50g group photo
50g
Archive for 50g.
Glad to be a member
Glad to be a member
2007-01-21 by bobaroo7
I'm glad to be a new member.
I am a new owner of a 50g since Nov.2006. I'm slowly learning to use
this calculator.
I can't get the the equation Ke = -Ln[(Vd)(Tr)divided by D divided by 1+
(Vd)(Tr)] divided by tau minus t'. I'm using the algabraic mode. I use
this equation at work. I know the numerical values for variables except
Ke. It would be very helpful to store this equation and plug in the
variables.
I have spent hours on this equation , but still get the "syntex error"
message.
I would appreciate any help.
Bob Blackwelder
Knoxville, Tennessee
Re: Glad to be a member
2007-01-22 by Don Hart
I'm not sure if this will come thru ok, I've never posted code here
before. I think this is what you want.
%%HP: T(3)A(R)F(.);
'Ke=-LN(Vd*Tr/(D*(1+Vd*Tr)))/(\Gt-T\180)'
Just save the 2 lines to a file and use Kermit to transfer to the
calc (or use the ascii mode of your transfer program).
I know this doesn't teach you how to enter the equation. It's hard to
tell where you're going wrong. Usually the problem point in your
entry is highlighted when the error message is displayed. If you can
tell us where the highlight is, we might be able to determine the
problem.
Oh, and for the tick mark in the "t'" I used the alpha/right-shift/U.
You can't use the regular tick mark because it's used to delimit the
equation itself. You can find it and the tau if you select the "char"
button on your keyboard.
use
> this calculator.
by 1+
use
except
> variables.
error"
> message.
> Bob Blackwelder
2007-01-23 by Tim Wessman
Easiest way to enter in an equation is to use the equation writer.
Then once you have it entered so it looks correct, select the whole
equation and push COPY (RS-VAR). Now you can hit PASTE anywhere you'd
like it.
TW
2007-01-23 by bobaroo7
> %%HP: T(3)A(R)F(.);
to
can
> problem.
I will try this.
Bob Blackwelder
Knozville, Tennessee
shift/U.
the "char"
> use
> > this calculator.
divided
> by 1+
I
> use
> except
> > variables.
> error"
> > message.
> > Bob Blackwelder
