Paul,
You are a tremendous help and a very patient person. Thank you for both. I think
I lack the basic understanding of what each inkset is developed from and
purposed for. The rest is a confusion over the the naming of the different
inks.For example, "Note that UT14 LM is LK, which is 30% of UT14-M, which is
simply MIS K4-PK".
According to InkSuppy's website, the MIS K4 inks are Epson K3 compatable
replacments and are matte + glossy. Eboni is a pure carbon core matte but more
neutral and stable than the K4 inks. For glossy B&W prints I would elect the K4
inks using LC & LM for toning = K4+. If I wanted more stability with the ability
to print glossy, I would select the Eb4+ inset wth UT14-C & UT14-LC for printing
glossy. Correct?
Yes- I meant to type "I am using 30% UT14-M in the LM position". However, if the
K4-PK is the same as 30% UT14-M, what makes the K4-PK different from the K4-LK
or LLK if the LK & LLK are glossy compatiable as well? Are these just diffrent
dilitions of K4-K? Please correct me if I am mistaken but doesnt PK identify
Photo Black meaning it is glossy compatiable versus MK which is Matte Black?
Please believe me when I say I am honestly trying to understand this and not
being argumentative or sarcastic. To the uninformed, it apears more logical to
have a natural progressin of K4-K, K4-LK, K4-LLK, and finally K4-LLLK especially
if the inks orginate from the K4-K ink. By injecting a K4-PK leads me to think
there is a difference and naturally assume the K4-LK & LLK are non-glossy inks
and the same as the Eb6-K inks.
Is there any difference between the MIS stock base (ESC-Base-UC), glop, and
generic base? How does this difference if any affect final print tone? Impact on
the printer?? I have been using the MIS clear stock UC compatiable base to mix
the different dilitions. Is this a bad thing? I know there is a most cost
effective apporach but a 4ounce bottle has lasted several months.
My intent is to achieve the most neutral inkset with the longest life stability.
For glossy prints I use the R2400 with Exibition Fiber or Ilford Smooth Pearl.
This seems to work fine for the time. Reading through the 1400-Eboni6 document,
I see the ink denisty is pretty standard: K,C,M,LC,LM, & finally that poor
little Yellow. Would I be wrong in assuming the densities should be 100%, 30%,
18%, 9%, 6%, and 2% respectively? This would relay solely on paper choice to
determine the actual print tone of warmth vs neutral though. How well would it
fair using UT14LC as a toner to help control the Lab b warmth in the mid
tones? This would be moving back towards the Eb4+ with the C & LC inks, yes?
So far, as the cloud of confusion begins to disipate, I see need to look closer
at Eboni-6 than the K4+ or Eb4+. I think I have more adventure ahead of me but
with your help I know that I will arrive at the look & tone that I
envision. Many thanks. I am beginning to think I just need to pull the plug,
step back, think about it, and re-set the inks using a fresh perspective.
Phil
Sent: Thu, April 14, 2011 9:09:08 AM
Subject: Re: [Digital BW] 1100 & Eboni-4
Phillip Kimble <grimmieoldfart@...> wrote:
>... What you are sayng is the K4+ inks are not pure carbon
> inks in the respect they are glossy compatable and potentialy
> mixed with other color pigments
The glossy carbons from MIS -- for example the K4 PK, LK, & LLK are pure carbon
-- no colors mixed in. The "Plus" inks are where the color is.
The reasons I came up with the Eboni-6 and 4 as opposed to use the MIS K4 PK, LK
& LLK is that the Eboni carbons are more neutral and have almost no binder in
them, being matte paper only. Glossy pigs are where the binder is needed to
stick them onto the slick paper ... and other things.
> I am currently using;
> Eb-Mk in the K position
> UT14-C in the C position
> 6% Eb-Mk in the M position
> 2% Eb-Mk in the Y position
> 2% UT14-C in the LC position
That is a very light neutral-cool ink.
> 50% UT-M in the LM position
Is that 50% UT14-M? Note that UT14 LM is LK, which is 30% of UT14-M, which is
simply MIS K4-PK.
> To be complaint with the Eb4+ specifrications I need to rearrange the inks to;
> K - 100% MK
> M - 18% MK
> LM - 6% MK
> Y - 2% MK
And if you're mixing these as opposed to buying MIS Eb6-M, LM, and Y, use the
generic base and not glop.
> C - PK
> LC - 30% PK
Yes, that is one set that can go there. The defaults are UT14 C and LC --
neutralized PK and LK. The idea is that many want a more neutral ink and some
minimal glossy capability. The 100% carbon PK and LK give you a sepia tone on
glossy paper.
> Are the only purpose of the PK/LPK inks for glossy printing & toning?
Yes. If you want 100% carbon on matte and the tones that can achieve, then I'd
recommend Eboni-6, not the Eboni-4 Plus the 2 others.
For the full Eboni-6, see http://www.paulroark.com/BW-Info/Eboni-6.pdf
Hope this helps.
Paul
www.PaulRoark.com
