Digital BW, The Print
CIS with 1160
CIS with 1160
2004-04-16 by byushooter
This is a copy of an email I sent to IJM last Monday.  I still
haven't gotten a response from them and am wondering if anyone here
can help me?  Please?!
"I am installing two CIS units using Piezotone inks on Epson
1160's.  I installed the first CIS without difficulty and other than
banding, it works correctly.  However, I attempted to install the
second CIS and am having difficulty.  The tubing from the CIS seemed
to be too short.  If the print head went all the way to the left,
the line was pulled taut.  I moved the velcro part over and it was
then too short to go all the way to the right.  In order to do
further adjustment, I removed the cartridges from the printer.  The
ink from two of the lines (the black cart and one of the color
lines) flowed back into the bottles and the lines are now filled
with air.  I have tried printing the flush image file twice but the
ink in those two lines has not moved.  And the ink that does make it
to the paper has a very heavy flow, puddling on the paper.
Is there a way to renew the vacuum and fill those two lines?  If
not, how do I fill them with ink?  What is causing the puddling?"
Thanks for any advice you can offer.
Re: CIS with 1160
2004-04-16 by Andre
You need to do a re-install with freshly cleaned tube lines. Put the
lines and arm in a sink full of water and blow/siphon to clear the
ink. Do not re-install untill you have ascertained that the tube
lines have fully dried. (very important)
For a clean re-install print this pdf from injketmall. It works for
the Epson 1160 and Epson 1200.
http://www.inkjetmall.com/store/info/pdf/CIS740-1200.pdf
Cheers,
Andre
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "byushooter"
than
seemed
it
Re: CIS with 1160
2004-04-17 by byushooter
Thanks Andre for the quick reply.  Since the cartridges were
installed and the bottom seal pierced, can I reuse them?  Can I just
tape over the bottom of them or something so that I can create a
vacuum with the syringe?
Jenny
Re: CIS with 1160
2004-04-17 by Andre
just
> Thanks,
> Jenny
I'm afraid you may need a fresh set of cartridges because you need to
put a vacuum in them so that they draw the ink from the bottles
through the tubes lines. And when you draw air from those filled
cartridges for said vacuum, you'll have ink overflowing into your
siphon! Also, I dont know if the tape of the bottom would hold when
you start that vacuum. I fail to see how it could be done otherwise,
but you never know, maybe someone will explain how to do it.
Read the pdf carefully and make sure you understand the entire
procedure before you start and take your time.
Cheers,
Andre
Re: CIS with 1160
2004-04-17 by Bob Michaels
You can bottom fill 1280 CFS cartridges very easily. I don't know
about 1160 carts though. The bottom fill seems to work just as well,
maybe better. Just make sure you suck all the foam out. No small task
as it seems it will never end.
If you don't know how much ink to put in the cart, and it's not on Jon
Cone's site, go to the MIS site.
Bob Michaels
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Andre"
> just
> > Thanks,
> > Jenny
> Cheers,
> Andre
Re: CIS with 1160
2004-04-17 by Mark Hahn
as long as your seals are good all you have to do is get the carts
and tubes full of ink.  The easiest way to do this is just to use a
syringe to pull ink up the tubes and then into the carts.  Then when
everything is filled up you have to pump enough air back into the
cart to make it roughly half full (you need the air space otherwise
you'll get sputtering).  Install the cart and it will work.  I've
done this numerous times with my CFS system on the 1160.
mark
Re: CIS with 1160
2004-04-17 by richard_h95050
Bob's suggestion is correct -- you can bottom fill the cartridges on
an 1160 quite easily. However, you do need to have a 30-60cc syringe
and bottom-fill adapter for this method, rather than the vacuum pump
used in your initial installation.
These parts may have been included with your CIS -- if not, they are
very inexpensive and you'll need them for long-term maintenance of
your CIS systems anyway. Don't purchase new carts unless there is
something defective with yours.
Go to the MIS Website (www.inksupply.com) and you'll find everything
you need there -- instructions, troubleshooting info, CIS feed tubing
sold by the foot, and the fill parts you need are in the catalog at:
http://www.inksupply.com/index.cfm?source=html/accessory.html
If you have any questions or problems, give them a call. They are
very helpful and understand the CIS mechanism very well, since they
sell and service their own systems. Their inks are great, too!
With all due respect to Jon and team, from the general feedback it
seems the IJM customer support isn't up to it's previous very high
standards. I still use their inks on some of my wide-format printers,
but for bulk inks, parts and software I've switched to other vendors.
If you're not getting an answer and assistance from them, call MIS --
I'm sure they'd be happy to help you and win your business ;>)
Good luck and happy printing!
Richard
than
seemed
it
Re: CIS with 1160
the only purpose of the vacuum pump is to get the ink into the carts
and tubes, after that it is an open system on the bottle side and
works by syphon action... it doesn't matter how the ink gets into the
right place.
mark
to
otherwise,
> Cheers,
> Andre
Re: CIS with 1160
2004-04-17 by smthopr2000
Puddling huh?
