RE: Advice on module/vibration
2003-08-07 by rdamon@mckinney-usa.com
Ed wrote: "Another possibility is to group pads on the rack by their connected > module; proximity can alleviate some of the danger. Other people have > dampened cymbals, say, at the top of the stand or even filled their > rack tubes with insulation material (OGD, was that you?)" > Lee, As you may know, I have three dtxpressII modules on my setup. If you look at the picture in the photos section, the pads/cymbals on the left section go to module no. 1, the middle pads to module no. 2 and the right side pads to module no. 3. Even with that separation, it still wasn't enough to stop cross-triggering, because dense packing of pads, the cymbal arms just seem to amplifly the vibration effects to the tom pads. And since you can only specifiy one other trigger to "specific rejection" per pad, I had to find another solution. So I replace the mounting clamps of the offending cymbal arms with some Gilbraltor multi-clamps, bought a heavy duty rubber washing machine drain hose and cut it up and placed it between the cymbal mounting arm and the clamp and it solved my problem. OGD > ************************************************************************** The information transmitted herewith is sensitive information intended only for use to the individual or entity to which it is addressed. If the reader of this message is not the intended recipient, you are hereby notified that any review, retransmission, dissemination, distribution, copying or other use of, or taking of any action in reliance upon, this information is strictly prohibited. If you have received this communication in error, please contact the sender and delete the material from your computer. ________________________________________________________________________ This email has been scanned for all viruses by the MessageLabs Email Security System. For more information on a proactive email security service working around the clock, around the globe, visit http://www.messagelabs.com ________________________________________________________________________
