Glen , remember boards get dinged sooner or later and limited amounts of
water will get in eventually!!
Steve[ board buster of note!]
to clarify the cotton is going to laminated under the fibreglass on the
surfboard so water solubility isn't an issue.
I'm printing with a 3000 using the standard dye inks, mainly because this is
what I have to work with and the straight paper path on the 3000.
My main concern with Inkaid and the Digital Ground is if they contain any
plasticisers (they just list proprietary polymers in the Inkaid MSDS) they
will likely cause the fibreglass to delaminate.
I'm aiming to go one up from the traditional rice paper which is very
difficult to use in large pieces and also to have more vibrancy to the image
with something closer to inkjet paper output.
I may end up going with Inkaid or digital grounds, but I have gleaned a few
interesting ideas from some reading on the net so far, so I'm going to do
some tests in the meantime.
regards
Glenn
--- In DigitalBlackandWhiteThePrint@yahoogroups.com
<mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> , "Heidi R."
<camerashyest@...> wrote:
> Hi Glenn,
> I hope I didn't miss the point of your question, but if you're printing
with a pigment ink printer (Epson durabrite or ultrachrome inks are
pigments), you can print on cotton (or any other fabric) without any kind of
coating or treatment. The result is pretty good -- the colors will be a
little less true than on treated fabric, and the resolution somewhat
reduced.
> If you're printing with a dye ink printer, then the inks will mostly wash
out and bleed unless you pretreat the cotton with Bubble Jet Set 2000 or a
similar fixative.
> You could also look into treating with InkAid or Digital Ground, although
you'd have to seal completely because they're not waterproof.
> I hope that helps.
> Heidi
> http://GardenDelightsArts.com
> From: Glenn <glennrbarry@...>
> Subject: [Digital BW] DIY coating for cotton fabric
> To: DigitalBlackandWhiteThePrint@yahoogroups.com
> Date: Thursday, April 22, 2010, 7:40 PM
> Hi All,
> I'd like to try a test printing on cotton fabric, yes I know that there
are pre-prepared products available, but nothing locally for me anyway.
> I am considering just sizing the cotton with gelatin to reduce
bleedthrough.
> It's going to be for the whole bottom of a surfboard, which is why it has
to be 100% cotton instead of nylons/polyester blends and I don't think
(actually hoping) the resin will be rejected by the gelatin.
> Resin doesn't laminate properly to anything synthetic.
> Does anyone have any other suggestions?
> I have read about using a combination of water based PVA and white acrylic
paint, but that much PVA glue will likely delaminate.
> I'm going for cotton fabric as opposed to rice paper as this board has
compound curves that are problematic for papers.
> thanks
> Glenn
