outputs
2001-07-12 by Jake B
2001-07-12 by jondl_2000@yahoo.com
> The outputs on my An1x have hardly any output. It seems like they put out some sound and then fade off really quick. The headphone output works fine but the main left and right is very low. Any ideas what could casue this? It was working fine and then nothing.Yikes!
> TIA,
> Jake
To: <AN1x-list@yahoogroups.com>
Sent: Wednesday, July 11, 2001 9:16 PM
Subject: [AN1x-list] Re: outputs
> > TIA,
> > Jake
> Yikes!
> Jake, I've not heard of that problem with an AN1x. Has anybody else on
> the list?
> Did your AN1x ever exhibit the infamous 'popping and clicking' sound at
> start-up? If so, did you (or a previous owner?) ever have the repair
> affected by Yamaha? I ask these questions only to see if there's any
> relation between the old problem (the audible crackling) and the
> problem you've descibed (audio drop-off.)
> I'd hazard a guess this is a service issue and encourage you to contact
> Yamaha Customer Assistance or a local Service Center. Prefably one that
> you TRUST!. FWIW - I had the hardware repair for the 'old' problem
> completed some time ago and have never had a reoccurence.
> HTH,
> Jon
> Community email addresses:
> Post message: AN1x-list@yahoogroups.com
> Subscribe: AN1x-list-subscribe@yahoogroups.com
> Unsubscribe: AN1x-list-unsubscribe@yahoogroups.com
> List owner: AN1x-list-owner@yahoogroups.com
> Shortcut URL to this page:
> http://groups.yahoo.com/group/AN1x-list
2001-07-12 by Ed Edwards
Sent: Wednesday, July 11, 2001 11:15 PM
Subject: Re: [AN1x-list] Re: outputs
> nope...no clicking or poping at all. Just very little output. Do you
have
> a number to customer service? Also do you think it would be bad to use
> headphone output for now? Becasue I use this synth live and have gigs
> coming up. Also could it be some how one of my other pieces of gear that
> casued the problem. I have a rolls rack mixer and a korg mono poly
running
> through it too. With an older yamaha mixer I had the mono poly would cut
> the output on the rest of the synths to almost nothing. I think it was
just
> the mixer tho.
> TIA,
> Jake
> From: <jondl_2000@...>
> > > TIA,
> > > Jake
> > Yikes!
> > the list?
> > HTH,
> > Jon
Sent: Wednesday, July 11, 2001 11:29 PM
> Sometimes the doctor has to ask personal questions that may embarrass you
> like, "How far was your nose in the young ladies room before she slammed
> door on it?" In your case we'd have to ask, "What are/were you running
your
> outputs into? The output circuitry is looking for a standard line level
> load such as a mixer, keyboard amp or similar input, and without the
proper
> load for the An1x final amps all sorts of bad things may happen in the
> signal chain.
> Ed Edwards
> Leader: Ezekiel's Wheel »»»»Retro-Progressive Rock««««
> http://www.untiedmusic.com/ezekiel
> http://artists.mp3s.com/artists/227/ezekiels_wheel.html
> From: "Jake B" <drummer@...>
> have
> the
that
> running
cut
> just
> > the mixer tho.
> > TIA,
> > Jake
put
works
casue
> > > > TIA,
> > > > Jake
> > > Yikes!
> > > the list?
at
contact
that
> > > HTH,
> > > Jon
Sent: Thursday, July 12, 2001 7:52 AM
> It is being run into a rolls 10 channel stereo line mixer. Which then
runs
> into a 16 channel peavy mixer.
> should be ok
> Jake
> From: "Ed Edwards" <edward.edwards@...>
you
> the
> your
> proper
> > signal chain.
> > Ed Edwards
> > have
use
> > the
> that
> > running
> cut
was
> > just
> > > the mixer tho.
> > > TIA,
> > > Jake
> put
> works
> casue
> > > > > TIA,
> > > > > Jake
> > > > Yikes!
on
> > > > the list?
> at
> contact
> that
> > > > HTH,
> > > > Jon
> nope...no clicking or poping at all. Just very little output. Doyou have
> a number to customer service?Go here...http://www.yamaha.com/service.htm
> headphone output for now? Becasue I use this synth live and havegigs
> coming up. Also could it be some how one of my other pieces ofgear that
> casued the problem.The only way to determine where the problem lies is, as Ed implied,
> through it too. With an older yamaha mixer I had the mono polywould cut
> the output on the rest of the synths to almost nothing. I think itwas just
> the mixer tho.Let us know how it works out.
