AVR-Chat
mega 168
mega 168
2005-08-21 by Dennis
Using ATmega 168. INT0 works fine as does Timer1. Invoke INT1 (pushbutton rising edge) and it goes to interrupt routine and never returns.
Had some sample parts from rep brought in to replace original ES (preproduction) parts. Thought that might be the problem. Not so.
Doesn't matter what's in the interrupt routine. Can put the RETI as the only instruction and still doesn't return to the instruction following an infinite loop.
Doing a lot of head-banging on this one.
Any ideas
Dennis
Re: [AVR-Chat] mega 168
2005-08-21 by Peter Gargano
Are you sure you have the right vector?
> returns.
Nebulous question. If all other interrupt vectors work OK why not this one?
D
To: <AVR-Chat@yahoogroups.com>
Sent: Saturday, August 20, 2005 10:36 PM
Subject: Re: [AVR-Chat] mega 168
>> returns.
Continue to assume the hardware works! Either the vector you think
you're using is wrong, or you do something bad in the correct ISR and
it never returns, or maybe you blow the stack with repeated int calls.
Surely a bit of diag code can work out what's happening?
Do you know your INT1 ISR gets entered, and via the correct vector?
INT1 is entered how many times per keypress? (hardware has a knack of
bouncing and producing multiple ints.
Peter.
When interrupt occurs, EIMSK,1 is set to zero disabling further INT1
interrupts. Interrupt routine loads T1 for 50ms debounce timeout and goes
into infinite loop waiting for T1 timeout.
It really doesn't matter. As I stated before, if I do an RETI as the first
instruction in the interrupt routine, it doesn't return.
The vectors are all standard assignments for a 168 with 16k flash.
Stack appears to operate properly if INT0 and Timer1 interrupts function.
It's a bugger. Have sent code to Atmel FAE to get his opinion. Might, maybe
get it on Monday.
Otherwise, more head-banging.
Dennis
Sent: Saturday, August 20, 2005 11:17 PM
>> one?
> Peter.
2005-08-21 by Mark Nowell
Dennis
FWIW I'm using both INT0 and INT1 on M168 with no problems ... now. I did
spend several hours banging my head against these interrupts because a) I'd
used the wrong vector names; b) more than one of the bit defs in the
avr-libc headers were wrong. The latest WinAVR appears to correct the bit
defs but it sounds as though you're using asm anyway?
Mark
Sent: Sunday, August 21, 2005 5:31 AM
> maybe
> get it on Monday.
> Thanks
> Dennis
Changed vector names from ZCINT0 to EXT_INT0 and PBINT1 to EXT_INT1 per the
168 data manual. Still the same results. More head banging.
D
Sent: Sunday, August 21, 2005 1:39 AM
> Dennis
> I'd
> Mark
> From: "Dennis" <dkazar@sbcglobal.net>
>> first
>> maybe
>> get it on Monday.
>> Thanks
>> Dennis
2005-08-21 by Thomas Keller
> returns.
   Stop banging your head!  It hurts!      *grin*
   Seriously, wait for the FAE to respond.  I suspect you have located a
legitimate bug in the hardware, anfd that this is what you'll hear
back.
   While, in general, one assumes that one is making some sort of
obscure error when such things are encountered (which is MUCH more
likely), hardware bugs *DO* occur, and based on your descriptions of
your diagnostics, I suspect you have found one.  Time (and the FAE) will
tell.
Tom
RE: [AVR-Chat] mega 168
2005-08-21 by Larry Barello
It is very, very, VERY UNLIKELY you have stumbled across a CPU problem. It
is very, very LIKELY your code is the problem.  Unless you show us your code
and how you built it (what compiler, etc), there is little anyone can do to
help you.
Cheers!
From: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com] On Behalf
Of Dennis
Sent: Sunday, August 21, 2005 8:09 AM
To: AVR-Chat@yahoogroups.com
D
> Dennis
> I'd
> Mark
>> first
>> maybe
>> get it on Monday.
>> Thanks
>> Dennis
Yahoo! Groups Links
Here is the code using AVR Studio SP3. As I said, I can put the RETI as the
only instruction in the PBINT1 service routine and the same still happens. I
can also take the infinite loop out of the routine (waiting for T1
interrupt), put it following the first infinite loop, and the same happens.
I'm using visual "breakpoints". The processor is generating triggers to an
STM quad AC switch which drives 3 AC driven strings of LEDs.
D
Sent: Sunday, August 21, 2005 12:05 PM
Subject: RE: [AVR-Chat] mega 168
help you.
Cheers!
Of Dennis
D
> Dennis
> I'd
> Mark
>> first
>> maybe
>> get it on Monday.
