Index last updated: 2026-04-05 19:03 UTC
using the free eg with assignable knobs
2010-11-30 by spaceanimals
I have a bad knob on the AN1X. When I try to edit parameters, knob 5 wiggles on its own, changing parameters I don't want changed. I can work around this mostly by using the assignable knobs. How do I use the assignable knobs to write automation into the free eg?
Thank you.
Jimmy
Re: using the free eg with assignable knobs
2010-11-30 by rlouve_macharvin
I had a problum like this a whiles ago. the knob 4 on my AN1x became unsable & values would jump randomly all over the place.
turns out this is because the solder used on the knobs connection to the main board.
this was fixed by opening up the board, accessing the knobs, heating & removing the old solder on the faulty knob, then applying new solder to it.
since doing so, my knob 4 has worked like new without a single hicup, really made me fall in love with the AN1x again (been an AN owner since 1998)
sy www.stoltz.co.uk
> Thank you.
> Jimmy
