2018-10-30 by paulmwhiting@...
Thanks Paul,
The profile I'm using is one of yours, EbVT-PA-FA205-Neutral. (For the benefit of a wider readership, it makes use of the Y cartridge filled with a blue toner to make the print less warm.) For space reasons here I'm only posting the Neutral version. Since we're talking about tweaking the Cyan cart to compensate for its clogs, I think it's only necessary to show one profile. I could have just as well posted the Warm version. I usually print using both curves at 50% - I like having being able to change the warm-cool mix to my tastes.
Paul W.
#Notes Feb 20, 2016
#Notes Rob de Loe
#Notes
#Notes Paul Roark's generic curve is starting point
#Notes Instead of using supplied values, I re-calibrated everything.
#Notes Uses M and LM as toner curves; total ink load of 40 is divided between them
#Notes Paul's generic assumed ink limit of 35, but I read 40 (so limits for toners are 20) and limit for Y is
#Notes 40/2.5=16
#Notes Linearized and had to fudge the darkest value; the ColorMunki read 19; it normally dries down by 0.2
#Notes so I dropped it down to 18.8 and it linearized fine. The curves look ugly, but it works
#Notes Y is a load curve that runs across the whole thing; his original neutral curve was designed for 10%
#Notes Y, but I'm using 25% Y so divided by 2.5 to get to 16.
#Notes
PRINTER=Quad1400-MIS
CURVE_NAME=EbVT-PA-FA205-Neutral
GRAPH_CURVE=YES
N_OF_INKS=6
DEFAULT_INK_LIMIT=40
BOOST_K=45
LIMIT_K=40
LIMIT_C=30
LIMIT_M=20
LIMIT_Y=16
LIMIT_LC=20
LIMIT_LM=20
N_OF_GRAY_PARTS=3
GRAY_INK_1=K
GRAY_VAL_1=100
GRAY_INK_2=C
GRAY_VAL_2=55
GRAY_INK_3=LC
GRAY_VAL_3=24
GRAY_HIGHLIGHT=10
GRAY_SHADOW=10
GRAY_OVERLAP=
GRAY_GAMMA=1
GRAY_CURVE=
N_OF_TONER_PARTS=2
TONER_INK_1=M
TONER_VAL_1=39
TONER_INK_2=LM
TONER_VAL_2=17.5
TONER_HIGHLIGHT=10
TONER_SHADOW=10
TONER_GAMMA=1
TONER_CURVE=
N_OF_TONER_2_PARTS=0
TONER_2_HIGHLIGHT=10
TONER_2_SHADOW=10
TONER_2_GAMMA=1
TONER_2_CURVE=
N_OF_UNUSED=0
CURVE_Y="0;0 10;4.7 20;13 30;22 40;31 50;46 60;61 70;85 75;91 80;89 85;81 90;61 95;35 100;0 """""""""
LINEARIZE="95.808479 92.117378 87.917824 83.138885 77.696144 72.914581 66.704521 60.622429 55.298779 49.439247 43.184006 38.032261 33.246773 29.592039 26.246315 23.846638 22.383198 20.462576 18.758568 17.984755 17.808918 "
