Digital BW, The Print
Settings for BO printing
2004-02-14 by Peter A. Klein
Does anyone have some ballpark settings of the Epson 1280 driver for
BO (black only) printing.  I'm out of hextones and am awaiting a
shipment from MIS, and I want to experiment.
Epson 1280, Epson Matte Heavy paper (supposedly same response as
EEM).  I want to fool around with both the OEM Epson black dye ink
and MIS Eboni.
I had beautiful prints with MIS VM.  Right now with BO I've got a
nice looking gray scale when I print a step wedge, but things in the
mid-high range (like flesh tones) are printing a "zone" or more too
dark.  Brightness, contrast, gamma?
Also, do I need to mess with color space settings in Picture Window
Pro?  I don't use color management, but I've got the working space
set at Adobe RGB 1998 as per the hextone workflow.
--Peter
Re: Settings for BO printing
2004-02-14 by Bob Michaels
I find that using no color profile and setting the printer for 10% dot
gain is the trick for 1280 / Eboni / EEM.
Bob Michaels
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Peter A. Klein"
> and MIS Eboni.
> Thanks,
> --Peter
2004-02-14 by Clayton Jones
Hello Peter,
>dark.
Several things going on here, probably the work space/printer profile
settings are what's doing it.  To have full control in BO printing
I've found it's best to keep the image in Grayscale.  This limits the
work space setings (the "front end" profile) to the Dot Gain/Gray
Gamma choices.
Briefly, you set the printer profile (the "back end" profile) to "Same
As Source".   This ensures that whatever front end profile you choose
doesn't affect the print.  Then you set the front end profile to
whatever setting makes the monitor image best match the print (trying
for good WYSIWYG).  If you aren't sure which to use, I recommend Dot
Gain 20% as a good starting point because it's in the middle of the
range of the available settings.  Once that is established, if you are
unhappy with the print you make changes to the image.
If this all sounds confusing, it is explained in much better detail in
article #4 on the web site link below.
Clayton
2004-02-15 by Peter A. Klein
Thanks, Bob and Clayton.  When you both mentioned dot gain, I
thought, "Wait a minute, I'm using Picture Window Pro, not Photoshop,
and it doesn't do dot gain."  Then I realized that Paul Roarke had
included a grayscale printing curve with some of his inksets. Hmm, I
thought, maybe that does what the dot gain profiles do.
I had one from the Epson 1290 VM set, so I ran a grayscale image
through it, and things got a lot lighter on the screen.  It just
finished printing as I write this, and things are looking a whole lot
better.
Thanks for jogging my memory in the right direction!
--Peter
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones"
<cj@c...> wrote:
> Hello Peter,
for
too
> >dark.
Window
space
profile
> Gamma choices.
to "Same
choose
(trying
are
in
> Regards,
> Clayton
2004-02-15 by Manuel Toledo Quinones
For BO using Picture Windows, I use the following settings in the
Epson drive:
Media type: photo paper
Print Quality: SuperPhoto at 2880
Color Controls set
Gamma: 1.0
Brightness: +2
Contrast:0
For many images, with this settings I get reasonable agreement between
print and monitor.
Have fun!
Manuel
> better.
> --Peter
> <cj@c...> wrote:
> > Hello Peter,
> for
> the
> too
> > >dark.
> Window
> space
> profile
> the
> > Gamma choices.
> to "Same
> choose
> (trying
> are
> in
> > Regards,
> > Clayton
2004-02-16 by Peter A. Klein
A big thank-you to everyone who replied to my queries about Black-
Only printing on an Espon 1280.  I use Picture Window Pro, which
doesn't do dot gain.  So I couldn't use Clayton's workflow.  But it
jogged my memory.  I recalled that Paul Roark had created a
grayscale curve for the Epson 1290 VM inkset.  It's in the files
section of this group here:
Files, Ink Sets, MIS, MIX Variable Mix.  It's the last item:
Paul Roark's 1290 Curves for VM and Sepia VM.ZIP  The curve for BO
printing is the one with "gs" in the name.
This 1290 curve works beautifully for BO on my 1280 (they are
essentially the same printer).  With images that had a lot of tonal
adjustment, I found that it was sometimes best to apply the curve
with the file still at 16 bits/pixel, and to do final sharpening
afterward as well.
For Picture Window (Pro) users:  You have to convert your image file
to RGB before PWP will load the curve file.  To avoid this, I
converted the Photoshop ACV file to a PWP grayscale .CRV file.  If
anyone is interested and Paul has no objection, I can post the curve
here (someone please tell me how).
My Epson 1280 driver settings are:
Ink:         Black
Media Type:  Epson Photo paper (to print at 2280 dpi)
             Epson Matte Heavyweight (to print at 1440 dpi)
Speed:       1440 or 2880 dpi
Gamma:       2.2
Bright:      0
Contrast:    0
(Manuel:  My driver only has gamma options for 1.5, 1.8 and 2.2.
There is no 1.0 setting)
Print quality is beautiful.  Nice deep blacks and luminous
highlights.  2880 dpi is a bit smoother than 1440.  I prefer 2880
when there are small human faces in the print, because the eye tends
to see the dots at 1440 as it tries to make out facial features. That
said, you only notice the dots if you look hard.  My wife actually
preferred the BO print when I showed her a 1440 BO print side-by-side
with a hextone of the same image:
http://www2.2alpha.com/~pklein/italy/MadonChildChant.htm
On the other hand, this picture looked better in hextone:
http://www2.2alpha.com/~pklein/italy/siblingrival_bw.htm
2880 dpi BO was almost as good as hextone, but the little girl's face
was a bit rough-looking at 1440 dpi BO.
--Peter Klein
Seattle, WA
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Manuel Toledo
> Epson drive:
> Color Controls set
> Gamma: 1.0
> Brightness: +2
> Contrast:0
between
> print and monitor.
> Have fun!
> Manuel
Klein"
Photoshop,
had
Hmm, I
lot
> > better.
> > --Peter
Jones"
> > <cj@c...> wrote:
> > > Hello Peter,
driver
> > for
got a
in
> > the
more
> > too
> > > >dark.
> > Window
> > space
> > profile
printing
limits
> > the
Gain/Gray
> > > Gamma choices.
> > to "Same
> > choose
> > (trying
recommend Dot
you
> > are
detail
> > in
> > > Regards,
> > > Clayton
2004-02-16 by Bob Michaels
Peter: You set the dot gain in the printer driver, not the image
editor. It's unrelated to you using PWP instead of PS.
For your 1280, click "print with preview" then under "print space"
change the "same as source" to 10%, 15% or 20% percent dot gain
(whichever makes your prints look like your screen), then proceed with
printing your image. Instant WYSIWYG.
Of course Clayton explains this in detail.
Bob Michaels
RE: [Digital BW] Re: Settings for BO printing
2004-02-17 by Paul D. DeRocco
> From: Bob Michaels [mailto:bob@...]
Print With Preview is part of Photoshop.
Ciao,               Paul D. DeRocco
Paul                mailto:pderocco@...
2004-02-17 by Bob Michaels
Paul: I learn something new every day. I guess my world is too narrow
being limited only to PS/Epson driver.  Is there no way to set the
printer driver to anything other than "same as source" when using PWP
or anything other than PS?
Bob Michaels
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul D. DeRocco"
<pderocco@i...> wrote:
> > From: Bob Michaels [mailto:bob@b...]
> Paul                mailto:pderocco@i...
