AVR-Chat
comms problem
comms problem
2008-04-05 by Brian
I made a program in asm that kinda works. the only problem is when my
mega16 xmits to hyperterminal I get weird symbols. I am working with
4Mhz 4800 baud. the letters in sram are in hex format. But the
symbols in HT look like they are from the extended ascII table. My
baud rate is set at 0x51. Has anyone else have a simliar problem?
Brian
main:
	ldi	ZH,high(message*2)	; Load high part of byte
address into ZH
	ldi	ZL,low(message*2)	; Load low part of byte
address into ZL
	clr	r0					;
menu:
	lpm						; Load byte
from program memory into r0
	nop						;
	nop						;
	tst	r0					; Check if I
reached the end of the message
	breq	run				; If so, continue
	mov treg, r0			;xmit message
	rcall txcomp			;
	adiw	ZL,1			; Increase Z registers
	rcall menu				;
message:
	.db     $50,$72		; P ,r
	.db     $65,$73         ; e ,s
	.db     $73,$20         ; s ,SP
	.db     $61,$6E         ; a ,n
	.db     $79,$20         ; y ,SP
	.db     $6B,$65         ; k ,e
	.db     $79,$20         ; y ,SP
	.db     $74,$6F         ; t ,o
	.db     $20,$63         ; SP,c
	.db     $6F,$6E         ; o ,n
	.db     $74,$69         ; t ,i
	.db     $6E,$75         ; n ,u
	.db     $65,$0A         ; e ,LF
	.db     $0A,$0D         ; LF,CR
	.db     $00,$00         ; END
Re: comms problem
2008-04-06 by Brian
--- In AVR-Chat@yahoogroups.com, "David VanHorn" <microbrix@...> wrote:
> What is the call to txcomp?
> Normally, I poll the tx tg empty flag before sending a char
txcomp: sbis UCSRA,UDRE      	;poll to check end of transmission
        rjmp txcomp		;
        out UDR, treg		;
        ret			;
Everything seems to work except the characture translation.
Brian
Re: comms problem
2008-04-06 by Brian
--- In AVR-Chat@yahoogroups.com, "Ranjit Puri" <ranjit.puri@...> wrote:
> Are you using an external crystal or internal RC Osc ? In case you
are using
> RC to derive clock you might want to shift the value in UBRR +/- 2.
I have tried +/-2, 4, and 5. It changes the charactures but not
readable.
If it helps...
In studio4 my int clock is read as 3.686Khz.
Brian
Re: [AVR-Chat] comms problem
2008-04-06 by Ranjit Puri
Are you using an external crystal or internal RC Osc ? In case you are using
> Brian
> main:
> address into ZH
> address into ZL
> clr r0 ;
> menu:
> lpm ; Load byte
> nop ;
> nop ;
> tst r0 ; Check if I
> rcall txcomp ;
> rcall menu ;
> message:
> .db $50,$72 ; P ,r
> .db $65,$73 ; e ,s
> .db $73,$20 ; s ,SP
> .db $61,$6E ; a ,n
> .db $79,$20 ; y ,SP
> .db $6B,$65 ; k ,e
> .db $79,$20 ; y ,SP
> .db $74,$6F ; t ,o
> .db $20,$63 ; SP,c
> .db $6F,$6E ; o ,n
> .db $74,$69 ; t ,i
> .db $6E,$75 ; n ,u
> .db $65,$0A ; e ,LF
> .db $0A,$0D ; LF,CR
> .db $00,$00 ; END
Ranjit
2008-04-06 by David VanHorn
Re: comms problem
2008-04-06 by Brian
--- In AVR-Chat@yahoogroups.com, John Samperi <samperi@...> wrote:
> ?? You DID say 4 MHz before, which is it? Are you using
> a crystal for the clock? If not you can pretty much
> forget about decent and stable comms.
> How is the USART initialized?
> Are you trying to disguise you message?
> What's wrong with:
> message:
> .db "Press space key to continue", $0A,$0A,$0D,$00
> Unless you are using a very old chip you may also want to try:
> lpm rx,z+
> where rx is any unused register.
> Regards
> John Samperi
I am using the atmega16l. I programmed the fuse bits for internal
4Mhz. When I read the stk500 osc in studio4 it says 3.686Mhz. I have
tried various baud rate setting +/- a couple from $51 to UBRRL.
As far as I know, when using lpm the result is stored in r0. I am
limited in info right now, just learning.
When I make a program to echo what I type it works and I see what I
type in HT. But trying to pull data from ram and send it to HT it
doesnt work. I was thinking that sending a hex character to HT it
would show in ascII format so I can read it.
