DTXtremeIIS & Mesh Heads.
2004-04-18 by Abdulmalek Hamsho
Hi everybody,
I have Pearl Traveller kit (DDrum Red shot triggers) along with the
DTXpressII kit, I'm facing problems with the mesh heads (lot of missed beats
while playing fast rolls in addition to some Bass drum problems), so the
question is: Would DTXtremeIIS response better to those mesh heads? If yes,
would it be that big difference?
Any idea how to decrease those missed beats rate with my current DTXpressII
(All rejection options are set to 0, Gain = 99, MVel = 4)
Thanks.
STOP MORE SPAM with the new MSN 8 and get 2 months FREE*
http://join.msn.com/?page=features/junkmail
Re: DTXtremeIIS & Mesh Heads.
2004-04-18 by emf
--- In DTXpress@yahoogroups.com, "Abdulmalek Hamsho" <aa_mm_hh@h...>
wrote:
> Hi everybody,
missed beats
so the
If yes,
DTXpressII
People have reported problems using the redshots and the DTXpress
module, especially on the kick, both here and at the ddrum forum.
Have you tried the DT10/20 pad-type settings in the trigger mode and
trigger setup, and have you flipped the DIP switches on the back of
the module to the high positions (use a pen or pin; they're tiny). We
don't know anything about how the DTXtreme IIS module will respond to
particular pads at this point, though chances are that it will be
more versatile than the DTXpress II. I'd try new triggers and exhaust
setting possiblilities in the module that you have now before I went
out and spent 1,000 on a new module that might not solve your problem
any better--unless, of course, you'd just like to have a better
module in principle.
Ed
RE: [DTXpress] Re: DTXtremeIIS & Mesh Heads.
Unfortunatelly, I did all what you adviced .... So, I should keep simulating
the missed beats in my brain rather than the DTXpress brain.
Thanks.
>From: "emf" <liberatusvirus@...>
>Reply-To: DTXpress@yahoogroups.com
>Subject: [DTXpress] Re: DTXtremeIIS & Mesh Heads.
>Date: Sun, 18 Apr 2004 16:29:38 -0000
>wrote:
> > Hi everybody,
>missed beats
>so the
>If yes,
>DTXpressII
>Ed
MSN 8 helps eliminate e-mail viruses. Get 2 months FREE*.
http://join.msn.com/?page=features/virus
2004-04-18 by emf
simulating
Well, the human brain can do some pretty amazing interpolations, but
unfortunately not with intervals this long, no matter how fast you
may be. I think we have to work harder on this one before we give up.
Would you do some testing for us? How about trying the RHP and SHP
settings in pad type? I have no expectations that they'll be better,
but I'd like to know how they compare with DT10/20 pad-type settings
when the DIPs are high. Do RHP and SHP make the redshot/Pearl
combination louder or softer, etc., or no change?
With pleasure. Here we go:
1- For Pad Type, nothing will help at all. It's not a problem of louder or
not. If I chose any pad other than DT (Kick, snare ...etc) or SHP, one beat
would give many undesirable beats. But If I chose SHP, the things would
become better (but not that much). While the DT Pad Type is the best option
but still you will miss some beats. In fact, after investigating all around
the beat (Trigger, Brain, Head), I got a result that it's mostly not because
of the Brain, nor the Trigger. Mostly because of the head, but why?  Because
when I hit the head in one location with same stick using the same kind of
velocity, it may miss the beat sometimes, when I play fast on a location
opposite to the trigger side, it hardly misses beats, while if I played with
the same speed either in the central or the trigger side area, it mostly
bypasses some beats (if it's in the central area, it will bypass a lot of
the beats).
I read about Pintech/Hartdynamics mesh heads, but some people said it's
better foot the mesh head to be 1-ply, while others said that 2-ply has a
better response. Since live in Dubai, I don't have any of those products in
hand. I got all of my equipments from US, and now I failed to get the
DTXtremeIIS from there (My brother left US).
Would this help you guys?
