sup Bruce
Yeah, the rm1x has a MIDI filter and even when I allow every MIDI-in
message to be accpeted, only some is recorded (i.e. aftertouch). It
doesn't seem to record changes like VCO1 and VCO2 changes (i.e delay,
speed, etc). Here's my setup:
an1x MIDI out > rm1x MIDI in
rm1x MIDI out > an1x MIDI in
an1x MIDI thru > xtreme lead MIDI in
Any thoughts?
--- In AN1x-list@y..., Bruce Wahler <bruce@a...> wrote:
> Hi Dave,
> Anything that you can send from the AN1x to your Xtreme Lead SHOULD
be able to be copied by the sequencer. The AN1x uses standard MIDI
note on/off, control change (CC), and aftertouch commands -- nothing
unusual or fancy. Does your RM1x have a setting to filter out
various MIDI messages? If so, maybe it's filtering some of the
commands.
> >I've been using the an1x to drastically change the sounds from an
emu
> >xtreme lead 1 (sound module). I can get some really wicked changes
in
> >the sounds, however I can't get my sequencer (rm1x) to all record
> >these changes that I've made to the sounds. What I'm trying to do
> >probably isn't possible. But it would be awesome if it were.
> Regards,
> -BW
> Bruce Wahler
> Design Consultant
> Ashby Solutions™ http://consult.ashbysolutions.com
> 978.386.7389 voice/fax
> bruce@a...