> TIA,
> Jake
2001-07-13 by Jake B
Sent: Thursday, July 12, 2001 8:38 AM
> On first thought, it sounds like it has to go on the bench... but wait. I
> had some TERRIBLE problems with mine after loading up some patches, so I
> re-initialized it to the factory settings and it fixed everything. The
> re-init procedure is in the back of the manual somewhere. hope this works
> for you
> Ed Edwards
> runs
> > should be ok
> > Jake
> you
slammed
> > the
running
> > your
level
> > proper
> > > signal chain.
> > > Ed Edwards
you
> > > have
> use
> > > the
gigs
> > that
> > > running
would
> > cut
> was
> > > just
> > > > the mixer tho.
> > > > TIA,
> > > > Jake
they
> > put
> > works
> > casue
> > > > > > TIA,
> > > > > > Jake
> > > > > Yikes!
else
> on
> > > > > the list?
sound
> > at
repair
any
> > contact
> > that
> > > > > HTH,
> > > > > Jon
2001-07-13 by jondl_2000@yahoo.com
> ok another addition to the problem. I went to use my an1x lastnight and
> tried the normal outputs and to my amasement they worked fine. Iused it
> for about an hour and a half and then the problem started happeningagain.
> Hooked it up to the headphones and all was happy again. So itsounds like
> it is heating up or something and then cutting out.This is conspicuously similar to the behavior exhibited with
>regards,
> any other ideas?
> jake
Sent: Friday, July 13, 2001 8:48 AM
> night and
> used it
> again.
> sounds like
> the "old" problem of audible 'popping and clicking' sound at start-
> up - until the unit reached a normal operating temperature (jokes and
> comparison to a REAL analog will ensue...) I'm speculating, i.e., not
> fact - just opinion, that the problem with your AN1x is related to
> the other known problem.
> Of course, I could be wrong. ;-)
> Did you reinitialize your AN1x as suggested? This has been known to
> clear seemingly random acts of strange behavior in the AN1x. Isn't
> the key command '7+8+9' while powering the unit up? Then it should
> prompt you with a selection of init options - just choose ALL and
> reply YES.
> Peter K. - if you're following this thread - what was the weirdness
> your AN1x displayed. Didn't you have something along these lines or
> just the 'popping & clicking' problem?
> > any other ideas?
> > jake
> regards,
> Jon
> what was the fix to the poping and clicking problem?Read this...
2001-07-13 by Tom Eales
>regards,
> any other ideas?
> jake
2001-07-13 by Phil
night and
used it
again.
sounds like
reply YES.
> any other ideas?
> jake
regards,
Jon
2001-07-16 by Yutaka Nakamura
> Yes, I believe so. My AN1x exhibited the problem from day one. I knewThank you very much for the reply, Jon. Do you happen to know how much this
> from various user groups that other owners had the same problem. When
> I called Yamaha they readily acknowledged the problem and corrected
> it with a hardware repair at their facility in CA (I'm on the East
> Coast, btw.) Yamaha was great - very helpful. My old dealer (now out
> of business) from whom I bought the AN1x was a MAJOR headache.
2001-07-16 by jondl_2000@yahoo.com
>knew
> > from various user groups that other owners had the same problem.When
> > I called Yamaha they readily acknowledged the problem andcorrected
> > it with a hardware repair at their facility in CA (I'm on the Eastout
> > of business) from whom I bought the AN1x was a MAJOR headache.much this
> repair may cost if the unit is out of warranty (I live in the U.S.,too)?
>my home
> I hate sending out my AN1x, though - it is the master keyboard in
> studio... :-(Oh, yeah - I understand.
> Thanks,regards,
> -Yutaka
2001-07-17 by Yutaka Nakamura
> But I never saw your reply (maybe I missed it) about if you had tried a system
> reset to go back to factory settings. This is a really great thing to try when
> things just seem all screwed up. There may be global settings, or local ones
> screwing it up, but a sys reset ought to get things at least to a known state.
> Plus...if you are hesitating because you don't want to lose all the presets, I
> would bet that if you send it in there is a good chance it will return with
> all factory presets again...
> I sympathize...there are pieces of equipment I would hate to lose even for a
> little while, but if you use the absence to advantage you could find yourself
> getting out of a rut. I mean...right now the weather is too warm in my home
> studio to record, and I am using the time to do the stuff I always mean
> to....like really working on lyrics, and simple songwriting. Too often I jam
> on the recorder and come up with something but it isn't structured
> enough....but I take this opportunity to get better at that.
> Try working on some killer drums, or bass, so you got lots of great stuff to
> work with when you get the An1x back!
> Good luck!
> Jim
> Just a thought
> James R. Acker
