Digital BW, The Print
Epson 2000P Hex or Quad MIS Inkset ?
2017-08-13 by a_pettit_jr@...
I believe I was correct in reading an article on Paul Roark's website about using a quad set in the 2000P
The replacement was
K Black
C DarkGrey
M DarkGrey
LC MedGrey
LM MedGrey
Y LightGrey
From studying a CMYK print-ready image it would seem to me that
C and LC should be DarkGrey and
M and LM should be MedGrey ..
Comments ?
Thanks !
Alex P
Re: [Digital BW] Epson 2000P Hex or Quad MIS Inkset ?
2017-08-13 by Paul Roark
I'd have the dark grays in M and C. With no Photoshop curves or separate rip (QTR), the Epson driver is going to start at the light end with Y, LM and LC. As you get in to dark shadows, the LC and LM will cross over to C and M, which should be appropriately darker.
In a color inkset the Y is high gamut but low density. You can usually profile a fairly wide range of densities there. Light gray will obviously give the smoothest highlights, but not much Y is used in the highlights, so you can get away with a medium density ink there.
Good luck.
Paul
On Sun, Aug 13, 2017 at 10:46 AM, a_pettit_jr@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
The replacement was
K Black
C DarkGrey
M DarkGrey
LC MedGrey
LM MedGrey
Y LightGrey
Comments ?
Thanks !
Alex P
Hello Paul,
I am trying to remember what I did .. 15+ years ago.
When I apply the MIS FS .acv profiles, I transform the BW into a KCMY
color file .. It is obvious the C and M equate to quite different darkness levels - I just am not able to understand were the LC and LM fit in a hex set.
Should I try a mix based on your 3880 formula
LM = 6% MK (Eb6-LM)16
M = 18% MK (Eb6-M)
LC = 9% MK (Eb6-LC)
C = 30% MK (Eb6-C)
LK = 18% MK (Eb6-M)
LLK = 6% MK (Eb6-LM)
K = 100% MK (Eb6-K)
using perhaps
K = 100
C = 30
M = 18
LC & LM = 9 ?
Y = 6 ?
I don't remember the old 2000P Hex dilution ratios.
Alex
The 2000p is a fairly standard 6 ink printer, as I recall. As such, the 3880 formula, dropping the LK and LLK, of course, should work. A very normal dilution step between a dark ink and a lighter ink is: light ink = 30% dark ink + 70% dilution base. Having the light ink be 33.3% (1/3) the density of the darker ink is close enough and works very well. The Y is flexible. It's a great place for a light blue toner to cool the warm (yellowish) carbon, or it can be a repeat of one of the light carbon positions if you want 100% carbon.
Paul
On Sun, Aug 13, 2017 at 1:23 PM, a_pettit_jr@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
Hello Paul,
M = 18% MK (Eb6-M)
LC = 9% MK (Eb6-LC)
C = 30% MK (Eb6-C)
LK = 18% MK (Eb6-M)
K = 100% MK (Eb6-K)
using perhaps
K = 100
C = 30
M = 18
LC & LM = 9 ?
Y = 6 ?
I don9;t remember the old 2000P Hex dilution ratios.
Alex