Brian
Re: [AVR-Chat] Re: comms problem
2008-04-06 by John Samperi
What's wrong with:
message:
lpm rx,z+
Regards
John Samperi
Ampertronics Pty. Ltd.
11 Brokenwood Place Baulkham Hills, NSW 2153 AUSTRALIA
Tel. (02) 9674-6495       Fax (02) 9674-8745
Email: john@ampertronics.com.au
Website  http://www.ampertronics.com.au
*Electronic Design * Custom Products * Contract Assembly
Ok things are a bit clearer now. With the STK500 you have to put the
OSCSEL jumper correctly. You can have the internal clock, the external
crystal clock or the STK500 generated clock which is what you are reading
with Studio. Read up on the OSCSEL to see how to set this correctly,
it's in the Studio help file as well as the docs you got with the STK.
The one in Studio is the latest.
>I have
Get the above correct first.
Correct, so it will work as you have it, however the chip will also
support the more advanced version I showed you ant you save a bit of
code. Not important at the moment
The program is NOT reading data from ram but from flash with lpm.
Your string is stored in flash, so unless you have a routine to read
it from there and put it into ram you will be reading random rubbish.
HOWEVER if you want to read from ram lpm is not good, you will need to
use lds.
Regards
John Samperi
Re: comms problem
2008-04-06 by enkitec
> Brian
> main:
> address into ZH
> address into ZL
> 	clr	r0					;
> menu:
> 	lpm						; Load byte
> 	nop						;
> 	nop						;
> 	tst	r0					; Check if I
> 	rcall txcomp			;
> 	rcall menu				;
Wouldn't this last instruction be "rjmp menu"?
Mark Jordan
Re: comms problem
2008-04-06 by Brian
> > menu:
> > 	lpm						; Load byte
> > 	nop						;
> > 	nop						;
> > 	tst	r0					; Check if I
> > 	rcall txcomp			;
> > 	rcall menu				;
> Mark Jordan
Yes it should be. I got carried away with my calls.
Brian
The internal oscillator isn't guaranteed to be accurate enough for serial.
It works, but it may not always work. If the baud rate is wrong,
you'll get odd translations.
Re: comms problem
2008-04-06 by Brian
serial.
Whoo hoo I figured it out (after about 30 hours of trial and error).
The mega16 has 3 buffer levels not 2 (I read this about a dozen times
in the data sheet but didnt think anything about it). So when figuring
out baud rate for UBRR you have to use 24 in the calculation not 16.
I kinda understand this but if anybody has more information to clear it
up would be great.
Brian
Re: comms problem
2008-04-06 by Brian
> Good for you! I don't know what you are talking about. :-)
> Regards
> John Samperi
In previous post I said I was having problems with comms between the
mega16 and hyperterminal.
 I was referenceing
http://www.avrfreaks.net/index.php?
name=PNphpBB2&file=viewtopic&t=45341&highlight=usart
when I was writing my program. that is where I ran into problems. It
is a general tutorial and not custome to the mega16.
Brian
2008-04-07 by John Samperi
Regards
John Samperi
RE: [AVR-Chat] Re: comms problem
2008-04-07 by Brian Fairchild
>-----Original Message-----
>From: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com] On
Behalf Of Brian
>up would be great.
Have a look at the Mega16 datasheet on page 145 and you'll see that
nowhere does it say to use 24 as a UBRR divisor, it's always 16 (or 8
for double speed mode). If you're having to use 24 then either your
clock speed is wrong or you ar esetting the wrong divisor. You stated
that '0x51' is the correct divisor, however it should be a decimal '51'
not hex '51' which is what you are setting.
Brian (another one)
Checked by AVG.
Version: 7.5.519 / Virus Database: 269.22.8/1362 - Release Date:
06/04/2008 11:12
Re: comms problem
2008-04-07 by Brian
8
stated
decimal '51'
> Brian (another one)
I have read the datasheet. I'm not sure why it worked but it does and
yes I would like to figure it out.
I have uploaded photos for my clock signal for a 2.4576 xtl
http://tech.ph.groups.yahoo.com/group/AVR-Chat/photos/view/ba64?b=1
and the data stream set at 9600 baud.
http://tech.ph.groups.yahoo.com/group/AVR-Chat/photos/view/ba64?b=2
Is there a prescaler for the system clock? Not sure what to look at
next to figure it out.
Brian
2008-04-08 by dlc
Could we be having a "Mars Rover" problem?  0x16 = 22 decimal (close to
24), could this be a hex vs. decimal thing?
Just a blind speculation,
DLC
> 8
> stated
> decimal '51'
>> Brian (another one)
> Brian
Dennis Clark          TTT Enterprises
www.techtoystoday.com
2008-04-08 by Brian Fairchild
>> You stated that '0x51' is the correct divisor, however it should be a
decimal '51' not hex '51' which is what you are setting.