>> Thanks
>> Dennis
Yahoo! Groups Links
Yahoo! Groups Links
Well, one problem leaps off the page: your have infinite loops which will
never exit.  Interrupt handlers return to the next address to FETCH, not the
next address!  When you jump to yourself, the next address to fetch is
yourself.
I recommend you get rid of the interrupt handler and just poll the timer
overflow bit.  Remember to reset it after it is set.  E.g.
loop:
	sbis	TIRF1, TOV1
	rjmp	loop
	sbi	TIRF1, TOV1
Of Dennis
Sent: Sunday, August 21, 2005 10:28 AM
D
help you.
Cheers!
Of Dennis
D
> Dennis
> I'd
> Mark
>> first
>> maybe
>> get it on Monday.
>> Thanks
>> Dennis
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
2005-08-22 by Dennis
An infinite loop sits there waiting for an interrupt. When the interrupt
occurs, the stack is pushed with the current location. In the AVR, when the
RETI happens, the Global interrupt is re-enabled and the stack is popped+2
for high byte and low byte. That address is the instruction following the
previous one, the infinite loop, ie. it shouldn't go back to the loop.
D
Sent: Sunday, August 21, 2005 6:22 PM
yourself.
loop:
sbis TIRF1, TOV1
rjmp loop
sbi TIRF1, TOV1
Of Dennis
D
help you.
Cheers!
Of Dennis
D
> Dennis
> I'd
> Mark
>> first
>> maybe
>> get it on Monday.
>> Thanks
>> Dennis
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
2005-08-22 by Larry Barello
If what you are saying is true (and it isn't) then this very common
programming idiom won't work since an interrupt on the "rjmp" instruction
will cause it to exit.
Forever:
	Rcall DoThisTask
	Rcall DoThatTask
	Rcall etc
	Rjmp forever
Please re-read my previous response again.  What is pushed is the address of
the next instruction to execute, not the next address.
Cheers!
Of Dennis
Sent: Sunday, August 21, 2005 6:45 PM
D
yourself.
loop:
sbis TIRF1, TOV1
rjmp loop
sbi TIRF1, TOV1
Of Dennis
D
help you.
Cheers!
Of Dennis
D
> Dennis
> I'd
> Mark
>> first
>> maybe
>> get it on Monday.
>> Thanks
>> Dennis
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
What I am saying is the next instruction is not being executed. In an
interrupt driven system, a loop is waiting for the interrupt. When it
happens the process continues from the instruction following the loop. It
doesn't go back to the loop, or not supposed to.
D
Sent: Sunday, August 21, 2005 9:33 PM
> Forever:
> Rcall DoThisTask
> Rcall DoThatTask
> Rcall etc
> Rjmp forever
> of
> Cheers!
> -----Original Message-----
> Of Dennis
> the
> D
> From: "Larry Barello" <yahoo@barello.net>
> the
> yourself.
> loop:
> sbis TIRF1, TOV1
> rjmp loop
> sbi TIRF1, TOV1
> Of Dennis
> the
> I
> happens.
> D
> code
> to
> help you.
> Cheers!
> Of Dennis
> the
> D
> From: "Mark Nowell" <mark@dicam.co.uk>
>> Dennis
>> I'd
>> Mark
>>> goes
>>> first
>>> function.
>>> maybe
>>> get it on Monday.
>>> Thanks
>>> Dennis
>> Yahoo! Groups Links
Hello!! The address of the next instruction to execute is the next
instruction.
D
> Forever:
> Rcall DoThisTask
> Rcall DoThatTask
> Rcall etc
> Rjmp forever
> of
> Cheers!
> Of Dennis
> the
> D
> the
> yourself.
> loop:
> sbis TIRF1, TOV1
> rjmp loop
> sbi TIRF1, TOV1
> Of Dennis
> the
> I
> happens.
> D
> code
> to
> help you.
> Cheers!
> Of Dennis
> the
> D
>> Dennis
>> I'd
>> Mark
>>> goes
>>> first
>>> function.
>>> maybe
>>> get it on Monday.
>>> Thanks
>>> Dennis
>> Yahoo! Groups Links
2005-08-22 by Mark Jordan
> D
	That would happen only if the ISR mess with the Stack.
	Other way the processor stays inside the loop.
	I have used loops waiting for some flag that was changed
inside the ISR.
	Mark
The ISR address must be good otherwise it wouldn't go to the service
routine.
D
Sent: Sunday, August 21, 2005 10:15 PM
>> D
> inside the ISR.
> Mark
2005-08-22 by John Samperi
>instruction.
LOOP0:
         rjmp LOOP0      ;wait for PBINT1 interrupt (pattern select pushbutton)
The above will NEVER go here but it will be stuck forever into the
loop because the next
instruction is rjmp LOOP0 no matter what happens in your interrupt routine.
         cbi PORTD,5
Regards
John Samperi
                         Ampertronics Pty. Ltd.
