Re: [AN1x] Digest Number 1687
2006-01-13 by daxe
> Seing an ad for the KaossPadII I just had to think of one advantage of those pads against joysticks: dicontinous changes. excellent point! > the JStick of the darkstar sends out > > X axis midi left right CC 30 > Y axis midi up down CC 31 There are several joystick assignments which you can switch internally on the XP2, do they not change the CC? > u will need a midi cc remapper via PC to control the WStation 16 and 17 > not very practical indeed ;-) I actually was messing around with this yesterday and realized that running the XP2 into the computer so MIDI-OX can remap, then send it out and back through the router or into the controller or something on the way to the WS is hardly practical. As you note! > .. add a Doepfer to the an1x it will make it a perfect controller ;-) Except the Doepfer stuff is somewhat expensive. I am leaning towards the KAOSS pad or maybe just buying a Korg Z1 to use as a controller. And a synth. :o) Thanks to everyone, I will report back on what I end up with. ~snakefooot
