re: atmospheric choir
2005-03-06 by spaceanimals
You might want to dissect the "We All Die" patch to get an idea how
to get the oohs and ahhs.
Rainbow Jimmy
RE: [AN1x] re: atmospheric choir
2005-03-06 by Ed Edwards
> Rainbow Jimmy
That's a serious throwdown, Jim!
I think we should challenge anyone on the list to give a quality explanation of
this patch.  It's one of the most mysterious peices of synth programming I've
ever heard.
Ed Edwards
Leader: Ezekiel's Wheel  \ufffd\ufffd\ufffd\ufffdRetro-Progressive Rock\ufffd\ufffd\ufffd\ufffd
http://www.ezekielswheel.com
http://www.untiedmusic.com/ezekiel
http://www.headholemines.blogspot.com
\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd
Re: [AN1x] re: atmospheric choir
2005-03-07 by Dan
Is that patch in the files section somewhere (or where could I get
it)?
--- In AN1x-list@yahoogroups.com, "Ed Edwards" <edward.edwards@v...>
how
> > Rainbow Jimmy
explanation of
programming I've
> ever heard.
> Ed Edwards
> Leader: Ezekiel's Wheel  »»»»Retro-Progressive Rock««««
2005-03-07 by Jon
> it)?
Its factory preset 119. You should be able to rtire the individual voice using AN1xEdit and
one of the copies of the factory defaults in the files section - or you can reinit your AN1x
and retrieve it that way.
Jon
2005-03-07 by Dan
voice using AN1xEdit and one of the copies of the factory defaults
in the files section - or you can reinit your AN1x and retrieve it
that way.
Cool, I'll open the AN1X factory bank in my AN200 editor and look
for it in the patch listing.
We All die (was Re: [AN1x] re: atmospheric choir
2005-03-09 by Jon
> > Rainbow Jimmy
> ever heard.
okay, I restored the factory presets to my AN1x and voice 119 is 'We All Die' (not too be
confused with the 80's classic "I Die, You Die'!)
It's not an arpeggio but rather a 4 step sequence at 90 bpm stored with the voice - C3 and
C4 triggering both voices. Each note is a whole measure, HOLD is enabled and the Seq is
stored with the Voice.
The Voice is in Split Mode. Basically, each scene is set to Sync+FMSlv with maximum,
negative settings for Sync and FM - the Pitch Dpth value controls the 'iiiie' sound but only
because the VCO1 is transposed down three octaves! The 'd' sound appears to be the
result of VCO2 which is transposed upwards nearly two octaves, but the fine tuning is
nearly 40 cents flat. Again, play with the Pitch Dpth and it makes sense. Both scenes in the
voices are VERY similar - mostly differences in Pitch, Fine Tuning and Pitch Dpth. The split
in combination with the Seq is how the DIE die DIE die effect is achieved. Whoever thought
this is up was friggin' brilliant.
Jon
2005-03-09 by Dan
It sounds completely different when played on the AN200 but I
definitely hear the osc. sync.  The AN200 doesn't have split mode
and I'm not sure if the sequencer is the same as the AN1X's.
appears to be the
the fine tuning is
> Jon
2005-03-09 by uralmoto2001
I can hear it say "we all die" using plg150an(scene 1 only); the step
sequencer is an essential part of the patch.  An equally mysterious
patch for DX-7 people: in sysex bank 0042 is a patch called "Why 2".
Play a note near mid C and a male voice clearly says "WHY!". No idea
how they got a DX-7 to talk...
> I can hear it say "we all die" using plg150an...  When I send
the "we all die" patch from AN expert editor, I can hear the "we all
die" voice.. When the same patch is loaded into userbank from
smartcard file, I don't hear quite the same sound. Odd...
Re: We All die (was Re: [AN1x] re: atmospheric choir
2005-03-09 by Andrew
The Yamaha computer that was out about the same time as the DX7 and DX9 and
with the same chip (CX5M, was it?) used to have a speech command.