>Not sure what to look at next to figure it out.
>Brian
See my comments about '51'.
Brian (the other one)
Checked by AVG.
Version: 7.5.519 / Virus Database: 269.22.9/1364 - Release Date:
07/04/2008 18:38
Re: comms problem
2008-04-08 by Brian
be a
> >Brian
OK, I am using a 2.45Mhz xtl, verified buy a digital oscope, remove the
xtl and the chip doesnt work so I should have my fuses right, and baud
rate of 9600. My UBRR is set at 10 to get good comms. I am using 16 as
a divisor, the date sheet says to use 12 as UBRR for 2Mhz. Why am I
needing a lower number for a little highter freq? Is it ok/common for
this? I am using a USB to serial to the computer and my STK500.
Brian
Re: comms problem
2008-04-08 by Brian
> Which base are all those numbers in?
> 0x10 <> 10 <> 00000010b
Sorry I didnt mention. it is in hex.
	ldi r16, 0x10					;Set baud rate
	ldi r17, 0x00					;2.45M xtl 9600
baud
	out UBRRH, r17					;
	out UBRRL, r16					;
This works on my computer at home and at work.
Brian
2008-04-09 by David VanHorn
Re: comms problem
2008-04-09 by Brian
> ...and by the way from which data sheet did you get that value from?
> I know you must HAVE double checked the data sheet already....
> Regards
> John Samperi
The problem came from understanding the STK500. I measured the freq it
was using, nomatter what I set the fuses at it was set at 16Mhz, I was
thinking 8Mhz which i set it to, that may be why 24 worked, measured
from the xtl1 pin. I put my own xtl in to make sure it was operating at
the freq i knew. It now makes sence.
Brian
P.S. If anyone wants to shoot me down or tell me what I do wrong I will
not get mad just strive to be better and learn more. My goal is to be
the best so that I can teach others to be better. not to mention AVR's
are so much fun. I love to see them do what I tell them to do.
2008-04-09 by John Samperi
So far we have had:
And I guess you did read all of my suggestions from the 6th??
Regards
John Samperi
Regards
John Samperi
Re: comms problem
2008-04-09 by Stefan Wimmer
it
was
measured
operating at
Dear "blue eagle" Brian,
My problem comes from understanding what exactly you are doing and
what you want to acheive: Does the text above mean that you use an
external clock source (crystal, resonator, STK500 clock circuitry)
and try to use the AVR fuses to change the frequency? Or do you use
the AVR internal RC clock generator and program it for different
frequencies (then please tell me how you get it to 16MHz!)?
Maybe you stop providing only small puzzle pieces of info and start
this thread all over again by describing what you want to do, what
you tried so far and how it failed?
will
Nobody wants to shoot you (- or, well, now that you mention... ;-)),
but sometimes people (not only you) make it rather difficult to
understand their problem in order to be able to provide some help.
2008-04-09 by Raymond Hurst
Hmmm...the highest frequency in my STK500 is 7.37 MHz provided by the
crystal (XC200).
Is this a new design?
Ray Hurst
Western Digital
20511 Lake Forest Drive
Lake Forest, CA 92630
949-672-9853
From: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com] On Behalf
Of Brian
Sent: Tuesday, April 08, 2008 8:44 PM
To: AVR-Chat@yahoogroups.com
Subject: [AVR-Chat] Re: comms problem
> Regards
> John Samperi
Brian
Brian,
For a 2.4567 MHz xtal:
            UBRR = (2456700/(16 * 9600)) - 1 = 15
Using 16 for UBBR:
            Baud = 2456700/(16 * (UBBR + 1)) = 9031.98
%error = (9600 - 9301.98)/9600 * 100% = .06%
Having a UBBR of 15 has not error, UBBR of 16 has a .06% error.
This is probably acceptable for single character transfers but I direct you
to page 168 of the ATmega16L data sheet for a discussion on the effect of
the baud error rate on data transfers.
Ray
Of Brian
> Regards
> John Samperi
Brian
2008-04-09 by David Kelly
Try again. Error is 3.1%. 2% is the commonly accepted worst case
mismatch.
David Kelly N4HHE, dkelly@HiWAAY.net
Whom computers would destroy, they must first drive mad.
Thanks for the correction.
Gotta replace that calculator.
Ray Hurst
Of David Kelly
Sent: Wednesday, April 09, 2008 10:10 AM
Subject: Re: [AVR-Chat] Re: comms problem
mismatch.
David Kelly N4HHE, dkelly@HiWAAY.net <mailto:dkelly%40HiWAAY.net>
