Sent: Wednesday, August 06, 2003 3:58 PM
To: DTXpress@yahoogroups.com
Subject: Re: [DTXpress] my go to ask for help
fezzasus said:
> i have a dtx2 but the interface is almost the same so im hoping
> you will still be able to help me:
> i have quite a heavy hitter and feel that i cannot get as much
> expression from the drums (ei - they wont go louder when i hit
> them harder) and im not quite sure on how i should go about
> adjusting them to make them do this - everyhting i seem to do
> makes it worse.
When you strike the pad, the piezo element encased in it produces a small
electric signal that is measured by the DTXpress module to determine how
loud a sound it should produce. In your case, if you are striking the
pads *very* hard, you may be causing the piezo to produce it's maximum
output voltage, if this is the case, then striking the pad even harder
will not produce a measureable increase in voltage and so the module is
not aware it should make a proportionaly louder sound.
This might be different if you had Mesh pads or some other type of pad
where you can reduce the amount of kinetic energy reaching the piezo. If
the piezo is not being saturated by your stick force, then you should be
able to reduce the sensitivity of the pad by using the DIP switches on
the back of the module.
If you have a sequencer, I would use it to record a series of notes from
one of your pads starting at MP and moving to FFF and then look to see
what the velocity level is for the notes. If they are reaching 127 before
you are at triple-forte, then you will need to reduce the pad sensitivity
more. If you are unable to get the note velocity to drop below 127 before
you hit triple forte, then it might be time to investigate a different
pad. :(
Of course, this is assuming that you are unable/unwilling to change your
drumming style. If you hit that hard, it might be best for you to move
away from gum-rubber pads altogether since many of the older drummers on
the list (et hem..:) can tell you from experience you will start to have
"organic degradation" i.e. carpal tunnel, sore wrists, sore shoulders,
etc.) since the gum rubber doesn't "give" when struck the way a drum head
does.
Rather than looking at changing the kit, you might want to consider just
changing your style a bit so as to improve your chances of being able to
drum when you get older. :)
> also, my hi-hat is level and i hit the side of it much like the way a
> normal one is played however the rim does not respond like the
> middle of the pad so i cannot trigger the closed/open sounds
> without hitting the top
On my kit I have the hat pad tilted towards me so the "normal" horizontal
position of my stick will impact the center of the pad. I had no real
luck getting the edge to trigger reliably and I don't think the pad would
survive long if it were continuously hit on it's side. Another option
would be to swap the two-zone cymbal pad with the hat pad since this
would give you an "edge" to strike like your "real" hi-hat.
> - can i just change the sounds around or
> will i need to re-arrange my drum kit - one i dea i had was to
> make a cable where the two sterio bits swap around so the DTX
> thinks the outside is the inside and the same the other way
> around - will this work?
I don't think switching the tip/ring around on the stereo cable would
work. I'm pretty sure it would render the pad silent as the center sensor
is piezo and the edge is a FSR. These two trigger types are not
compatible. Changing the cable would route the piezo output to the FSR
input on the module and vice versa.
It seems to me that a little larger view ought to be taken here. I think
many of us are surprised to learn that Electric drums are NOT Acoustic
drums! They are as different as an electric guitar is to an acoustic
guitar or fretless standup bass is from an electric bass. Subsequently,
you need to learn some new playing techniques.
Though it is probably possible to make changes to the kit to accommodate
what you are trying to accomplish, I don't think it's the best thing for
you to do if only because really heavy playing is *very* hard on your
body and may result in a shortened playing career.
Personally, I discovered that I could produce some very dynamic and
powerful sounds with the kit without beating the cr@p out of it. :) I use
the lightest jazz sticks I can find and I turn the volume of the kit up
loud enough that if I hit with medium to heavy force the sound is *very*
loud. This keeps me from hammering the cr@p out of the kit. Of course
then you have to be careful not to damage your hearing... :::sigh::: what
a drag it is getting old... :(
Vern
Vern Graner CNE/CNA/SSE | "If the network is down, then you're
Senior Systems Engineer | obviously incompetent so why are we
Texas Information Services | paying you? Of course, if the network
vern@... www.txis.com | is up, then we obviously don't need
Cell 507-7851 Desk 328-8947 | you, so why are we paying you?" VLG
Community email addresses:
Post message: DTXpress@yahoogroups.com
Subscribe: DTXpress-subscribe@yahoogroups.com
Unsubscribe: DTXpress-unsubscribe@yahoogroups.com
List owner: DTXpress-owner@yahoogroups.com
Shortcut URL to this page:
http://groups.yahoo.com/group/DTXpress
Alternate DTXpress site:
http://www.dtxpressions.com
Incoming mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.495 / Virus Database: 294 - Release Date: 6/30/2003
Outgoing mail is certified Virus Free.