Accordingto Dave Bristow, Yamaha's demonstrator at the time, the command was
only in the Japanese manual because, according to Yamaha, the computer only
spoke Japanese.  But he was able to get it to speak several European
languages with a heavy Japanese accent by putting in almost joke-Japanese -
e.g. `haro' for `hello.'  It worked, too.  He used to demonstrate this, and
I've been there when he did it.
So in theory the DX7 should be able to say a few things, though in practice
it may not have the command structure for it?
- Andrew
RE: We All die (was Re: [AN1x] re: atmospheric choir
2005-03-09 by Giblet
> and
> was
> only
You can make anything with a programmable 'beep' simulate speech.
A common add-on for DOS was a "speak" program that made the PC speaker
simulate text-to-speech. No sound card mind you, just the inherent PC beep
speaker.
2005-03-10 by Ed Edwards
Here Giblet has gone and poked his face right out of the window into the fog.
"You" (who? scientists maybe?) can make "anything" (what? methane, a Casio
watch, maybe your car horn?) with a programmable 'beep' (like your car?)
simulate speech (what language?).
Gilbert, the abilities of any synthesizer depend upon the design.  You are
mistaken in thinking that the AN series of synths has a simplified means of
emulating speech.  The programmable beep that you speak of must be modulated
with a complex waveform to produce an output that has the intricate qualities of
speech.  The AN series has only a simple set of internal waveforms available for
modulation (sine and pulse being the most prevalent).  There is no "audio in"
function in this synth.
You shouldn't presume that producing a sound resembling speech is an easy task.
It requires special algorithms, programming and wave storage.
Again: The "We All Die" patch is a masterpiece, very clever and very complicated
to produce.  Jon has done an excellent job of dissecting it for us to examine
and possibly modify.
Ed Edwards
Leader: Ezekiel's Wheel  >>>>Retro-Progressive Rock<<<<
> -----Original Message-----
> From: Giblet [mailto:phw@...]
> Sent: Wednesday, March 09, 2005 4:57 PM
> To: AN1x-list@yahoogroups.com
> Subject: RE: We All die (was Re: [AN1x] re: atmospheric choir
> > and
> > was
> > only
> speaker.
> Community email addresses:
>   Post message: AN1x-list@yahoogroups.com
>   Subscribe:    AN1x-list-subscribe@yahoogroups.com
>   Unsubscribe:  AN1x-list-unsubscribe@yahoogroups.com
>   List owner:   AN1x-list-owner@yahoogroups.com
> Shortcut URL to this page:
>    http://groups.yahoo.com/group/AN1x-list
> The AN1x Control Synthesizer FAQ::
>   http://www.geocities.com/jondl_2000/an1x_faq/an1x_faq_toc.htm
2005-03-10 by Giblet
> fog.
'You' == anyone who knows how to modulate speech with an oscillator. There
are lots of white-papers and books on the subject. A PC speaker is driven by
a square wave generator whose only programmable parameters are duty cycle
and frequency. If one can make THAT talk, then one can make a dog's
squeak-toy talk if one is persistent enough.
No algorithm is required at the an1x end -- only at the PC end.
While the interface to an AN1x's oscillators is indirect and primitive
compared with the PC's directly-programmable oscillator, it can't be all
THAT difficult to synthesize short waveform sequences on a PC and transfer
those to the synth. I've played with speech synthesis under DOS (I *am* a
scientist) on a PC but maybe I should shut up until I actually DO it on an
an1x... Don't hold your breath on that - it just isn't worth the effort.
There are several TTS examples available on the web, in assembly and C
languages. One can use them to observe the waveforms of those words one
wishes to duplicate on the an1x and 'simply' duplicate the waveform. (What
could be simpler, eh?)
This would be an interesting exercise, but a total waste of time. A Triton,
or any other sampler, can talk its fool head off right out of the box.
2005-03-10 by Dan
>A Triton, or any other sampler, can talk its fool head off right
out of the box.
