eboni 6 & R2000 ink positions
2016-11-10 by bakerstrt@...
I want to install eboni 6 ink in an Epson r2000 and was wondering which eboni ink goes in which position in the printer? I will be making my own profiles so maybe the order doesn't matter? Can anyone confirm this?
Michael V
2016-11-10 by Paul Roark
I am not at home, but take a look at the Eboni -1800.pdf. The URL will be my usual paulroark.com/BW-Info/Eboni -1800.pdf (or something close - Google it). What I found is that with the printers like the R1800, you can have Epson drive compatibility by arranging the ink order following the color wheel. The PDF explains it. That compatibility is useful for ICCs and applications where you can not use QTR.
Paul
ThanksMichael V
2016-11-10 by m venz
Thanks Paul, I found it.
http://www.paulroark.com/BW-Info/Eboni-6-1800.pdf
Michael
Paul
ThanksMichael V
2016-11-10 by richard@...
I am working on a new version that will allow profiles to be made with up to 8 partitions in the 10 ink printers.
There are two versions. The standard one will simply speedup/automate the profile creation process without needing to enter a single thing in the QTRgui—the qidf profiles are generated for you and double clicking them on Windows will install the quad curves without the Windows 10 show curves bug.
The deluxe version has tools for reshaping the QTR-generated quad curves to make longer smooth leading and trailing edges without introducing unwanted or inconsistent ink load. It also has some advanced quad linearization tools that allow you to specify a set of target input and output points and see the quad curves change in real time.
It works with on both macOS and Windows, but with Excel only (because of the nature of the macros and user defined functions) and really cuts down on the time and paper used in generating these kinds of profiles.
Hope that helps,
Richard Boutwell
http://www.richardboutwell.com/
Thanks Richard.
I purchased this the other day (deluxe version) and have just begun reading the instructions with a yiew to working through it over the next couple of days.
Cheers
Michael
2016-11-13 by jerry dungan
Michael, -------------------------------------------- On Thu, 11/10/16, m venz bakerstrt@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
Subject: Re: [Digital BW] eboni 6 & R2000 ink positions
To: "DigitalBlackandWhiteThePrint@yahoogroups.com" <DigitalBlackandWhiteThePrint@yahoogroups.com>
Date: Thursday, November 10, 2016, 12:04 AM
100%
Eboni Carbon Pigment Printing For the Epson R1800
www.paulroark.com
100% Eboni Carbon Pigment Printing For the Epson R1800 Paul
Roark 9-17-08 Pure, 100% carbon pigment printing has become
a more powerful and flexible system
Michael,
Does the ink sequence for the R1800 with Eboni 6-VTfrom the information at that link turn out to be:
Toner
6% MK
9% MK
MK
MK
18%MK
30%MK
MK
The linked page seems to state that's the set up because the 3 100%MK positions are locked in, so just checking on where to place each of the Eboni inks.
Jerry
<DigitalBlackandWhiteThePrint@yahoogroups.com> on
behalf of Paul Roark roark.paul@...
Sent: Thursday, 10 November 2016 18:43
To: DigitalB&WPrint
positions
QTR.
Paul
On Nov 9, 2016 8:47
PM, "bakerstrt@hotmail.com
[DigitalBlackandWhiteThePrint] " <DigitalBlackandWhiteThePrint@
yahoogroups.com>
this?
Michael V
#yiv8393379376 #yiv8393379376 --2016-11-13 by jerry dungan
Michael, Seems I lost my earlier query somewhere ? The question was about the ink loading sequence on the R1800 in the link you provided. That very informative report says to sequence the Eboni 6 from lightest to darkest and the MK goes into the MK, PK and GL positions. Does that turn out to mean the sequence for the Eboni 6VT + 3 MK is: Toner 6% MK 9% MK 18% MK MK MK 30% MK MK Thanks for the patience with this. Jerry -------------------------------------------- On Sat, 11/12/16, jerry dungan jerry_4y@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
Date: Saturday, November 12, 2016, 6:03 PM
Michael,
positions
To:
100%
www.paulroark.com
Paul
become
Michael,
Toner
6% MK
9% MK
MK
MK
18%MK
30%MK
MK
Jerry
To: DigitalB&WPrint
positions
printers
by
PDF
use
QTR.
