Arches watercolor roll paper
2012-12-11 by Paul
I printed my first large panorama on Arches paper that is sold in rolls. In this case it was a 51 inch by 10 yard roll <http://www.utrechtart.com/Paper,Arches.utrecht>. I sliced off 24 inches from the roll and printed it in the 7800 with the Eboni-HP inkset <http://www.paulroark.com/BW-Info/7800-EbHP-2013.pdf>. The bottom line is that it appears to have worked quite well. The hardest part was flattening the tightly rolled Arches. This uncoated watercolor paper (the real thing, not inkjet paper), is internally sized with gelatin. I did not have a d-roller that was suitable, and I'm not sure if the small diameter one I have would be a good idea anyway. The painters have all sorts of recommendations for flattening Arches that also did not appeal. What I did was buy 2 melamine-coated 12 inch by 5 foot shelves that I put on top of the paper, with lightly dampened old wet darkroom Kodak blotter papers between the shelves and Arches. Humidity softens gelatin and the cellulose. So after sitting in this sandwich for a few hours the paper was quite flat -- sufficient that there were no head strikes on the paper. At any rate, Arches in large sizes works. It's a lot more work than the usual 22 x 30 "full sheet" sizes I usually use, and there is no "bright white" version of Arches in this size. As usual with Arches, QTR or other rip is essential, and it's not a paper or workflow I'd recommend for most printers. Paul www.PaulRoark.com
