Digital BW, The Print
Base for dye ink
Base for dye ink
2013-01-06 by Keith
Based in the UK, I have just spent an age trying to find a source of Dow Butoxytriglycol to no avail.
a) Does anyone know of a UK source.
b) Could I use the normal base of;
Glcerol
Foto Flo
Edwal LFN
Water
Keith Dugdale
Re: [Digital BW] Base for dye ink
2013-01-06 by Michael King
Keith,
Did you try these guys, I got my Dow Tergitol from them.
Univar Europe****
Leslie Court****
Western Industrial Estate****
Lon-Y-Llyn****
Caerphilly****
CF83 1BQ.****
UK****
T 02920 855300
F 02920 855331****
*www.univareurope.com*
Let us know how you get on.
Cheers,
Mike
> Glcerol
> Foto Flo
> Edwal LFN
> Water
> Keith Dugdale
2013-01-07 by Paul Roark
Try searching under CAS # 56-81-5 and/or triethylene glycol monobutyl
ether.  I think this chemical is called different names by different
companies.
> Glcerol
> Foto Flo
> Edwal LFN
> Water
I don't recommend it.  Butoxytriglycol or triethylene glycol monobutyl
ether is a dye carrier and coupling agent.  I think a base without this in
it would not produce as good or stable results.
Paul
www.PaulRoark.com
2013-01-07 by Ernst Dinkla
> Glcerol
> Foto Flo
> Edwal LFN
> Water
> Keith Dugdale
OCP sells some alternatives for gloss enhancers like used in the Epson
R1900 etc. I still use an OCP gloss enhancer for Kodak thermal head
printers to mix HP pigment inks for HP thermal heads. That one is
probably not suitable given the different viscosity used for thermal
heads but I assume the R1900 one should be good. OCP pricing and
availability in Europe is as good as it gets. I can get gallon size OCP
cans if needed.
Met vriendelijke groet, Ernst Dinkla
http://www.pigment-print.com/spectralplots/spectrumviz_1.htm
December 2012: 500+ inkjet media paper white spectral plots.
The OCP alternative ink set for the R1900 is actually dye based. Try a
sample with the dyes you want to dilute whether the result is stable.
The gloss enhancer is available in the UK in carts or bulk.
Like this:
https://www.refillsupermarket.co.uk/ocp-ink-epson-t0540-colorless-p-1752.html#.UOqNAEhKhO0
Re: Base for dye ink
2013-01-10 by Glenn
I just started looking for Tergitol 15-S-7 in Australia
Sigma Aldrich lists it in 500ml quantities www.sigmaaldrich.com
Thay also list 24 hits for CAS # 56-81-5, though Tergitol has a different CAS #
They are pretty much worldwide
peace out
Glenn
> Like this:
Re: [Digital BW] Re: Base for dye ink
2013-01-10 by Paul Roark
I don't use Tergitol in the dye base.
Paul
www.PaulRoark.com
2013-01-11 by Glenn
Apologies - I skimmed through the earlier messages and saw tergitol mentioned and a source listed
That said sigma aldrich listed quite a few items under the CAS # 56-81-5
I'm not up to speed with the dye dilution base so can't discern between them as to suitability
peace out
Glenn
> Paul
> www.PaulRoark.com