Paul
On Nov 9, 2016 8:47
PM, "bakerstrt@...
yahoogroups.com>
this?
Michael V
#yiv8393379376 #yiv8393379376 --2016-11-13 by Paul Roark
2016-11-13 by m venz
Hi Jerry,
I am not using the VT version (just the plain one). The instructions said to order inks according to the colour wheel if you want to use the Epson driver. I will be using QTR and making my own curve/profile so it appears not to matter.
Michael
Michael,
100%
www.paulroark.com
Michael,
Toner
6% MK
9% MK
MK
MK
18%MK
30%MK
MK
Jerry
on
To: DigitalB&WPrint
positions
QTR.
Paul
On Nov 9, 2016 8:47
PM, "bakerstrt@...
yahoogroups.com>
this?
Michael V
#yiv8393379376ygrp-mkp {
0;padding:0 10px;}
#yiv8393379376 #yiv8393379376ygrp-mkp hr {
border:1px solid #d8d8d8;}
#yiv8393379376 #yiv8393379376ygrp-mkp #yiv8393379376hd {
0;}
#yiv8393379376 #yiv8393379376ygrp-mkp #yiv8393379376ads {
margin-bottom:10px;}
#yiv8393379376 #yiv8393379376ygrp-mkp .yiv8393379376ad {
padding:0 0;}
#yiv8393379376 #yiv8393379376ygrp-mkp .yiv8393379376ad p {
margin:0;}
#yiv8393379376 #yiv8393379376ygrp-mkp .yiv8393379376ad a {
#yiv8393379376 #yiv8393379376ygrp-sponsor
#yiv8393379376ygrp-lc {
font-family:Arial;}
#yiv8393379376ygrp-lc #yiv8393379376hd {
margin:10px
#yiv8393379376ygrp-lc .yiv8393379376ad {
#yiv8393379376 #yiv8393379376actions {
#yiv8393379376 #yiv8393379376activity {
#yiv8393379376 #yiv8393379376activity span {
font-weight:700;}
#yiv8393379376 #yiv8393379376activity span:first-child {
text-transform:uppercase;}
#yiv8393379376 #yiv8393379376activity span a {
#yiv8393379376 #yiv8393379376activity span span {
color:#ff7900;}
.yiv8393379376underline {
text-decoration:underline;}
#yiv8393379376 .yiv8393379376attach {
0;width:400px;}
#yiv8393379376 .yiv8393379376attach div a {
#yiv8393379376 .yiv8393379376attach img {
#yiv8393379376 .yiv8393379376attach label {
#yiv8393379376 .yiv8393379376attach label a {
#yiv8393379376 blockquote {
margin:0 0 0 4px;}
#yiv8393379376 .yiv8393379376bold {
#yiv8393379376 .yiv8393379376bold a {
#yiv8393379376 dd.yiv8393379376last p a {
#yiv8393379376 dd.yiv8393379376last p span {
span.yiv8393379376yshortcuts {
margin-right:0;}
#yiv8393379376 div.yiv8393379376attach-table div div a {
#yiv8393379376 div.yiv8393379376attach-table {
width:400px;}
#yiv8393379376 div.yiv8393379376file-title a, #yiv8393379376
div.yiv8393379376file-title a:active, #yiv8393379376
div.yiv8393379376file-title a:hover, #yiv8393379376
div.yiv8393379376file-title a:visited {
#yiv8393379376 div.yiv8393379376photo-title a,
#yiv8393379376 div.yiv8393379376photo-title a:active,
#yiv8393379376 div.yiv8393379376photo-title a:hover,
#yiv8393379376 div.yiv8393379376photo-title a:visited {
#yiv8393379376 div#yiv8393379376ygrp-mlmsg
#yiv8393379376ygrp-msg p a span.yiv8393379376yshortcuts {
#yiv8393379376 .yiv8393379376green {
color:#628c2a;}
#yiv8393379376 .yiv8393379376MsoNormal {
margin:0 0 0 0;}
#yiv8393379376 o {
font-size:0;}
#yiv8393379376 #yiv8393379376photos div {
float:left;width:72px;}
#yiv8393379376 #yiv8393379376photos div div {
border:1px solid
