Digital BW, The Print
Epson V750 Pro focus
2014-02-07 by <lestihor@...>
When scanning black and white 35 mm film with my Epson V750 Pro I found the focus not as sharp as expected. I tried scanning as colour positive, then inverted in CS3. Then in Channel Mixer I applied in turn various coloured filters. I found that the blue or green filters produced very sharp results, while the yellow, orange and red filters produced progressively poorer focus. Does this mean that the scanner is focusing the red, blue and green scans in different planes? If so, is this a defect or is it normal?
Les
Re: [Digital BW] Epson V750 Pro focus
2014-02-07 by Ernst Dinkla
> Les
Most of this you will know. First of all the V750 has no active
focusing. You have to find its sweet spot by adjusting the height of the
film carriers. It could be that for the V750's two lenses there is a
difference in height so carriers normally used for the 150mm wide scan
path get a different tweak compared to the wide carriers like the wet
mounting type. The 35mm carrier is just covered by the smaller field lens.
You might use only the two center strips and cover the outside strips
with black paper if there is some gain in that. Doug Fisher's Betterscan
(wet mounting) carriers are easier to adjust for focus. I wet mount
films on both the Nikon 8000 and the V700 that I have. Doug has a link
to something I wrote on wet mounting years ago.
Harder to do with 35mm frames. I think the V750 is not really up to the
task of scanning 35mm frames anyway, The 8000 here is used for 35mm
scans and normally dry but difficult takes get a wet mount treatment.
My theory is that flatbeds like the V750 use the lens with a very small
stop so near/in diffraction to cover the width of the scan path with equal
resolution. That and resolving "grain" or better to reduce "aliased grain"
goes along with using shorter wave light, Blue or Green. However Green
light lies in the middle of the spectrum the lens should cover so one
may expect better performance there, whether the focusing results in a
plane field is harder to conclude, though wet mounted larger frames scans
suggest it is quite plane. Deconvolution sharpening like one can find
in the smart "lens" sharpening in PS or ACR does a better job to
recreate the original information of the take than other sharpening
routines. It will reduce the flaws of both optical systems, of the
scanner and of the camera.
I use Vuescan with all my scanners. It's B&W scan setting favors the
Green channel. My method with the Nikon 8000 B&W scanning goes further
than that. The RGB LEDs can be controlled with Vuescan that only the
Green or Blue LEDs are used. Both gave better resolution than the full
RGB LED method. Right now I use the Green LEDs, wet mount, Vuescan DNG
RAW export but negative reversed to positive, PS ACR import and the
deconvolution (lens) sharpening used there. Grain reduced with Neat
Image in PS afterwards.
There are narrow band Green or Blue CCFLs that fall in the sweet spot of
sensor sensitivity for Blue and Green. If I can lay my hand on a cheap
secondhand V700 or V750 there would be a good chance I would replace the
white CCFL in the scanner's lid. A very nice dedicated B&W MF to 8x10
film scanner could be made that way.
So Yes, Blue or Green channels can make a difference.
Met vriendelijke groet, Ernst
http://www.pigment-print.com/spectralplots/spectrumviz_1.htm
January 2014, 600+ inkjet media white spectral plots.
RE: Epson V750 Pro focus
2014-02-07 by <ro@...>
Thank-you for this post. We've just started to scan our A. Aubrey Bodine color transparencies and we are using a V750Pro.
I have taken a brain-dead approach to my scanners since 2000 (1640XL and 10000XL), I have never tried to characterize scanner performance, so this analysis really piqued my interest.
Blue - image smears to right by 1 pixel
Green - sharpest
Orange - less sharp than G
Red - less sharp than O
Yellow - same as Orange
I guess it's time to read about calibration procedures.
Epson 4900 not printing VLM or LC
2014-02-07 by Arthur Fink Photo
I was away for a month, and my Epson 4900 sat idle.  I tried to print, but all I got were blank pages.  A nozzle check showed the same.  But one regular cleaning and one power cleaning cleared everything -- except VLM and LC.  I've run several power cleanings on just that pair, each a day apart, but still absolutely nothing.
Epson's response (by phone) is outrageous -- It needs a new print head and more . . . total cost about $2,000.
But there must be a way to clear the head, the dampers, or whatever.
Not understanding the mechanism of this printer, I do think it interesting that two colors are blank, and that they are paired in the power cleaning process.
Any ideas about how to proceed -- short of giving in to Epson's crazy offer or buying a new printer?
The printer is, and has alway been, loaded only with Epson OEM inks.  I use QTR to print black and white on this printer, and Piezeography to print on smaller printers.
Thanks much,
Arthur
       Arthur Fink Photography
   Pictures of dancers, weddings, births, fish,
   and other subjects of interest and amusement
    Studio / Gallery in Portland, Maine, and also on Peaks Island
    www.arthurfinkphoto.com af@... 207.615.5722
    Read, and comment on, my blog: www.InsightAndClarity.com
    Click on this link to join my e-mail list (via Constant Contact)
    for news about shows, art and spirit and creativity workshops,
    creativity coaching, wedding, birth, and event photography.
