knob woes
2007-06-15 by spaceanimals
Index last updated: 2026-03-31 12:05 UTC
2007-06-15 by Jeff
>One of the knobs on my AN1X is loose. Tap it and the numbers jump allHi Jimmy !
>over. Is there any easy fix?
>Jimmy
2007-06-17 by Ed Edwards
><> <>< <>< ><>http://www.ezekielswheel.com
>> Jimmy
> Hi Jimmy !
> Looks like a bad contact .... or less likely a worn out pot.
> Try to clean it (inside) with an electric contact cleaner, turn it up
> and down when you spray the cleaner inside, wipe out the excess liquid
> and check if your troubles are over . If not, you have to change the pot
> for a new one....(same ohmic value - same shaft type) or at least the
> solder joints on each of the 3 lugs of the existing pot.
> With a good soldering iron with a fine tip, not an ice axe, please, and
> electronic grade solder!
> Cheers
> J.F.
> Community email addresses:
> Post message: AN1x-list@yahoogroups.com
> Subscribe: AN1x-list-subscribe@yahoogroups.com
> Unsubscribe: AN1x-list-unsubscribe@yahoogroups.com
> List owner: AN1x-list-owner@yahoogroups.com
> Shortcut URL to this page:
> http://groups.yahoo.com/group/AN1x-list
> The AN1x Control Synthesizer FAQ::
> http://www.geocities.com/jondl_2000/an1x_faq/an1x_faq_toc.htm
2007-06-17 by Jeff
>Jimmy & Jeff,
>If I know Jimmy by now, he's all atwitchin' since you talked about
>internal organs. But not to worry, Jim me mon... it is a simple fix for
>a tech, should run under $100 at the most. The costs will be due to
>having bench time to get to the offending pot (the tech name for the
>control under the knob) and possibly sourcing an identical replacement.
>IIRC someone on the list said that they had found the correct part from
>a major supplier like Digi-Key or Mouser. Any help? If Jimmy could buy
>the part first, he might save markup money when he puts it in the shop.
>*Ed Edwards*
>http://www.untiedmusic.com/ezekiel
>http://mysite.verizon.net/vze29bq6
>>>Jimmy
>>Hi Jimmy !
>>Cheers
>>J.F.
>>Yahoo! Groups Links
2008-04-22 by spaceanimals
2008-04-22 by Jeff
2008-04-22 by Gerald Raucamp
> Knob # 4 is now offical defunct. For a long time it was loose and theHmm, if it's only the switch that is defunct, you could perhaps replace
> parameter bounced all over the place, now it does nothing.
> Jimmy
2008-04-22 by Bill
>the
> > parameter bounced all over the place, now it does nothing.replace
> > Jimmy
> it with a logical equivalent? It's a non-detented rotary-push switchnumbers /
> or sumthin' smuthin' right?
> or perhaps ask your local yamaha repair center for say, part
> spare part. Might help :Dget a
> (crap, I still need to send a mail to my yamaha repair center to
> replacement cap)can be
> http://www.avishowtech.com/mbhp/images/encspecs18.gif
> Bourne's rotary switch, detented, with switch. Well, the detents
> removed no prob..forums and
> http://www.avishowtech.com/mbhp/buy.html
> Maybe Alps has some replacements as well? :)
> Would be great if it's just something like that.
> or well, maybe I've just been reading too much on the midibox
> way too much into the DIY zone with my head.
> Gerald
2008-04-23 by Ed Edwards
> -----Original Message-----Behalf
> From: AN1x-list@yahoogroups.com [mailto:AN1x-list@yahoogroups.com] On
> Of spaceanimals4:23
> Sent: Tuesday, April 22, 2008 7:44 AM
> To: AN1x-list@yahoogroups.com
> Subject: [AN1x] knob woes
> Jimmy
> No virus found in this incoming message.
> Checked by AVG.
> Version: 7.5.524 / Virus Database: 269.23.3/1390 - Release Date: 4/21/2008
> PMNo virus found in this outgoing message.