I had that happen on my 1200 with the black ink and wondered what happend. I
learned soon enough: The black ink bottle was empty, and it stopped printing
entirely. But why the puddle? From your post I guesss I've learned that when there is
no ink to pull in (just air) the ink flows too quickly through the cartridge.
Oh, how I fixed it.
I pulled the carts, and then found I had many colors where the ink had gone back in
the bottles, and a lot of air in the lines.
I made sure each bottle had enough ink and then used a syringe to suck ink out of
the hole in the cart that goes on the print head. When I pulled through a substantial
quantity of ink, I squirted it back in the resevoir bottle (careful not to mix colors).
I ran about 5 cleaning cycles and I'm back in business.
-bruce
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "byushooter" <jellerbe@j...>
Re: CIS with 1160
Wow.  Thanks everyone for all the responses.  You have given me a
lot of advice that I am going to put to use today to see if I can
get this printer working.
These 2 1160's belong to a friend who is also considering purchasing
piezo inks for his old 7000.  From the total lack of support
exhibited by IJM, I am definitely going to tell him to consider
giving MIS a try.
Thanks again.
Jenny
Re: CIS with 1160
A couple more questions ... I have read the info on the MIS
website.  To fill the carts from the bottom it looks like I will
need a syringe (which I have), rivets (which I assume I can get from
the hardware store) and a device to attach to the syringe to insert
into the carts.  Is there any type of device for that that would be
available locally?  If not, I can order it from MIS but it would be
great if I could get started on this sooner.
Also, the rivets ... do those stay attached to the carts even when
they are installed in the printer?  Or are they removed before
installation?
Jenny
Re: CIS with 1160
the rivets are just for plugging the hole and have to removed.  My
guess is that those little nozzles that MIS supplies with the
syringes are an off the shelf medical device so if you have a medical
supply house local and can bring in a picture that they will have
them... but I don't know what they are called.  Once you get it going
you'll find that it will just work.  Let the freshly filled carts to
sit for like 24 hours before trying to run your printer, you'll avoid
a lot of frustration.
mark
from
> installation?
> Thanks,
> Jenny
Re: CIS with 1160
MIS has great service... they even helped out a friend of mine with
his Niagra system... needless to say he will go with MIS next time.
mark
purchasing
> giving MIS a try.
> Thanks again.
> Jenny
Re: CIS with 1160
2004-04-17 by jim hayes
Sorry to jump into the middle of this thread without reading any
previous entries, and as a further disclaimer, I haven't been filling
my own carts for 1 1/2 years now so I may be out of date but...
Why do you want to fill the carts from the bottom? Of course it can be
done easily, and you probably won't have a problem but the possible
disadvantages are: 1) Running a slight risk of damaging the filter
(either a mesh screen or a fiber construction, don't know what they
use these days); 2) The filter doesn't get to do it's job: filtering
out impurities in the ink that may just happen to be there. If you
fill from the top, the ink has to flow past the filter before it can
enter the head. From the bottom, all the junk can get trapped below
the filter and turn around and exit as cart is used into the head.
Perhaps the cart design has changed to prevent top vacuum filling? Or
you don't want to invest the $$ and effort (it is more complicated)?
In the files section of this list somewhere there is a detailed 7 page
pdf I wrote quite some time ago on instructions for (top) vacuum
filling of carts. I don't know if it would still be up-to-date. And I
was too lazy to include pictures. But it describes the method I used
to fill most of my carts and I rarely had a problem. It is far more
detailed then MIS instructions were. Just about all the parts are
available (or were) from MIS.
Also with vacuum filling you don't have to mess with rivits, the seals
stay intact until carts are installed.
> the hardware store)
or just buy from MIS to be sure you get the right diameter. There was
some speculation as to whether using the MIS rivets would over time,
destroy the seal through expansion. The rivits are larger in diameter
than the nipples in the head (the things that receive the ink from the
cart by sticking through the cart seals- conducting it into the head).
Then the CIS folks were offering an $$ alternative with nipple sized
pins embedded in plastic. The only problem was the ink attacked the
plastic and cracked it very quickly!
I don't think anything was ever determined, and I've used the MIS
rivits just fine.
> into the carts.
MIS sold that as a "bottom fill adapter". Very cheap if they still
have it. Let me know if you can't find it I may have an extra one, not
sure.
> available locally?
I wouldn't take chances on a jury-rig because of the possibility of
damage to the filter as stated above. I strongly emphasise this, but
again this is just the teutonic way I work.
I understand the excitement, or perhaps you are working under a
deadline for a client. I feel the same way, but it can be painful if I
rush things without having the right parts, if I jury rig a tool it
may not work right. Still, of course use your own judgement.
> installation?
