I've given up on trying to print quadtones as my other chambers aren't working. But my black chamber gives a perfect nozzle check. BUT ... I still get banding when printing Black only.
Can anyone help me please??
thanks a lot,
Richard
http://smallfield.vze.com
http://photos.smallfield.vze.com
"Men and nations behave wisely once they have exhausted all
the other alternatives. "
--Abba Eban (1915-)
I had the same experience after ~3 years of MIS CIS and VM quads...
couldn't fix it. Printer works fine with color dye carts. My
solution was to spend $150 on an HP 7660 :) I think that pads start
partially clog just enough to band with full ink application, but
not for the tiny amount used in a nozzle check... but that is just
speculation. MIS gave me new carts and I was just trying to decide
which inkset to try next... no rush with the 7660 though... will
probably need to print larger before I go back down that path.
mark
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Richard
Smallfield <r.smallfield@p...> wrote:
> Hi,
> thanks a lot,
> Richard
> --Abba Eban (1915-)
i had a similar problem... with 1280, UT2 + Ebony - my noozle checks
were also coming OK - but was still getting banding... i followed the
instructions here:
http://www.inksupply.info/?_a=knowledgebase&_j=questiondetails&_i=1
and no more banding ...
altaf
On Apr 18, 2004, at 8:48 PM, Richard Smallfield wrote:
> Hi,
> thanks a lot,
> Richard
> speculation.
The same effect is happening with the pro printers and their
dampers (the sieves in them) so a good guess.
Ernst