The Waldorf Microwave 1 has a speech synthesizer that,
unfortunately, wasn't included on my Microwave II.
There was an old Commodore64 program called S.A.M. that did a pretty
good job of speech synthesis.  (You just typed in phrases/sentences
and it would speak them.)
Didn't mean to start a flame.
I'm not a scientist, but I've played one at work in the past... PCM through a PC
speaker is painful enough to force confessions from hardened criminals.
My pint is that the AN1x and its buddies don't have the programmability to do
much exciting stuff.
Ed Edwards
> Sent: Thursday, March 10, 2005 8:35 AM
> > fog.
2005-03-10 by Dale Kay
http://www.analogx.com/contents/download/audio.htm
another fellow musician and programmer... he has a lot of tools and stuff to play with... see his audio programs...(i.e. say it)
dale
Administrator for Kay-Net.com
admin@...
Lancaster CA
Band Web pages
Inquisitor Betrayer
http://www.soundclick.com/bands/7/inquisitorbetrayermusic.htm
Angel's Wings
http://www.soundclick.com/angelswings
Are you a musician that needs to promote yourself or tell everyone about your musical event?
 promotions_n_events-subscribe@yahoogroups.com
is designed just for this.
  Sent: Thursday, March 10, 2005 6:34 AM
  Subject: We All die (was Re: [AN1x] re: atmospheric choir
  out of the box.
2005-03-10 by Summa
well, there's a software named Cantor from Virsyn that can create synthetic
speach, vocals and choir sounds...
Very simple choir sounds can be created using PWM...
FM/Ringmod combination or prefiltered FM/Ringmod can do nice vowel sounds too...
More sophisticated ones need formant synthesis or formant filters (at least 3
parallel bandpass filters).
...Summa
> dale
> admin@...
> Lancaster CA
> Band Web pages
> Inquisitor Betrayer
> Angel's Wings
>   ----- Original Message -----
>   From: Dan
>   out of the box.
> --------------------~--> In low income neighborhoods, 84% do not own
> computers. At Network for Good, help bridge the Digital Divide!
> http://us.click.yahoo.com/c9hWNA/3MnJAA/n1hLAA/QnLolB/TM
CZ/VZ 		mailing list	: http://groups.yahoo.com/group/CZsynth
FMHeaven	mailing list	: http://groups.yahoo.com/group/fmheaven/
FS1R 		mailing list	: http://www.ampfea.org/mailman/listinfo/fss-list
Vokator		mailing list	: http://groups.yahoo.com/group/vokator
Wellenform Chat  So and Do 22.00 CET: http://chat.moogulator.com/
I believe my band member has that one and another one which he can create singing voices...
(analogx stuff is free...)
dale
admin@...
Lancaster CA
Band Web pages
Inquisitor Betrayer
Angel's Wings
  Sent: Thursday, March 10, 2005 9:45 AM
  Subject: Re: We All die (was Re: [AN1x] re: atmospheric choir
  ...Summa
2005-03-11 by Dale Kay
ok got it wrong (no suprise for most here, I do get wires crossed
between my ears...) it is Miriam that he has and he cant get it to
install correctly to even try to use. He has a mac and it wants a nic
card to authorize too, so he bought a usb one and guess what, does
not work... he has been working with that a few months since the sale
on it... but that is now treading OT for the group... if anyone here
can help on it, do email off list and I will give you his email to
direct contact as I know he would like to get that up and running.
It's candor that Klaus Schulze has a fond likeing too (thinking I
might have that right)... (which by the way he isn't doing too well,
real sick, see his web site...)
But I have to say, I have vocoders on a lot of things here, ION,
MS2000, Trition Extreme, Chameleon (sound art's)my current fav is
using the extreme... I have samples if any wished to hear.. drop load
as they are rather large...I never bought the chip for the
DarkStar... or I could have added that to the list...
Using the filter queen, I have also been able to alter voice, which I
am thinking to try to move this back to topic (near anyway) is the
one of the keys to using an200 types, the filters.
dale
> dale