   11 Brokenwood Place Baulkham Hills, NSW 2153 AUSTRALIA
          Tel. (02) 9674-6495       Fax (02) 9674-8745
                Email: samperi@ampertronics.com.au
                  Website  http://www.ampertronics.com.au
* Electronic Design   * Custom Products   * Contract Assembly
Re: mega 168
2005-08-23 by Volkmar Dierkes
Dennis,
I am sorry, but you are wrong. In an interrupt driven system, an
interrupt may occur at any time. If the serving of the interrupt
would end in returning to a different address, the code wouldn't be
executed in the desired sequence. If you want to wait in a loop
until the interrupt is being serviced, you need to set a flag in the
ISR and check this flag in your loop to exit it at the given time.
Please reread the datasheet to understand the interrupts correctly.
Volkmar
> D
>> Forever:
>> Rcall DoThisTask
>> Rcall DoThatTask
>> Rcall etc
>> Rjmp forever
>> of
>> Cheers!
Re: [AVR-Chat] Re: mega 168
2005-08-23 by Dennis
Not that I disagree with you, however, look at the RETI for th 8051. Also,
check out the RET and RETI instruction explanantion is the instruction set
manual. Both of the latter use the same stack operation implying they
function the same. RET returns to the instruction following the CALL, RETI
does not.
I've changed my code to accomodate the RETI. Doesn't make much sense to have
infinite loops.
RETI (80C51 Instruction Set)
Function: Return from interrupt
Description: RETI pops the high- and low-order bytes of the PC successively
from the stack and restores the interrupt logic to
accept additional interrupts at the same priority level as the one just
processed. The Stack Pointer is left
decremented by two. No other registers are affected; the PSW is not
automatically restored to its pre-interrupt
status. Program execution continues at the resulting address, which is
generally the instruction immediately after
the point at which the interrupt request was detected. If a lower- or
same-level interrupt was pending when the
RETI instruction is executed, that one instruction is executed before the
pending interrupt is processed.
Example: The Stack Pointer originally contains the value 0BH. An interrupt
was detected during the instruction ending at
location 0122H. Internal RAM locations 0AH and 0BH contain the values 23H
and 01H, respectively. The
following instruction
Sent: Tuesday, August 23, 2005 12:50 AM
Subject: [AVR-Chat] Re: mega 168
Dennis,
Volkmar
> D
>> Forever:
>> Rcall DoThisTask
>> Rcall DoThatTask
>> Rcall etc
>> Rjmp forever
>> of
>> Cheers!
Yahoo! Groups Links
Re: [avr] Re: [AVR-Chat] Re: mega 168
2005-08-23 by Don Jackson
> does not.
> infinite loops.
Excuse me for the intrusion, but aren't we discussing the Atmel
ATMega168 rather than an 80C51?
Even then, note in the above for the '51 that it says "Program execution
continues at the resulting address, whis is generally the instruction
immediately after the point at which the interrupt request was detected."
This is also true for the AVR and every other micro I have seen ... but
the key word is "generally".  GENERALLY this means that the micro is
executing sequential inline code and the statement is then true.
Use a simulator or other tool and watch what happens when you step thru
the code.  You should be able to see what return address is pushed onto
the stack in an infinite loop situation (jump to yourself).
In many micros (not all!) the only difference between a RET and RETI
instruction is the treatment of the interrupt flag(s).  An interrupt
will not get you out of an infinite loop unless you somehow alter the
return address on the stack.
Don
2005-08-23 by Mark Jordan
On 23 Aug 2005 at 9:12, Dennis wrote:
> Not that I disagree with you, however, look at the RETI for th 8051. Also, check
> out the RET and RETI instruction explanantion is the instruction set manual.
> Both of the latter use the same stack operation implying they function the same.
> RET returns to the instruction following the CALL, RETI does not.
	Indeed it does. The RCALL is assumed. It can be anywhere in the program.
> infinite loops.
	Why not?  I use them very often.
2005-08-23 by David Kelly
> to have infinite loops.
Every embedded application I have ever written was formed as an infinite
loop.
It doesn't make much sense to have an empty infinite loop waiting on an
interrupt. Its quicker and simpler to poll in that situation.
David Kelly N4HHE, dkelly@HiWAAY.net
Whom computers would destroy, they must first drive mad.
2005-08-23 by John Samperi
>does not.
Well there is an easy way to find out, translate your code to 8051
code and run it in a simulator and see if it works differently to
the AVR and let us know. I have been working with microprocessors for
some 25 years and with at least a dozen different families/architectures
and I haven't seen a processor behave like you expect.
You can use your loop as long as you understand that
loop:
         rjmp loop
will ALWAYS and regardless of what happens anywhere else jumps
to itself so that the next instruction to be executed is rjmp loop
If on the other hand you put some code in your loop that tests
something for true or false and that something can be changed
by an interrupt then it will work well.
