's for your up-date.
Scott
The various shades refered to are shades of color between the
neutral and warm ink sets and not shades of gray as referenced below
by HP's photo B&W ink set. The various shades of color is due to
varying the amounts between the warm and neutral inks by varying the
combinations of the warm to neutral carts. See original post!
Randy
--- In
DigitalBlackandWhiteThePrint@yahoogroups.com, "scott_now_coming"
<scott_now_coming@y...> wrote:
> "One thing
and
> just two inks?
prints
> Scott
O.K, Randy, I mis-spoke.
I meant "density" instead of shades.
How do you get all those densties with only 2 densities of ink.
One bottle to fill the C, Y, And M positions and one bottle of black
to fill the black position.
2 inks. I just don't get it.
Scott
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Randy Rancier"
> Randy
> --- In
> > "One thing
> and
> > just two inks?
> prints
> > Scott
Varying warm and neutral Tones w/ EZ inksets on C84/86
Upthread to see original post:
Scott,  I'm not sure how the mechanics of gray densities and
how "smooth" they appear and is really beyond the scope of my
original post as it relates to differences in warm and
neutral "tones" rather than "shades" of gray.  The shades of gray
question would probably be a question for Paul Roark.
Cheers,
Randy
--- In
black
> Scott
Rancier"
below
> > Randy
> > --- In
> > > "One thing
carts
> > and
bottle of
and Y
with
> > > just two inks?
> > prints
> > > Scott
RE: [Digital BW] Varying warm and neutral Tones w/ EZ inksets on C84/86
2005-01-09 by Paul Roark
>one bottle of black to fill the black position.
The dot size and very high resolution of the C86 allow it.  Recall that the
R800 no longer uses light inks either.  The light inks were only needed
where the dots were too big and the resolution too low.  As technology
advances, the light inks will disappear.  I will not miss them.  Among other
things they flood glossy paper and end up being worse than a more dense ink.
I call them expensive water.
Also, think of how you'd get the lightest individual dots if you were going
to have 3 jets firing.  You'd want 3 identical densities so that each one
could be as light as possible.
It works, and the C86 and R800 technology are probably where we're going in
the near future.
Paul
www.PaulRoark.com
Re: [Digital BW] Varying warm and neutral Tones w/ EZ inksets on C84/86
2005-01-10 by Roy Alcantara
Thanks for the verification that the inks in the C/M/Y positions are
identical.  I've read this in previous threads.
For kicks, I posted this question to tech support at MIS, mentioning
that I had heard that the inks were identical yet was confused about
them selling the C/M/Y ultratone refills as separate items.  Here's
their response: "...also you can order by individual color but all
the colors have a different mix so you will have to purchase by color
and not mix it."  The subject line of the post indicated Ultratone &
C86 too.  Go figure.
Anyway, I think I'm going to take the plunge and order some empties
and some ink, along with the refill kit
(http://www.inksupply.com/index.cfm?source=html/vacfill.html)
thanks again.
Roy
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark"
that the
needed
technology
Among other
dense ink.
were going
each one
going in
> the near future.
> Paul
> www.PaulRoark.com
2005-01-13 by scott_now_coming
Thanks for posting this.
It is really helpful to me.
I was using PK and all "N" inks and felt is was a little on the cool
side. Pk and all "W" was too warm, especially with high key images.
I'm now using PK, N,N,W with Kirkland (Epson C86 printer,of course!)
and the prints look really neutral to me.
I've bookmarked this post for future reference.
Thanks again,
Scott
I've
printers,
> 3. CW-MN-YN
> 4. CN-MW-YN
> 5. CW-MN-YW
> 6. CW-MW-YN
> 7. CN-MW-YW
and
and
> Randy
2005-01-20 by Randy Rancier
Your welcome, I'm glad you found this helpful.
I suppose if you wanted a tone in between what you can achive using
this method I suppose one could mix the warm and neutral inks at
various ratios in one or two of the carts.
Happy experimenting.
Randy
--- In
cool
course!)
> Thanks again,
> Scott
Rancier"
> I've
vs.
on
> printers,
rating
There
> > 3. CW-MN-YN
> > 4. CN-MW-YN
> > 5. CW-MN-YW
> > 6. CW-MW-YN
> > 7. CN-MW-YW
also
a
> and
> and
of
Y
Epson
optical
warmer.
> > Randy
