AVR-Chat
Why is it so!
Why is it so!
2005-03-19 by John Samperi
G'day
We I finally got my updated board with the M64 on
Friday. Put it together and got it running with some
simple code, USART0 and USART1 talking to 2 terminals
and the mandatory flashing led. The led uses timer
overflow 1 (4.095ms) and a register dec from 127 to
give about .5 sec flashes in the int routine. The code
was ported from another app using the m8. Here is the
strange part. The led would flash 3 times correctly,
the 4th ON time was about twice as long, it would then
flash 5 times correctly, the 6th OFF time was about
twice as long, it would then flash 6 times correctly,
the 7th OFF time was about twice as long. It would then
repeat the sequence! For 2 days!
This morning (+-6am) I felt the need for a jtagice
(nope not expecting) but being Sunday morning no chance
of getting one in a hurry...unless..look up bootleg info
about jtagice, adatpt one of my DXIO-6 module which uses
M8535 (pin compatible with m16) some veroboard and some
connectors and voila, instant jtagice //BRAG MODE ON//
It worked first go!//BRAG MODE still ON// :-)
Meanwhile back at the range...something happened by enabling
disabling OCD and JTAG on the M64. The LED now flashes correctly
even without jtag or programmer plugged in i.e. as it should.
The question remains: Why is it so! Why is the timer now working
as it should? Anyone has any ideas? No I haven't changed anything
in the code, just played around with the 'fully working' jtag.
By the way Dave, I learned from your problems with the Int vectors
last week and copied and pasted them directly from the M64 PDF
into my code. :-))
Regards
John Samperi
                         Ampertronics Pty. Ltd.
   11 Brokenwood Place Baulkham Hills, NSW 2153 AUSTRALIA
          Tel. (02) 9674-6495       Fax (02) 9674-8745
                Email: samperi@ampertronics.com.au
                  Website  http://www.ampertronics.com.au
* Electronic Design   * Custom Products   * Contract Assembly
Re: [AVR-Chat] Why is it so!
2005-03-20 by Russell Shaw
John Samperi wrote:
> G'day
Where do you get the firmware to turn a mega8535 into a jtagice?
Could have something to do with the setting that allows timers
to be stopped or run at full speed during jtag single-stepping.
> into my code. :-))
2005-03-20 by John Samperi
It is not a 8535 but a M16. The board DXIO-6 uses a 8535
which is pin compatible with the M16 so it was quite easy to build
the circuit for the ice as 90% of the stuff is already there i.e.
Power supply, RS232, oscillator etc. The programming socket carries
power and 3 of the signals required fo the ice...so a little veroboard
some connectors a few components and it's all done.
For firmware just do a search for jtagice and you will come
up with lots of usefull info ;-) then Studio does the upgrade to
the lastest firmware.
Maybe...now it's flashing sporadically with the ice back on.
Lots of new stuff to learn and many questions to ask....
Regards
John Samperi
I know a guy that tried that with a mega16 but avr studio wouldn't
see it as a jtag ice. The jtag ice mk-I has a mega163 in it. So you're
saying the firmware from avr studio works unmodified in a mega16? If so,
i'll have another look at his pcb.
Make sure the ice isn't automatically changing any clock fuses,
or loading down VCC on the target pcb.
You need a proper bootloader in the M16 before studio sees it as a
jtagice, you can then manually upgrade it with AVRprog. The M163
is no longer made but there would be some floating around. The M16
works. There is lots of info on how to get the bootloader set up and
manually upgrade the jtag (DN11 from avrfreaks) and at least one
bootloader...'Out There'..on the net.
Regards
John Samperi
2005-03-20 by Ron
The commercial ECROS JTAGICE uses a MEGA16 and it simply
works without any bootloaders or special considerations and it
was upgradeable with Studio 4.11. Ron
Sent: Sunday, 20 March, 2005 02:29 PM
Subject: Re: [AVR-Chat] Why is it so!
Regards
John Samperi
2005-03-21 by John Samperi
They put the bootloader in ;-) But if you have a blank
M16 (let's say your chip blows up and you want to fix
the ice)then it needs the bootloader to talk to Studio.
It's a once off thing.
Regards
John Samperi
Re: Why is it so!
2005-03-21 by upctoys
> into my code. :-))
> Regards
> John Samperi
John,
I havn't played with the JTAG on AVRs,but I have with CPLD's. I know
that CPLD's can play strange games if some of the JTAG pins are left
unconnected (floating) even if they aren't being actively used. Seems
to work fine on the bench with the dongle hanging from it but soon as
it is left to it's own devices intermittant random events can and do
occur.
Just wondering if something similar is happenig with oyur board.
Rgds
Stefan
Re: [AVR-Chat] Re: Why is it so!