Let's say you enter your loop with r16=0 and your interrupt
routine changes it to 1 then you could do the following:
loop:
         tst r16         ;Check if r16 is still 0
         brne exit_loop  ;If no longer 0 then exit the loop
         rjmp loop       ;otherwise keep on waiting
exit_loop:
         more instructions
In your code you seem to test portd for some pattern
put this test within your loop and it will work but
by having an interrupt just happening will not exit
a loop.
Regards
John Samperi
Changed the code. Using GPIOR0,0 as a flag and a test loop on the register
when the interrupt completes. Works fine.
Found what might be another little problem though. The GPIOR0, 1 and 2
registers are supposed to work with the sbi, cbi, sbis and sbic
instructions. GPIOR0 works fine, the others give me an "operand out of
range" error when I build the code.
Dennis
Sent: Tuesday, August 23, 2005 5:01 PM
Subject: Re: [AVR-Chat] Re: mega 168
>>does not.
> loop:
>         rjmp loop
> loop:
> exit_loop:
>         more instructions
> a loop.
> Regards
> John Samperi
Parallel High Voltage AVR910 programmer?
2005-08-24 by Peter Gargano
Well, I finally spent the time to look at app. note AVR910 and now
understand how to make something that should function like an AVRISP
(well, as long as I keep updating the firmware to support newer CPU
cores that I want to program).
The original AVR910 source code mentions [quote] ...
   "The host computer do not need to know if the programmer
    operates in serial or parallel mode."
So, has anyone designed and updated the firmware for a  high voltage
parallel port programmer that otherwise has the same AVR910 interface?
Also, some of the newer AVR910 programmers support extra commands. Is
there an official and updated "AVR910 specification"?
Peter
RE: [AVR-Chat] Re: mega 168
2005-08-24 by Larry Barello
You need to read the data sheet for the mega168 carefully, particularly the
areas of memory access, instruction references and the IO register
descriptions.
I don't know about your particular situation, but many of the newer mega
chips have extended I/O registers (>0x100) which cannot be accessed via
in/out instructions.  The SBI/CBI instructions are limited to the first 32
I/O locations, etc.  So you can have up to three situations:
Sbi/cbi	= classic, low 32 bytes of I/O
In	rx, REGISTER	= classic, upper 32 bytes of I/O
And	rx, 0x01
Out	REGISTER, rx
Lds	rx, memory_location	= new: everything else.
And	rx, 0x01
Sts	memory_location, rx
Depending upon what register you are dealing with.  Make no assumptions
about where grouped registers are located.  Many newer features (extended
timer interrupts, etc) are out in SRAM space since Atmel didn't leave enough
I/O space for the future...
BTW you can use direct memory reference (ld/st, lds/sts) to get to any
register (R0-R31, IO and SRAM) - that can be a very handy feature at times!
I know it is a little weird, but after a while you will begin to appreciate
the tradeoffs that Atmel made when assigning code space to the various
instruction types.
If you want weird, try assembly programming a PIC...
Cheers!
Of Dennis
Sent: Tuesday, August 23, 2005 3:07 PM
Dennis
>>does not.
> loop:
>         rjmp loop
> loop:
> exit_loop:
>         more instructions
> a loop.
> Regards
> John Samperi
Yahoo! Groups Links
2005-08-24 by Dennis
The data manual specifically states that the 3 registers are accessible by
those instructions.
However, point taken. Manuals have been known to be wrong.
If you look at the "include" file it also specifies the register bits.
Maybe avr@atmel.com  hasn't been notified of the manual inaccuracy.
Dennis
Sent: Tuesday, August 23, 2005 8:49 PM
Subject: RE: [AVR-Chat] Re: mega 168
descriptions.
And rx, 0x01
Out REGISTER, rx
And rx, 0x01
instruction types.
Cheers!
Of Dennis
Dennis
>>does not.
> loop:
>         rjmp loop
> loop:
> exit_loop:
>         more instructions
> a loop.
> Regards
> John Samperi
Yahoo! Groups Links
Yahoo! Groups Links
Looked at the PIC for this project. Got somewhat confused at to how may
functions the pins had. Really couldn't determine if it had what I needed.
Haven't checked out the lds etc. instructions with the GPIOR yet.
Another day dawns
D
Sent: Tuesday, August 23, 2005 9:07 PM
those instructions.
Dennis
descriptions.
And rx, 0x01
Out REGISTER, rx
And rx, 0x01
instruction types.
Cheers!
Of Dennis
Dennis
>>does not.
> loop:
>         rjmp loop
> loop:
> exit_loop:
>         more instructions
> a loop.
> Regards
> John Samperi
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
