RECORDING Drum performance to seperate midi tracks??? How?
2005-06-09 by gollywillickers
i want to record DTXpress II into Pro Tools with each drum on a seperate midi track so i
can eventaully have a seperate audio track for each drum - just like i would for recording
acoustic drums.
How do i do that?
the drum sounds are all set to channel 10.
are the drum samples in the DTXpress available on any channel other than 10?
reording ALL the drums to multiple tracks and erasing the unwanted ones would be a huge
amount of work. i'd like to find a smarter way.
has anyone successfully done this?
Re: RECORDING Drum performance to seperate midi tracks??? How?
2005-06-10 by emf
--- In DTXpress@yahoogroups.com, "gollywillickers"
> acoustic drums.
> How do i do that?
than 10?
Why don't you just assign each drum to its own MIDI channel in the
Voice Edit Mode--under 1-7: Channel, Gate Time?
2005-06-12 by gollywillickers
i changed the voices from channel 10 to channels 1,2,3,4,5,etc.
but then the DTXpressII is triggering the "General Midi" sound set.
so, i have something like a piano on the kick drum, a synth on the hihat, etc.
etc..
how do i change the midi channel and still trigger the sampled drums?
can you do that with this unit?
> > acoustic drums.
> > How do i do that?
> than 10?
2005-06-12 by emf
hihat, etc.
> etc..
Golly,
Bear with me. I've never had occasion to change MIDI channels with a
DTXpress, but it should be possible. Why else would Yamaha give you
the ability to change a pad's channel in Voice Edit? What appears to
be happening is that the DTXpress defaults to the GM set voice for
every channel other than 10. At this point, the only spot in the
manual that that seems to address this problem is Song Edit 2. Program
Change, Bank Select. After you change the channel for each pad in
Voice, you may have to come to this section, log that channel, toggle
it to "on," and change V (Bank Select) to "drum V." I'm hoping that
switching to "drum V" will automatically also take care of PCNo, since
you won't be choosing a GM voice number, only a particular kit's pad
voice. Once you've gone to drum V, however, you may have to set PCNo
as the drumkit number that you're using. If this doesn't work, it's
back to the drawing board.
Ed
2005-06-15 by gollywillickers
Thank you Ed.
I'm going to try it tonight.
golly
> hihat, etc.
> > etc..
> Golly,
> Ed