>Date: Sun, 18 Apr 2004 17:33:16 -0000
>simulating
The new MSN 8: advanced junk mail protection and 2 months FREE*
2004-04-18 by bongokonzelmann
Probably it only touches a side aspect but nevertheless: Before I
bought my DTXPIII I was a DTXtremeI user and I remember my problem
with loudness on the standard heads that go with the original setup.
So I went to a local dealer and asked for meshheads and he strongly
recommended not to go for any other than T-Drum heads which actually
are the ones that are distributed by Ddrum in Europe (I therefore
assume that they are mounted on Ddrum shells).
Although I realise that your hardware (shells, pads) isn´t Ddrum or
DTXtreme, still it is about Ddrum triggers. How do you view the
influence a certain meshhead brand could have? - If you are interested
to have a look at T-Drums´ website the link is www.triggerhead.com.
Regards     -Bongo-
louder or
one beat
option
around
because
 Because
kind of
location
played with
mostly
lot of
> the beats).
has a
products in
> >From: "emf" <liberatusvirus@y...>
> >simulating
Ed, your idea is very reasonable, specially if I told you that there is no
dropouts at all in Buzz-roll if it was too close to the trigger.
>Date: Sun, 18 Apr 2004 18:57:04 -0000
>--- In DTXpress@yahoogroups.com, "bongokonzelmann" <carsten@h...>
> > Although I realise that your hardware (shells, pads) isn\ufffdt Ddrum or
>interested
> > to have a look at T-Drums\ufffd website the link is www.triggerhead.com.
>I'd like to think a little about what Abdulmalek has observed--that
>dropouts are more likely to occur nearer to the trigger than away
>from it. I'm familiar with the DTXPU's tendency to multiple triggers
>with certain pads at certain settings. As for what happens with the
>DT10/20 setting and mesh heads, I'm tempted to say that the DTXPU
>module is too slow to read strong signals that follow each other
>closely, but at a distance, when the signal envelope is shorter, it
>doesn't hang up as much. But I'm not sure about that theory.
>As for mesh heads, I think that ddrum had to license the ones on its
>pads from triggerhead, who had an agreement with Roland. What impacts
>triggering with mesh heads is not so much the brand (which varies
>mainly by thickness, if at all, for the purposes of this issue) but
>where the piezo is located beneath it, the nature of the foam that
>intervenes, and how tightly the head is tuned. I wouldn' be surprised
>if Bongo's problem was either heads that were tight enough or shell
>interiors that tended to muffle the piezo. Lots of people with the
>first DTXT simply pulled swapped the mylar heads for Roland, Pintech
>meshes, rearranged the foam layers as necessary, and never looked
>back.
>Ed
Add photos to your e-mail with MSN 8. Get 2 months FREE*.
http://join.msn.com/?page=features/featuredemail
2004-04-19 by emf
interested
if Bongo's problem was either heads that weren't tight enough or shell
first DTXT simply swapped the mylar heads for Roland or Pintech
back.
Ed
2004-04-19 by emf
--- In DTXpress@yahoogroups.com, "emf" <liberatusvirus@y...> wrote:
The post before this one is out of order, because it's the rewritten
version of one that I deleted to remove the typo that actually
contradicted my point. It should go before the one about the buzz
rolls.
Ed
2004-04-22 by Abdulmalek Hamsho
Guys, finally I found the reason of the dropouts I've been suffering of. I
muffled the head, and ..... finish. No dropouts at all guys.
I have a question: Anybody knows well about Alesis SR16? Pros and cons of
this module?
Thanks.
Help STOP SPAM with the new MSN 8 and get 2 months FREE*
2004-04-22 by emf
suffering of. I
cons of
> this module?
What did you use to muffle the head, and did you change any of your
DT10/20 settings?
2004-04-24 by Abdulmalek Hamsho
I used like this one in the picture :
http://www.music123.com/Evans-Min-EMAD-Mini-Damping-System-i97711.music
I changed nothing in the settings.
>Date: Thu, 22 Apr 2004 16:11:08 -0000
>suffering of. I
>cons of
> > this module?
>DT10/20 settings?
MSN 8 with e-mail virus protection service: 2 months FREE*