#666666;height:62px;overflow:hidden;width:62px;}
#yiv8393379376 #yiv8393379376photos div label {
#yiv8393379376 #yiv8393379376reco-category {
font-size:77%;}
#yiv8393379376 #yiv8393379376reco-desc {
font-size:77%;}
#yiv8393379376 .yiv8393379376replbq {
margin:4px;}
#yiv8393379376 #yiv8393379376ygrp-actbar div a:first-child {
#yiv8393379376 #yiv8393379376ygrp-mlmsg {
sans-serif;}
#yiv8393379376 #yiv8393379376ygrp-mlmsg table {
font-size:inherit;font:100%;}
#yiv8393379376 #yiv8393379376ygrp-mlmsg select,
#yiv8393379376 input, #yiv8393379376 textarea {
#yiv8393379376 #yiv8393379376ygrp-mlmsg pre, #yiv8393379376
code {
font:115% monospace;}
#yiv8393379376 #yiv8393379376ygrp-mlmsg * {
line-height:1.22em;}
#yiv8393379376 #yiv8393379376ygrp-mlmsg #yiv8393379376logo {
padding-bottom:10px;}
#yiv8393379376 #yiv8393379376ygrp-msg p a {
font-family:Verdana;}
p#yiv8393379376attach-count span {
#yiv8393379376 #yiv8393379376ygrp-reco
#yiv8393379376reco-head {
#yiv8393379376 #yiv8393379376ygrp-reco {
#yiv8393379376 #yiv8393379376ygrp-sponsor #yiv8393379376ov
li a {
li {
ul {
margin:0;padding:0 0 0 8px;}
#yiv8393379376 #yiv8393379376ygrp-text {
font-family:Georgia;}
#yiv8393379376 #yiv8393379376ygrp-text p {
margin:0 0 1em 0;}
#yiv8393379376 #yiv8393379376ygrp-text tt {
font-size:120%;}
#yiv8393379376 #yiv8393379376ygrp-vital ul li:last-child {
border-right:none !important;
#yiv8393379376
Paul, Thanks as always for your time on an answer for a well running but older system. I'll set the R1800 up the following way, putting in the original idea of the 2% instead of a toner at Y, and see how it goes: 2% 6% 9% MK MK 18% 30% MK And definitely Yes, QTR is the easier way to go. Jerry -------------------------------------------- On Sun, 11/13/16, Paul Roark roark.paul@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
To: "DigitalB&WPrint" <DigitalBlackandWhiteThePrint@yahoogroups.com>
Date: Sunday, November 13, 2016, 8:04 AM
I note that the ink order
below includes a toner. I think my initial comment to the
OP was about ink order related to Eboni-6, which I read as
not including a toner. I am not sure my "follow the
color wheel" approach to make Eboni-6 on this class of
printer (which I believe to be in the same general family as
the old R1800) Epson driver compatible will work if there is
a toner in the inkset. I probably posted some profiles for
Eb6 in the R1800 that assumed 2% MK in Y. Those profiles
will cause the highlights to be way too cool if Y has a
light blue toner in it.
With the standard hextone
printers, the blue Photoshop curve can easily control yellow
position ink. Thus my recent variable tone inksets usually
work very well with that toner position. And if I had an
R2000, I'd still start with the color wheel
positioning. It may take some experimenting to see how the
setup works with the toner, however. The Epson drivers for
these printers that include more than the standard CMY
colors don't fit the Photoshop curves model as directly
as the hextone printers.
QTR control is almost
always the easier way to go.