RE: [Digital BW] Epson 4900 not printing VLM or LC
2014-02-07 by Gary
Hello,
I have a similar problem. I have a two year old 4900 that I replaced the
head under warranty after 3 months due to clogging. Now the yellow nozzle
has not been working for the last two weeks and I am out of ideas on what to
do to fix it. There is lots of info on line concerning premature head
failure on the  Epson 900 series printers. Not sure what the solution is
other than disposing. Head replacement is not cost effective. The best
method I have found in the past for clearing nozzle clogs is soaking a paper
towel in Windex and placing it under the head for several hours or
overnight. This method has worked for me in the past for other clogs. If
others have ideas on how to fix my yellow please reply.
Gary Wagner
www.garywagner.com
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Arthur
Fink Photo
Sent: Friday, February 07, 2014 7:19 AM
To: Digital B&W Print
Subject: [Digital BW] Epson 4900 not printing VLM or LC
process.
smaller printers.
Thanks much,
Arthur
    www.arthurfinkphoto.com <http://www.arthurfinkphoto.com/>
af@... 207.615.5722
    Read, and comment on, my blog:  <http://www.insightandclarity.com/>
<http://visitor.constantcontact.com/manage/optin/ea?v=001RgvbKVLa7a7RR4E6BV8
sKw%3D%3D> join my e-mail list (via Constant Contact)
Re: [Digital BW] Epson 4900 not printing VLM or LC
Can somebody give me (or point me toward) detail instructions about how to place a power towel (soaked with whatever) under the print head on a 4900?
Arthur
On Feb 7, 2014, at 10:38 AM, Gary <gary@garywagner.com> wrote:
Hello,
I have a similar problem. I have a two year old 4900 that I replaced the head under warranty after 3 months due to clogging. Now the yellow nozzle has not been working for the last two weeks and I am out of ideas on what to do to fix it. There is lots of info on line concerning premature head failure on the Epson 900 series printers. Not sure what the solution is other than disposing. Head replacement is not cost effective. The best method I have found in the past for clearing nozzle clogs is soaking a paper towel in Windex and placing it under the head for several hours or overnight. This method has worked for me in the past for other clogs. If others have ideas on how to fix my yellow please reply.
Gary Wagner
www.garywagner.com
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Arthur Fink Photo
Thanks much,
Arthur
; Click on this link to join my e-mail list (via Constant Contact)
2014-02-07 by Gary
Google 4900 paper towel.
Lots of posts.
Try this one.
http://www.nwpphotoforum.com/ubbthreads/ubbthreads.php?ubb=showflat
<http://www.nwpphotoforum.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=
40109> &Number=40109
Gary Wagner
Fink Photo
Sent: Friday, February 07, 2014 8:01 AM
Subject: Re: [Digital BW] Epson 4900 not printing VLM or LC
Arthur
On Feb 7, 2014, at 10:38 AM, Gary <gary@...> wrote:
Hello,
Gary Wagner
www.garywagner.com
Fink Photo
process.
smaller printers.
Thanks much,
Arthur
af@... 207.615.5722
af@... 207.615.5722
2014-02-07 by Jere DeWaters
Check out Jon Cone's Inkjet Mall for various cleaning and maintenance for Epson printers.
From my iPed
> Arthur
>> Hello,
>> Thanks,
>> Gary Wagner
>> www.garywagner.com
>> From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@...m] On Behalf Of Arthur Fink Photo
>> Thanks much,
>> Arthur
2014-02-07 by Elliot Puritz
There are wonderful videos which provide the details of cleaning the various
Epson printer models on YouTube.
Elliot
Fink Photo
Sent: Friday, February 07, 2014 11:01 AM
Arthur
Hello,
Gary Wagner
www.garywagner.com
Fink Photo
process.
smaller printers.
Thanks much,
Arthur
af@... 207.615.5722
af@... 207.615.5722
2014-02-07 by mrjimbo2
Arthur,
It winter , really low humidity and it sat for a while.. So a couple of things you can do / try.. First make sure the two colors that won't show don't have air in the lines..
Next wet the park pad with water.. really wet it .. ( I use an eye dropper for this) Put the head over it for an hour or so.. Then try a nozzle test to see if your getting anything if you start seeing a few lines go ahead and do a regular cleaning cycle.
If that doesn't work , This one you'll want to keep an eye on so you don't start wicking ink out thru the head.. wet a paper towel with a mix of water and simple green... fold it in half to double its thickness... get that in the rollers manually...make sure it's good and wet even if you have to add more with an eye dropper.... then pull the head off park and let it set on it for several hours.. (no windex or similar as that dries it out).
As far as Epson saying you need a new print head.. well too soon to say that I think..... you might have a damper issue or simply struggling with air in the line...
jimbo
Sent: Friday, February 07, 2014 8:19 AM
Thanks much,
Arthur
; Arthur Fink Photography
; creativity coaching, wedding, birth, and event photography.
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2014.0.4259 / Virus Database: 3697/7069 - Release Date: 02/06/14
2014-02-07 by Gary
Jimbo,
How can you tell if you have air in the line?
Gary Wagner
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of mrjimbo2
Sent: Friday, February 07, 2014 8:37 AM
Arthur,
the line...
jimbo
2014-02-07 by <homershannon@...>
Jon Cone (inkjetmall.com) has a number of products for cleaning printers. Check out his video for the 4900 on YouTube at http://www.moneychimp.com/features/market_cagr.htm.
I can't personally speak as to how good these products are, but I'm willing to believe that they are much better than the generic Windex and ammonia solutions offered from less reputable suppliers.
Homer Shannon
