Al ,
He's right !
if you find something interesting in a factory patch , just look how
it's done by the simple observation , so you'll understand quickly how
it works . You can modify factory patches without damage as long as you
don't push the "store" button , followed by "yes" . And , in case of
fatal error you can reset the factory patches as described in the last
pages of the handbook .
J.F.
Ed Edwards a \ufffdcrit :
>aL,
>In this case, it's not a matter of understanding the VA as much as the
>Assignable Matrix and MIDI controllers.
>Turn the matrix rotary to the bottom row and hit the up arrow on Ctrl
>Device. You'll see parameters listed above the "devices" as you scroll
>through such as 1:Mod Depth and an arrow beneath with an abbreviation
>such as MW (for Mod Wheel). The switch to the right, Ctrl No., changes
>the top row of the display which is the MIDI Continuous Controller
>number and assigns this parameter to the device.
>So you've got a device that can control (or change something) having a
>number assigned to it. The most common assignments on all synths are
>for the Mod Wheel to be assigned to CC:1 Modulation Depth and the Foot
>Switch assigned to CC:64 Sustain (often called Hold). Makes sense --
>you would probably want the Modulation Wheel to control Modulation,
>although how modulation is used in the individual synth engine can vary.
> The foot switch is easier to understand because most keyboard players
>would like to have a hold pedal like on a piano for sustaining notes.
>In this case, there's no mystery what the hold pedal does in the synth
>engine -- it forces the ADSR envelope to remain at the fixed level of
>the S parameter until released.
>Now if you'd like to use those knobbies, you'll need to have them
>assigned to something the AN1x engine can use -- in other words, they
>need to have an assignment in the control matrix. The MIDI CC values
>are factory assigned to 41 through 48 and are useful for controlling
>external devices which have been set up to respond to CC changes. As
>far as getting the knob to do something to the internal synth engine,
>you'll need to dial the matrix rotary to the top row and hit the up
>arrow on the Ctrl Matrix button. Now you'll see a synth parameter on
>the top row and a Set number on the bottom row. There are 16 "Sets",
>Pitch Bend Up and Pitch Bend Down and Common 1 & 2. A Set is the
>mapping of a control to a parameter, such as Knob 1 to Resonance. Use
>the Param, Source and Depth switches to assign the Source (a knob,
>ribbon x-y or z, etc.) to a parameter (resonance, AEG depth, etc.) with
>an amount or Depth. (For now lets just deal with Sets and ignore the
>Common and Pitch Bend.)
>*Damn, this is getting involved.*
>What you need to do is to look at a factory preset that you know has had
>the knobs assigned to useful parameters. Then learn from this
>observation which parameters do what when modified. Am I making sense?
> For example, the ribbon X-Y is often assigned to open up the filter
>cutoff with the Z (pressing on the ribbon) mapped to resonance. This is
>good, yes? Damn right it is because if you're soloing with your right
>hand, the left can be whooping and squawking the filter according to the
>left-right motion and pressure.
>Be aware that many variable parameters in the synth engine may not sound
>like ANYTHING when modulated because they just don't have much effect on
>the overall output. It all depends on each individual patch.
>So, to conclude, learn by observation.
>That said (and furiously typed while observing the AN1x), please deposit
>$10 in your DVD drive to reimburse me for my time.
>Ed^2
>http://www.untiedmusic.com/ezekiel
>Community email addresses:
> Post message: AN1x-list@yahoogroups.com
> Subscribe: AN1x-list-subscribe@yahoogroups.com
> Unsubscribe: AN1x-list-unsubscribe@yahoogroups.com
> List owner: AN1x-list-owner@yahoogroups.com
>Shortcut URL to this page:
> http://groups.yahoo.com/group/AN1x-list
>The AN1x Control Synthesizer FAQ::
> http://www.geocities.com/jondl_2000/an1x_faq/an1x_faq_toc.htm
>Yahoo! Groups Links
>Wanadoo vous informe que cet e-mail a ete controle par l'anti-virus mail.
>Aucun virus connu a ce jour par nos services n'a ete detecte.
>avast! Antivirus: message Entrant propre.
>Base de donn\ufffdes des virus (VPS): 0614-1, 04/04/2006
>Test du: 05/04/2006 20:18:08
>avast! - copyright (c) 2000-2004 ALWIL Software.
>http://www.avast.com
avast! Antivirus: message Sortant propre.
Test du: 05/04/2006 23:06:05