Paulwww.PaulRoark.com
Jerry wrote:
>The question was
you>
the Eboni 6 from lightest to >darkest and the MK
to > mean
>Toner>6% MK>9% MK>18% MK>MK>MK>30% MK>MK
#yiv3374244924 #yiv3374244924 --2016-11-13 by jerry dungan
Hi Michael, Yes, dropping the toner and staying with the original concept of the Eboni 6 and the color wheel will be how I set my printer up. I'll also work up a QTR profile for the EB6. That and using the the available 3 MK profiles as the 2nd profile at the QTR print stage will be something to look forward to. It'll be 2% 6% 9% MK MK 18% 30% MK as in the paper by Paul. Thanks for your reply Jerry -------------------------------------------- On Sun, 11/13/16, m venz bakerstrt@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
Date: Sunday, November 13, 2016, 11:06 AM
Hi Jerry,
matter.
Michael
behalf of jerry dungan jerry_4y@...
Sent: Sunday, 13 November 2016 15:03
positions
Michael,
positions
100%
www.paulroark.com
Paul
become
Michael,
Toner
6% MK
9% MK
MK
MK
18%MK
30%MK
MK
Jerry
To: DigitalB&WPrint
positions
printers
PDF
QTR.
Paul
On Nov 9, 2016 8:47
PM, "bakerstrt@...
yahoogroups.com>
this?
Michael V
#yiv8393379376 #yiv8393379376 --2016-11-14 by Paul Roark
Paul,
2%
6%
9%
MK
MK
18%
30%
MK
Jerry
Date: Sunday, November 13, 2016, 8:04 AM>Toner>6% MK>9% MK>18% MK>MK>MK>30% MK>MK
Jerry wrote:
>The question was
you>
to > mean
#yiv3374244924ygrp-mkp {
0;padding:0 10px;}
#yiv3374244924 #yiv3374244924ygrp-mkp hr {
#yiv3374244924 #yiv3374244924ygrp-mkp #yiv3374244924hd {
0;}
#yiv3374244924 #yiv3374244924ygrp-mkp #yiv3374244924ads {
#yiv3374244924 #yiv3374244924ygrp-mkp .yiv3374244924ad {
padding:0 0;}
#yiv3374244924 #yiv3374244924ygrp-mkp .yiv3374244924ad p {
margin:0;}
#yiv3374244924 #yiv3374244924ygrp-mkp .yiv3374244924ad a {
#yiv3374244924 #yiv3374244924ygrp-sponsor
#yiv3374244924ygrp-lc {
font-family:Arial;}
#yiv3374244924ygrp-lc #yiv3374244924hd {
margin:10px
#yiv3374244924ygrp-lc .yiv3374244924ad {
#yiv3374244924 #yiv3374244924actions {
#yiv3374244924 #yiv3374244924activity {
#yiv3374244924 #yiv3374244924activity span {
font-weight:700;}
#yiv3374244924 #yiv3374244924activity span:first-child {
#yiv3374244924 #yiv3374244924activity span a {
#yiv3374244924 #yiv3374244924activity span span {
color:#ff7900;}
.yiv3374244924underline {
#yiv3374244924 .yiv3374244924attach {
0;width:400px;}
#yiv3374244924 .yiv3374244924attach div a {
#yiv3374244924 .yiv3374244924attach img {
#yiv3374244924 .yiv3374244924attach label {
#yiv3374244924 .yiv3374244924attach label a {
#yiv3374244924 blockquote {
margin:0 0 0 4px;}
#yiv3374244924 .yiv3374244924bold {
#yiv3374244924 .yiv3374244924bold a {
#yiv3374244924 dd.yiv3374244924last p a {
#yiv3374244924 dd.yiv3374244924last p span {
span.yiv3374244924yshortcuts {
margin-right:0;}
#yiv3374244924 div.yiv3374244924attach-table div div a {
#yiv3374244924 div.yiv3374244924attach-table {
width:400px;}
#yiv3374244924 div.yiv3374244924file-title a, #yiv3374244924
div.yiv3374244924file-title a:active, #yiv3374244924
div.yiv3374244924file-title a:hover, #yiv3374244924
div.yiv3374244924file-title a:visited {
#yiv3374244924 div.yiv3374244924photo-title a,
#yiv3374244924 div.yiv3374244924photo-title a:active,
#yiv3374244924 div.yiv3374244924photo-title a:hover,
#yiv3374244924 div.yiv3374244924photo-title a:visited {
#yiv3374244924 div#yiv3374244924ygrp-mlmsg