Mandatory they be removed before install. Otherwise the carts wouldn't
even go in. The seals have to slip over the head nipples, and for this
they need a hole, not a hunk of impassable metal greeting them as you
press the carts down. How would the ink come out either? The rivits
come out well if you have a solid fingernail, or if you've chewed them
off in nervousness first :-), I will sometimes use a small swiss army
knife to get them started then pull the remainder with my finger.
Pulling out three from the color cart without getting ink leaking all
over is much easier than you think- it doesn't flow out that fast. But
have a paper towel or two handy to be safe.
Jim Hayes
> Thanks,
> Jenny
Re: CIS with 1160
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "jim hayes"
OOPS!!!
Well, that was a big mistake on my part, droning on about filling carts.
I should have looked at the title and realized you're filling a CIS.
Actually I got thrown off by the talk about bottom filling and rivits.
It sounds like this CIS is being filled for at least the second time
then. Well I guess some of my comments still apply, like the bottom
fill adapter remark. Top vacuum filling would not work.
Anyway sorry for the bandwith. I'll try to remember to have the coffee
before I read messages.
Jim Hayes
Re: CIS with 1160 - Bottom Fill
Hi Jenny, Jim and all,
This is indeed a lively thread -- great responses from everyone, and
since this information applies to Jenny's 1160 and most other CIS
installations, it's good to have this info available for all...
Jim, I understand your response about the "bottom-fill" question, and
it may cause confusion for Jenny and others as well. Just to clarify:
The misnomer here is the term "bottom-fill", which applies to the
name MIS uses for the syringe adapter rather than the method of using
it to recharge a CIS system. The adapter is tapered to provide a
tight fit to the opening on the bottom of the cart, as well as to
activate the poppet valves if your CIS has Epson-type cart seals.
However, the actual process used to recharge a CIS using this method
is to draw ink OUT of the cartridge through the bottom port and into
the syringe -- i.e. leave the feed tubes connected and attached to
their feed bottles, removing the carts, plugging the holes with
rivets so the ports not being worked on do not leak, and then one at
a time, removing the rivet from a chamber and drawing ink INTO the
syringe, thereby creating a mild vacuum in the cart and drawing ink
out of the bottles, through the feedlines and into the cart and
syringe.
You don't actually by-pass the protective foam and screen that the
cart uses to keep foreign matter out of the printheads because you're
not actually injecting ink from the bottom for a CIS configuration.
But those are very good points and because of the "bottom-fill"
adapter's name, might save someone a lot of grief if they interpret
the name literally ;>)
This process needs to be repeated with each chamber/cart, and the
rivet replaced after "suctioning" ink into the cart so it doesn't
drip while you're working on the next chamber, etc. Also, you may
have to draw more than one syringe-full of ink through the bottom
port to clear foam and get a good fill (recommended), so the excess
ink can be simply dumped back into the originating bottle. Be
careful here to not mix up the inks, and draw the syringe very slowly
to prevent excess vacuum and cross-contamination from occurring
between the chambers.
This can be a fairly messy process, so make sure your work area is
well protected, you're wearing gloves and you don't mind a bit of ink
splattering about. It washes off pretty easily, but not from carpets,
walls and other porous surfaces. Windex (the original with ammonia)
helps on clean-up quite a bit.
Other good suggestions provided by Jim, Mark and Bob include the
printing of purge/test patterns after the procedure is complete,
running cleaning cycles if they're not "good", letting things sit for
6 hours or even overnight if the patterns aren't good right away, and
very importantly, making sure there is an "air-break" in the carts
after filling -- you don't want them to be 100% full. MIS
instructions for restoring the air-break are here:
http://www.inksupply.com/index.cfm?source=html/cobratrouble.html#4
I think everyone who uses a bulk feed system goes through this
process at some point, either at installation time or for routine
maintenance somewhere down the line. The new MIS UT inks seem to be
much more trouble-free and require less CIS/CFS tinkering, but the
basic principles of operation and maintenance are good to know.
In this case, Jenny, you're just getting your education a bit early
and probably sooner than you would have preferred ;>) However, as
Mark said, "there is no science to this stuff", just some basic
principles usually learned with the help of the good people on forums
like this or at MIS, and a few ink stains under your fingernails just
to show you're a veteran ;>)
Good luck to you, Jenny -- and to all who go through this same
process in the worthwhile endeavor to get their systems feeding
properly. When they work right (and they will), they work great!!
 -Richard
P.S. Jenny, you mentioned you were having some banding on one of your
1160's (which may be resolved by just letting it sit and "settle
in"), but it would be good to also review the thread that is now
running called "clogged 1280". There is some great info there about
how to maintain the exterior components of the print heads on any
Epson desktop printer, break up actual clogs, etc.
filling
> OOPS!!!
carts.
rivits.
coffee
> Jim Hayes
I am really amazed at all of the helpful information from you guys.
If I had written here last Monday, instead of to IJM, I would be
printing by now!  I can't find an adapter to insert into the carts
so it looks like I will be ordering from MIS.
Richard ... thanks for the clarifications and for the tips about the
1280 thread.
Thanks!!!!
Jenny
