50g group photo
50g
Archive for 50g.
List of numbers goes beyond the right edge of the display
2009-06-05 by rickwendel763242
I'm in RPN mode and have two lists of numbers I'm adding together. The list goes beyond the display. When I use the 4 silver arrow buttons either nothing happens or I get some weird formula come up or when I press the F6 key it merely brings up the menu. How do you display the contents of the screen?
Re: [50g] List of numbers goes beyond the right edge of the display
2009-06-05 by Michael Carey
Hit your down arrow and it will bring up the contents.
Mick
Re: List of numbers goes beyond the right edge of the display
2009-06-05 by Juan C.
Press the [up-arrow] ( or alternatively you can press the [HIST] key) you are now in the interactive stack mode, then press [F2] for VIEW, you are now in GRAPHIC mode and you can use the [left-arrow] or [right-arrow] to see the contents of the list press [F1] for TEXT and you will see the hole list, finally press [ON] as many times as necessary until you are back in the regular mode.
2009-06-07 by Don Hart
Try turning off flag -52
<<-52 CF>>
Flag -65 determines how stack levels 2 and above display the list.
You may also want to check the documentation for flags -66 and -97.