#yiv3374244924ygrp-msg p a span.yiv3374244924yshortcuts {
#yiv3374244924 .yiv3374244924green {
color:#628c2a;}
#yiv3374244924 .yiv3374244924MsoNormal {
margin:0 0 0 0;}
#yiv3374244924 o {
font-size:0;}
#yiv3374244924 #yiv3374244924photos div {
#yiv3374244924 #yiv3374244924photos div div {
border:1px solid
#yiv3374244924 #yiv3374244924photos div label {
#yiv3374244924 #yiv3374244924reco-category {
font-size:77%;}
#yiv3374244924 #yiv3374244924reco-desc {
font-size:77%;}
#yiv3374244924 .yiv3374244924replbq {
margin:4px;}
#yiv3374244924 #yiv3374244924ygrp-actbar div a:first-child {
#yiv3374244924 #yiv3374244924ygrp-mlmsg {
sans-serif;}
#yiv3374244924 #yiv3374244924ygrp-mlmsg table {
#yiv3374244924 #yiv3374244924ygrp-mlmsg select,
#yiv3374244924 input, #yiv3374244924 textarea {
#yiv3374244924 #yiv3374244924ygrp-mlmsg pre, #yiv3374244924
code {
#yiv3374244924 #yiv3374244924ygrp-mlmsg * {
#yiv3374244924 #yiv3374244924ygrp-mlmsg #yiv3374244924logo {
#yiv3374244924 #yiv3374244924ygrp-msg p a {
p#yiv3374244924attach-count span {
#yiv3374244924 #yiv3374244924ygrp-reco
#yiv3374244924reco-head {
#yiv3374244924 #yiv3374244924ygrp-reco {
#yiv3374244924 #yiv3374244924ygrp-sponsor #yiv3374244924ov
li a {
li {
ul {
#yiv3374244924 #yiv3374244924ygrp-text {
#yiv3374244924 #yiv3374244924ygrp-text p {
margin:0 0 1em 0;}
#yiv3374244924 #yiv3374244924ygrp-text tt {
font-size:120%;}
#yiv3374244924 #yiv3374244924ygrp-vital ul li:last-child {
#yiv3374244924
2016-11-15 by jerry dungan
This is a very insightful reply and really nicely spells out the pitfalls of where I was headed with the Eboni 6 VT + 3MK. As I want to produce neutral prints as the first objective, the warning about the probable too warm output comes at just the right time as I haven't committed to the first set up runs. I'll now set up with the standard Eb6, with the 2 MK's and the toner substituting for the 3rd MK. As for the microbanding with the 1.5pl droplet, I ran across that unpleasant output on some negatives that where banding making them useless.There was some remedy from a technique suggested by Roy Harrington in 2005 to print at 2880dpi and adjust the Ink Limit Adjust to ~ -30. I dropped the boost K and upped the ink values a tad and all that seemed to help as the microbanding disappeared. But I never went on and printed out a variety of images to see how those were affected by the technique. So for this initial set up, it'll be EB6 + MK + Toner and see how it turns out. Lastly, is the toner the Canon Lucia referenced in your EB6 + R1800 paper or is there a compatible alternate blue toner ink that will work as well? So thanks as always for the insight and encouragement. Jerry -------------------------------------------- On Sun, 11/13/16, Paul Roark roark.paul@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
Date: Sunday, November 13, 2016, 7:03 PM
On Sun, Nov 13, 2016 at
the following way, putting in the original idea >of the 2% instead of a toner at
>2%
>6%
>9%
>MK
>MK
>18%
>30%
>MK
It'll be warm. My going to
a toner, in part, reflected the fact that I was not happy
with the way Eboni v.1.1 printed on inkjet paper. Arches
is still able to make a 100% carbon print that is within
what I believe people see as "neutral." Most
coated inkjet paper is no longer there; thus the
toner.
easier way to go.