>occur.
Status update: OCD and JTAG enabled but no jtag cable connected,
lots more code into the M64. Led flashing happily, messages
being sent out correctly on RS485 com (usart1), relay clicking normally...
it is starting to look and feel just like a bought one :-)
I'll leave it running on it's own overnight. This morning it was flashing
erratically, perhaps I had some junky test code. I'm now starting to put
in it real code and it seems ok. No doubt there will be lots of questions
as I venture out of the comfortable 8K memory boundaries, some of the
registers in the large chips seem to be a bit of a dog's breakfast....
not that there is anything wrong with that!
Regards
John Samperi
2005-03-21 by Ron
Yes I agree, I mis-understood the point of the question. Ron
Sent: Sunday, 20 March, 2005 10:59 PM
Regards
John Samperi
Vector table in assembler.
2005-03-21 by Dave VanHorn
For speed, I need to have a bunch of operations that I would normally loop,
set up in straightline code.
I also need to control how many of these operations that I execute, by
varying the entry point.
I seem to remember a way to implement vectored jumps, but I can't think
what it was offhand.
Each entry might be 6-10 instructions, and there may be 256 of them, so
whatever it is, needs to not use rjmps.
Definitely trading codespace for speed here!, and one of the few places
where I'm likely to use a macro.
Re: [AVR-Chat] Vector table in assembler.
2005-03-21 by Dennis Kazar
How about an offset table using index referencing another using indexing
main table of values.
D
To: <AVR-Chat@yahoogroups.com>; <AVR-Chat@yahoogroups.com>
Sent: Monday, March 21, 2005 1:21 PM
Subject: [AVR-Chat] Vector table in assembler.
> loop,
Checked by AVG Anti-Virus.
Version: 7.0.308 / Virus Database: 266.7.4 - Release Date: 3/18/2005
[AVR-Chat] executing a code block 0 to ?? times
2005-03-21 by wg0z@aol.com
one way is to use a subroutine that consists of computational code followed by 1 to 256 occurrences of the macro followed by a RET instruction.
use the computational code to compute start_address as (address_of_RET_instruction - macro_size * number_of_executions_desired), then jump to start_address.
get it?
if the macro size is a power of two then (macro_size * number_of_executions) may be implemented as
"number_of_executions << logbase2(macro_size)"
To: AVR-Chat@yahoogroups.com; AVR-Chat@yahoogroups.com
Sent: Mon, 21 Mar 2005 14:21:35 -0500
Yahoo! Groups Links
2005-03-21 by Henry Carl Ott
ijmp?
i do something like this:
                 add     zl,ax25_rx_count
                 adc     zh,zero                 ; if a carry from low
order add it in
                 ijmp
;--- jump table
rx_jmp: rjmp    rx_flag                 ;0 flag
                 rjmp    rx_add_5                ;1 zero stuff, add five
ones toss zero
                 rcall   rx_add_1                ;2 11110
                 rcall   rx_add_1                ;3 1110
                 rcall   rx_add_1                ;4 110
                 rcall   rx_add_1                ;5 10
                 rjmp    rx_add_0                ;6 0
                 rjmp    rx_flush                ; error, too soon
-carl
>ijmp?
Ah, I hadn't actually ever used Ijmp before, so I had forgotten it was in
there
Thanks.
Small computers
2005-03-22 by Dave VanHorn
Harkening back to the discussion of a week ago, is anyone using, or aware
of a pocket-pc sort of device that could run studio?
Re: [AVR-Chat] Small computers
2005-03-22 by Michael Haisley
Dave, i've done some reasearch this way...do you really need a pocket
pc?  If so, that does significantly limit your options...  Tiqit
really makes about one of the only toys out there that will do what
you need, but you can't get them yet (they have them, i've seen them,
but they aren't shipping yet)    OQO also makes a good device, they
stray a little bit from the traditional hand held form factor, but it
appears to be well worth it, considering the specs.
All in all, I like the oqo, much better than I do the tiqit, but it's
really a matter of if you need the traditional handheld formfactor.  I
just recently got myself pushed into the market for a new laptop, and
am looking small, if funding were not an object, the OQO is the way
that I would go myself.
http://www.oqo.com/hardware/specs/
http://www.tiqit.com/specs.shtml
On Mon, 21 Mar 2005 21:31:35 -0500, Dave VanHorn <dvanhorn@dvanhorn.org> wrote:
>  Yahoo! Groups Sponsor
>  ADVERTISEMENT
>  ________________________________
>  Yahoo! Groups Links
> To visit your group on the web, go to:
> http://groups.yahoo.com/group/AVR-Chat/
> AVR-Chat-unsubscribe@yahoogroups.com
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
