50g group photo
50g
Archive for 50g.
Can anyone answer a question about compiled local variables?
2009-07-05 by rickwendel763242
I made a program that looks like this: << Right Arrow (0 key) and a left arrow from the CHAR menu followed by X Y << X Y + >> >>.
1) No matter what the program is doing it drops 1 number in the stack above it.
2) If you only enter two numbers and their is no number above the two level stack, you get an error.
3) If you try to enter a number into the program before the point where the variables are initialized, all sorts of weird things happen and it won't let you.
4) You don't end up with any extra variables at the end of the program execution but then again I don't think its actually acting as a compiled local variable with the left arrow added. If you remove it and just use regular local variables theirs no problems.
5) So, can anybody write a simple program using compiled variables so I don't have to PURGE all the variables I use all the time?
RE: [50g] Can anyone answer a question about compiled local variables?
2009-07-05 by Jeremy Hawdon
The left arrow on its own is a compiled local variable, and the X and Y are non-compiled local variables. Hence 3 values are required for your program to make the value assignments. You need two variables each with left arrow as the first character in the name.
Jeremy
From: 50g@yahoogroups.com [mailto: 50g@yahoogroups.com ] On Behalf Of rickwendel763242
Sent: 05 July 2009 21:11
To: 50g@yahoogroups.com
Subject: [50g] Can anyone answer a question about compiled local variables?
Re: [50g] Re: Can anyone answer a question about compiled local variables?
2009-07-06 by Don Hart
The left arrow becomes part of the name of the variable, e.g.
<< -> <-X <-Y << <-X <-Y * >> >>
This takes 2 numbers off the stack.
--- On Sun, 7/5/09, rickwendel763242 <rickwendel763242@...> wrote:
> From: rickwendel763242 <rickwendel763242@...>
> Subject: [50g] Re: Can anyone answer a question about compiled local variables?
> Date: Sunday, July 5, 2009, 2:28 PM
> So, how do your store data in
> variables from the stack and use it anywhere in the program
> or sub-routines?  Where's the left arrow go?
>     mailto:50g-fullfeatured@yahoogroups.com
2009-07-07 by Tim Wessman
I will write one using a single command.
Type in 'PROG(X,Y)=X*Y^2' and then push DEF. PROG appears. Recall it an see that it looks like this. << -> X Y 'X*Y^2' >>
Here is another:
<< -> A B C << A 2 ^ B 2 ^ + C 2 ^ = >> >>
TW
