Digital BW, The Print
Epson 1270 vs 1280 for UT2 inkset
2004-04-12 by Arthur Fink
I'm thinking of getting a used Epson 1270 on Ebay to dedicate to black and
white printing.  The 1270 seems like a good bargin right now.  How does it
compare to the 1280 for use with the LU2 inkset (or should I be using
LU1)?  I expect to be using matt surface paper only -- probably Hanemule
photo rag 308 -- so performance on glossy papers doesn't concern me at all.
Any other comments about the choice between these two printers?
  A r t h u r    F i n k      P h o t o g r a p h y
  Ten New Island Avenue     · 207.766.5722
  Peaks Island, Maine 04108 · arthur@...
Re: Epson 1270 vs 1280 for UT2 inkset
2004-04-12 by wolarsky
I have both the 1270 and 1280. I tested the 1270 with UT2 and found
that the 1280 gives significantly better results. The problem with
the 1270 and black-and-white printing is that its just not well
supported by any of the workflows. This means that you will land up
wasting a great deal of time, ink, and paper. A reconditioned Epson
from the Epson website for $325 will provide much better value.
Evan
-- In DigitalBlackandWhiteThePrint@yahoogroups.com, Arthur Fink
black and
does it
using
Hanemule
at all.
>   Peaks Island, Maine 04108 · arthur@a...
