50g group photo
50g
Archive for 50g.
How do you graph the defined function, F(x) = X^2 + 1
Re: How do you graph the defined function, F(x) = X^2 + 1
2009-05-25 by Juan C.
Hello Rick, Once you defined your Function F(X), In RPN;
Hold |left-shift| key and press |F1| for Y=, then press |F2| for ADD.
Type F(X) and press |ENTER| .
Hold |left-shift| key and press |F2| for WIN.
With arrows keys you can move and then type in the different values for your window, or just select the H-View window parameters and then press |F4| to AUTOmatically calculate V-View.
|F5| to ERASE the graphic window.
and |F6| to DRAW the function.
