On Apr 16, 2011, at 1:12 PM, frankg_photo wrote:
> Thanks for the reply and the article link.
> II think the choice is clear - 3880.
> However what's between the regular, the portrait, the pro & the graphic arts editions?
> Also...is there an imminent release of the 3900?
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Andrew Darlow <ad@...> wrote:
> > Hi Frank:
> > You have another option these days, and that's the Epson Stylus Pro 4900. The advantage of the Stylus Pro 3880 and Epson Stylus Pro 4900 are that changing from matte black to photo black will only set you back a few dollars in wasted ink. The 4880 is a whole other story. It will take about 10 minutes to change the inks, and the cost is about $40 in inks unless you have the ImagePrint RIP and their Phatte Black ink.
> > An advantage of the 4880 and 4900 over the 3880 is the roll-feed, if that's important. They both also take larger cartridges.
> > If you only print on matter or semi-gloss/gloss papers, then the above issue is not a big issue.
> > I wrote a long review about the 3880 here, which may help you make your decision:
> > http://imagingbuffet.com/2010/09/24/hands-on-review-epson-stylus-pro-3880-inkjet-printer/
> > All the best,
> > Andrew