If you are proficient in QTR, then
you can put inks in almost any position. You'll also
be able to put the toner in one of the spots that has MK
in it.
I was not a huge fan of the 3MK
approach. It was something that many liked because it
allowed them to have color printing with matte paper as well
as 100% carbon printing that was almost dead neutral. MK,
not diluted, is still very neutral. The 3 positions were
needed to hide microbanding.
What I'd probably end up doing
with such a printer now is have only 2 MK positions --
needed for best Arches printing as well as useful for making
dilute Eb6 100% carbon prints more neutral by having one of
the MK inks be a "Black Only" type ink, but used
more as a "toner" to pull the warmer dilute ink
image toward neutral. Note that while 2 MKs were needed to
hide microbanding when MK was the only ink, where the full
Eb6 inks are also in the mix, a single MK is going to be a
smoother way to pull the 100% carbon image toward neutral
than using the full 3MK profiles in conjunction with an Eb6
profile. As such, I'd put the toner where the third MK
would be. I'd use only QTR to print.
This is all easy to do piecemeal.
An Eb6 plus 3MK setup allows you to see how each approach
works. If you want more neutrality, the toner can be
easily added later.
Paul,
2%
6%
9%
MK
MK
18%
30%
MK
Jerry
positions
yahoogroups.com>
as
of
as
is
for
profiles
yellow
usually
an
for
directly
Jerry wrote:
>The question was
you>
sequence
out
to > mean
MK>MK
#yiv3374244924 #yiv3374244924 --2016-11-15 by Paul Roark
2016-12-13 by richard@...
2016-12-13 by Paul Roark
Something you might want to consider, especially since the R2000 is an 8-ink printer, is using a K5 set and put in LcLmY inks. You could swap out MK and PK and use a protective spray in place of a gloss optimizer—UV protection and anti-bronzing in one shot... That way you'll get far more toning options and all the benefit of quad(+) printing than using a single blue toner—everything from super warm sepia from mixing various ratios of Lm and Y to super cold with mixing Lc and Lm. I just set up a 3880 using Piezography WN shades 1,2,4,5,6 plus the Epson LcLmY. I've only profiled a few Canson papers, but I am pretty excited with a few of the test prints I made over the past few days. Once I get the kinks worked out on the small printer I am going to take it up to K6+LcLmY on the a 9900 to provide more options for printing commercially.
If you are dead set on Eboni inks, you could probably use those instead—they are just not the inks I prefer.
2016-12-13 by m venz
Thank you Richard and Paul. You both have an enviable level of expertise and your views and comments are highly valued. I appreciate the time you have taken to respond to this issue.
Thanks again.
Michael V
2016-12-30 by jerry dungan
To Update on this R1800 Set up: Once past some delays, have now set up the R1800 as advised with the EB6 + a single MK in the PK position and + the Blue toner ,(the light blue from MIS), in the GL position. The MK and Toner each have their own profiles so I can bring them into the print as needed. With Print Tool split toning I can print from the straight Eboni 1.1 warm all the way through a very pleasing neutral and all the way to a dark cool. Just a terrific flexible set up and kudos as always to Paul R for the guidance and encouragement. Jerry -------------------------------------------- On Mon, 11/14/16, jerry dungan <jerry_4y@...> wrote:
Date: Monday, November 14, 2016, 8:57 PM
technique.
well?
Jerry
positions
>2%
>6%
>9%
>MK
>MK
>18%
>30%
>MK
toner.
easier way to go.
in it.
well
MK,
making
of
to
Eb6
easily added later.
Paul,
2%
6%
9%
MK
MK
18%
30%
MK
Jerry
positions
yahoogroups.com>
to
read
as
of
family
as
there
is
profiles
for
profiles
a
control
yellow
usually
had
an
how
drivers
for
CMY
directly
Jerry wrote:
>The question was
link
you>
sequence
turn
out
to > mean
MK>MK>MK>30%
MK>MK
