Epson 1430 Issues
2018-10-19 by homershannon@...
My Epson 1430 is on the fritz. This is my color machine - I use a 1400 for B+W, but I'm hoping my issue is something that is seen with black and white printers using the 1430.
In the process of clearing some banding issues today (normal stuff), I wound up with the paper light and the ink light alarms on and flashing in synchrony. I searched the web for this condition and the closest I could find was these two lights alternating, which is an error code for a software upgrade failure. I did not do any software updating today.
I tried the "leave it un-powered for a while" trick and that did not help. I've also noted that on a restart, the machine goes through its normal start up cycle and then ends up with the ink light on. Usually, this means that one of the non-epson cartridges is not reading properly. The fix for this is to press the ink button, wait till the printer head parks and then re-install whichever cartridge has an alarm light on. Normally, after this cycle the printer runs a cleaning cycle and returns to normal operation.
Today, however, after start up, I get the ink error but after the above described correction, the machine goes to the flashing paper and ink lights and locks up.
Any ideas as to what is happening and what the fix is?
