Using Acoustic parts
2003-06-06 by sboehmer
I was wondering if any of you use Acoustic Cymbals, High-hats etc ...?
I went to a percussion workshop and started to miss the versatility of the
acoustic kit that I learned on. There are some things that the DTXpress does
not do well ... especially cymbal or high-hat sounds.
Any input would be greatly appreciated
Scott
Re: Using Acoustic parts
2003-06-06 by liberatusvirus
Scott,
I can't argue with you there. Uniformly, the cymbal sounds within
modules, as well as the physical triggers themselves, leave much to
be desired. A lot of people who otherwise use e-percussion do not
trust e-cymbals when they seriously record. I'm sure that I don't
have to go into detail about what acoustics do that electronics
cannot, at least at this relatively early stage of the game. That
said, though the cymbal samples within modules cannot be altered to
sound like your favorite acoustic line, usually you can find a
couple of rides, layered or not, and crashes that are pretty good if
properly set up. Finding the right decay and frequency cutoff are
crucial--that is, after gain and min. velocity are settled.
Though the gum rubber pads have definitely come a long way, their
feel, and perhaps even electronic response, are still lacking.
Stereo cymbals (triggering on edge via a rim switch and on bow via a
piezo), which are the domain of gum rubber, are particularly
finicky, often forcing a change in playing technique and always
risking the occasional drop-out or unintended voice/choke. The
Pintech Zenbal 14" round cymbals are probably the best of the lot,
especially at the price, since they swing and trigger as expected
most of the time. Once you get past the Roland CY-6, the rest of the
Roland line is pretty reliable as well, although the price is
difficult to justify. To my mind, though, gum rubber is tough to
swallow as a hi hat cymbal if you spend a lot of time riding the hi
hat (I do).
In my opinion, the e-cymbals with the best feel--the ones that
behave most (not completely) like acoustics--are the Harts and the
Visu-lites. Unfortunately, the otherwise great Hart Ecymbal II 16"
bronze ride (triggering via piezo on both bow and bell) doesn't
appear to mate well with Yamaha modules; nor does the brass hat. The
crashes (single-zone piezo), which are not bronze but coated, do,
though over time the veneer starts to flake. The Visu-lite line of
cymbals (dual piezo bow/bell or single piezo w/choke) is composed of
durable acrylic. They love Yamaha, and their touch is as much
like "real" cymbals as the Harts. I don't know whether the effect is
partly paychological because of that extraordinary feel, but they
also seem to make the Yamaha cymbal samples sound better (I'm not
the only one who's said as much), maybe by transmitting a more
robust signal across the bow and/or bell. The do have a more
delicate way of mounting the triggers, leaving the heavy hardware
off the cymbal proper. I've said enough about the Visu-lite hi hat
assembly on this board. If you aren't aware of it, the cymbals work
on an acoustic stand, opening and closing with full variability,
just like the "real" thing. I left a file about it, w/pictures, in
the Files section, but you could also check it out at Drumbalaya.com
or Visu-lite.com.
Sorry about being so long-winded, and redundant. It's an important
topic that can profit from as much input as we all give it. Although
the e-cymbal situation is far from ideal, options exist to bring it
closer to what many of us prefer to hear and feel.
Ed
etc ...?
versatility of the
DTXpress does
> Scott
Re: [DTXpress] Re: Using Acoustic parts
Ed,
Thanks for the response .. I appreciate the thorough ins and outs of all the
models available on the market today. My one resignation with buying more
toys is I already have a full complement of acoustic hardware that I was
thinking about integrating with the Yamaha. I have had the DTXpress for
about 3 1/2 years and truly love the way that I can manipulate the voices
and sounds that I can get. But unless I am missing something in the way I
have the kits set up I get a crash when I hit crash and nothing less. I want
to get the lighter, chimey sounds that I can get with acoustic but have not
gotten even by adding dual zone pads.
I would like to be able to,as I hit the high-hat harder get the slushy
sounds or partially open sounds that you can't seem to get with the current
high-hat pedal/pad combination.
Of course there are many more positives on the Yammy kit than negatives. It
is truly one of the best low end kits I have played. I we all could afford
the V-Drums there would be no need for this list and Nirvana would be
reached :)
At some point the Visu-lites may be an option ... trying to justify to the
lady of the house is always the first show stopper ... but maybe someday!
Sorry for the equally long response ... I was just flushing out my
frustrations a bit!
Scott
>On Fri, 06 Jun 2003 19:26:35 -0000 "liberatusvirus"
<liberatusvirus@...> wrote.
>Scott,
>hat (I do).
>or Visu-lite.com.
>Ed
>etc ...?
>versatility of the
>DTXpress does
>> Scott
>Community email addresses:
>  Post message: DTXpress@onelist.com
>  Subscribe:    DTXpress-subscribe@onelist.com
>  Unsubscribe:  DTXpress-unsubscribe@onelist.com
>  List owner:   DTXpress-owner@onelist.com
>Shortcut URL to this page:
>  http://www.onelist.com/community/DTXpress
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Scott,
Resisting the buying mania is prudent on a lot of levels, even with
all the temptations. I agree with you about the positive/negative
balance. It helps ease the pain when your ears aren't hearing
exactly what they want. Samples, sampling, and digital technology in
general have to get much better before electronics can capture the
subtleties that traditional cymbals and drums deliver as a matter of
course. But we're not doing so bad, and judicious spending can get
us even nearer to that elusive perfect moment. But not even the V-
Session or the acoustic set of your dreams can stop time forever.
I'm waiting to hear what Yamaha's next offering will be in the
module dept. See ya.
Ed
> Ed,
of all the
buying more
I was
DTXpress for
voices
the way I
less. I want
have not
slushy
the current
negatives. It
could afford
be
> reached :)
justify to the
someday!
> frustrations a bit!
> Scott
> <liberatusvirus@y...> wrote.
> >Scott,
to
to
if
via a
lot,
hi
> >hat (I do).
16"
The
of
of
is
hat
work
in
Drumbalaya.com
> >or Visu-lite.com.
important
Although
it
> >Ed
> >etc ...?
> >versatility of the
> >DTXpress does
> >> Scott
2003-06-06 by brown8700
Scott:
I've used my A-cymbals on a couple of gigs where volume wasn't a
concern. The two main drawbacks are the increase in stage volume and
the disconnect, if you will, between hearing the drum sounds come
from the monitor behind you and the cymbal sounds coming from in
front of you. It's a little strange, kind of like an out of body
experience, but I guess one could become accustomed to it. I,
personally, didn't like it.
But, oh, how I do love the sound of REAL bronze!
Stephen
2003-06-13 by Scott Boehmer
Stephen,
I have noticed that "disconnect" do to the way the PA system at the church I
play is set up ... the sound is behind and over my head. I am currently
using my old home stereo amp and Bose 901 speakers as my personal
monitor/amp. Still the feel is not right when I use the acoustic crash that
I use with mallets for sustains etc ... I am going to give it a try in the
next couple of weeks and see if I can get used to it and the others that I
play with can handle the difference in sound positions.
Thanks for the response ... I thought I was the only one who had this
problem.
Scott
To: <DTXpress@yahoogroups.com>
Sent: Friday, June 06, 2003 6:43 PM
Subject: [DTXpress] Re: Using Acoustic parts
> Scott:
> Stephen
